I was having a discussion on Facebook about how the cylinders were labeled and what was bank 1 and bank 2 in our '10 MKS Eco. The majority opinion was the back 3 were 1, 2 and 3 from passenger side and the front were 4, 5 and 6. I've replaced 2 coil packs and used the 1,3,5 back and 2,4,6 front layout to successfully make the repairs. There's limited info online to confirm but I found this diagram which supports my belief it's correct. What say ye EcoBoost gurus?
Also which is bank 1 and bank 2?(https://uploads.tapatalk-cdn.com/20200502/3977172e14a0d5bf9b648e7bdb442389.jpg)
Sent from my LM-G710 using Tapatalk
Quote from: Black Dream on May 02, 2020, 10:33:22 AM
Firing order or cylinder number? That diagram is the firing order.
Cylinder numbering would 123 left to right on the bank 1 and 456 left to right on bank 2 if you are looking at the motor from the front of the car.
Bank 1 is the bank with cylinder 1 closest to the fire wall.
Cylinder order was my main question but your answer is intriguing. I've had 2 cylinder misfire codes in the last 7 months a couple of months apart, one P0305 and 0302 with the car running rough. I replaced the coil pack in the back right which is cylinder #3 thinking it was #5 in the first repair and it fixed the 0305 issue. Then I replaced the front left cp assuming it was cylinder 2 and it fixed the 0302 issue. Am I missing something here?
Quote from: Black Dream on May 02, 2020, 11:19:27 AM
Right from the ford troubleshooting manual(one of them anyway!!!)
"Ford F150 P0305 Definition
P0305 is a cylinder specific misfire code, which means that Cylinder 5 is misfiring and causing it. An important thing to understand when finding the location of Cylinder 5 is that it's going to be the fifth cylinder in the firing order. It won't be the fifth cylinder that you might see when looking at the engine."
Coils were clean and dry? An oil leak was the first possibility that came to mind. Also the codes are likely to return after some time. How long has it been since you changed the coils?
On an offtopic note, how old is the battery in your MKS?
StealBlue nailed it. I had no idea the codes followed the firing order, not the cylinder numbering.
And even at 109k miles my motor's super clean. No leaks anywhere and the battery is only 6 months old, a Duracell. Thanks for the help fellas.
Fingers crossed problem solved :)
I haven't had an issue with either since.
:thumb: :thumb:
Code reader states which cly in block is misfiring. Not the the firing order.
Very curious to see more responses from the masses.
The best knowledge comes from the factory manual, the OBD II operations manual, and of course specialized knowledge gained in the field.
https://www.motorcraftservice.com/FreeResources/OBD (https://www.motorcraftservice.com/FreeResources/OBD)
https://www.stratifiedauto.com/index.php?main_page=page&id=20 (https://www.stratifiedauto.com/index.php?main_page=page&id=20)
Knock specific
http://stratifiedauto.com/blog/understanding-knock-and-ignition-corrections-in-your-high-performance-ecoboost-engine/ (http://stratifiedauto.com/blog/understanding-knock-and-ignition-corrections-in-your-high-performance-ecoboost-engine/)
Quote from: Black Dream on May 11, 2020, 12:01:19 PM
Last summer when my injector hung open it called out cylinder 2 as the misfire. The firewall middle cylinder is the one that was soaked with gas.
