Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Maintenance, Oil, and Fluids => Topic started by: SuperPete on November 01, 2021, 02:33:04 PM
Title: PTU Oil service - EASY WAY
Post by: SuperPete on November 01, 2021, 02:33:04 PM
Hey guys, I am back after little time off.
Back to the PTU service, I think I found easy way to replace oil without draining it.
Simply remove fill plug, keep filling it with clean new oils and after about 2-3 quarts you replace old oil with new.
Thoughts?
Little DYI video:
https://youtu.be/3J7f0hajiKE
Title: Re: PTU Oil service - EASY WAY
Post by: Macgyver on November 01, 2021, 09:39:49 PM
You will never get the Older oil out of the bottom of the PTU case ?
Post by: SuperPete on November 02, 2021, 08:55:10 AM
You can't get that out even by sucking it out, the hose can never get all the way down to the lowest cavity.
If you want absolute full swap, you need to drill hole on the bottom for drain.
Post by: irondoor19 on November 02, 2021, 03:25:34 PM
Ok i found this on U tube:
and i have been doing this from when i was driving 2013 Ecoboost PI
https://www.youtube.com/watch?v=pQBjQAq3La8
Purchase the 1/4" Check Valve and a 1/4" Female Cap, (about 20.00)
If you want to make it even easier, Replace the PTU Vent Hose with a Larger and 1 Foot Longer Length (about 48", 4.00)and add a Breather Filter instead of the Stock PTU Breather."you can also Fill thru this hose if you want, A bit more time and Mess"
Pull the Drain Plug,
Install the Check Valve,
Fill (with a Simple Pump 10.00)
with 18 OZ of your Favorite Go Juice
and after filling install the 1/4" cap,
NOW takes about 20 Min Max to refill ;D
Post by: Macgyver on November 02, 2021, 09:21:21 PM
I got most of it out by sucking it out. Then Installed a larger vent hose and filled it using the vent hose using a big turkey basting syringe. Works quite well and no mess.
