Ok,
So I had an issue with the front right headlight connector burning out.
Replaced it once and then the pins were not making good connection with the bulb. So I just replaced it again and now the passenger headlight will not work at all. When you turn the lights on there is 12 V showing on the connector but it is reversed from the colors. When you plug the bulb in the voltage goes away. We have looked at the fuse block underneath the steering wheel and those fuses are good. Driver side is still working. I have yet to check that voltage on that side but currently and I say this with all sincerity.."stump the band". :bangin: :bangin: :bangin:
