General Ecoboost Discussions => Ecoboost News! => Topic started by: Code AiR on December 28, 2019, 12:02:46 PM
Title: Aftermarket sway bars!
Post by: Code AiR on December 28, 2019, 12:02:46 PM
Just wanted to give you all a heads up. I know in the past there has been a demand so I thought I would share. Check the attachment below for further information. I'll try to keep an eye on the post and let you all know when any further progress is being made.
Title: Re: Aftermarket sway bars!
Post by: bpd1151 on December 28, 2019, 04:25:49 PM
***subscribed***
If the "place in cart" tab was available now, I'd certainly be clicking on it.
Post by: Code AiR on December 28, 2019, 07:55:32 PM
Quote from: bpd1151 on December 28, 2019, 04:25:49 PM
***subscribed***
You were the first person I thought of when I saw this. I was going to mention this in your build thread but I didn't want to clog it up.
Post by: bpd1151 on December 28, 2019, 08:07:39 PM
Appreciate it. A PM would've worked to, but in this case, posting it for mass consumption and sharing best serves everyone involved.
Targeting for mid March maybe on mine. Or at least hopeful for that time frame.
Maybe these'll be ready by then. Guess we'll all see.
Post by: 802SHO on December 28, 2019, 10:11:05 PM
Looks good I'm interested as well
Post by: Code AiR on January 03, 2020, 03:14:34 PM
Just a little update.
Post by: Code AiR on January 03, 2020, 03:16:00 PM
I'm surprised how easy of an install this looks like.
Post by: nickstewartroc on January 03, 2020, 06:31:19 PM
Hoping the Flex is similar enough I can put one of these one
Post by: ZSHO on January 03, 2020, 07:30:46 PM
Group Buy perhaps!! Great to see new products introduced/developed for 2020! Z  :)
BTW - Probably will need a wheel alignment after install...
Post by: Eliuprt on January 30, 2020, 08:28:40 PM
hello. i`m the guy who start all this with Whiteline. Lil update:
Mitchel Yardley (https://www.facebook.com/71Yardley3 (https://www.facebook.com/71Yardley3)) needs test SHO to check our 24 mm 2 point sway bar fitment. Located in SoCal. Ontario.
when Mitchell gets his test vehicle in he will make measurements and then Whiteline should be able to offer set of universal adjustable links.
So we need test SHO asap
Post by: bpd1151 on January 30, 2020, 09:27:35 PM
Damn. Hopefully a test fitter pops in and volunteers their ride for fitment.
Not only am I no where near you guys, but my whip is still not running/driveable etc.
Good luck!
Post by: 802SHO on January 31, 2020, 04:41:24 AM
Please don't let a SHO coming in stop this train, if you send a pair OUT you would be looking at hundreds of test SHO's willing to put this on and take some measurements, myself included!
I would also check nearby Rental Agencies.
Post by: bpd1151 on January 31, 2020, 07:22:40 AM
All great points there 802!
Well suggested good sir.
Post by: SM105K on January 31, 2020, 12:11:40 PM
Quote from: Eliuprt on January 30, 2020, 08:28:40 PM
If he is intersted, I will be in SoCal April 6-10 and he can shore everything up then.
Post by: Eliuprt on February 06, 2020, 04:29:00 PM
From Mitchell: (the guy from Whiteline who make this parts)
Hi guys. I just finished install of our @whiteline prototype rear sway bar. What you are seeing is a 24mm solid spring steel bar with 2 points of adjustment, whiteline adjustable endlinks, and lateral locks. Upon installation with stock links we were hitting the bottom control arm on big dips and driveway inclines. So I put together a tad bit longer end link than OEM and now we have plenty of clearance. Check out the before and after of the clearance. Yes there is still ground clearance for normal driving.
That being said we will most likely have to sell these bars with our endlinks or we might have an option for customers who want to use something else. But a longer link will be needed!
I should have pricing hopefully in the next couple of days. These bars should be ready within 1-2 months.
I know some people don't like the red bars so we might be able to do our signature Whiteline silver.
To the people asking about if the car got lowered. The links just need to be adjusted longer to accommodate a lowered car, that`s it
Post by: bpd1151 on February 06, 2020, 04:36:13 PM
Sharp. Great update. Thank you.
Look'n forward to its completion.
Post by: Moisme33 on February 06, 2020, 06:31:06 PM
Definitely interested in this setup!
Post by: Eliuprt on February 06, 2020, 10:36:31 PM
reply to the people asking about if the car got lowered. The links just need to be adjusted longer to accommodate a lowered car, that`s it
Post by: 802SHO on February 07, 2020, 06:41:14 AM
Me want
Post by: Eliuprt on February 28, 2020, 08:59:12 PM
Last update from Mitchell. They make 3-rd prototype to clear
Hey all once again. Sorry for so many updates. But I believe we are all good with the rear sway bar. I test fitted the new bend design and it looks like we are all clear. Its clearing the control very well. After test driving. I did not notice any knocking like I did before on big dips and bumps and inclines on driveways. However, this was on a bone stock SHO suspension wise. I can't be 100% certain on a lowered SHO. However, it should clear still. I can cross that bridge when It comes.
That being said here are the photos of the bars. I am relaying all the fitment data to my team and we can hopefully have bars ready to come over here by The middle of April. I know its a long wait but it should be worth it.
Thank you, everyone.
P.S. I think they will offer sway separately and sway + endlinks if needed.
Post by: 802SHO on February 29, 2020, 09:58:46 AM
Quote from: Eliuprt on February 28, 2020, 08:59:12 PM
Send me a set, I'll verify they clear a lowered SHO...better yet...a lowered SHO with cut lowering springs....then you'll know they'll clear anyone's ride!
Post by: wraitherx on May 12, 2020, 10:21:54 PM
Anyone know what the final outcome of this is?
Post by: FiveLeeter918 on May 12, 2020, 10:40:27 PM
Well Mitchell was released from the company when they shut down for COVID. I've been I'm contact with another sales rep who says they will still be produced, but are delayed due to COVID. He said the work order has been created and they will have a bulk buy that I'll be hosting. I actually need to follow up on this, will report back when I have more details.
Post by: bpd1151 on May 12, 2020, 10:42:59 PM
My build has been slowed down as a result of the COVID-19 pandemic, and all of the resulting shut down orders.
So I completely get it.
Thanks for the update. Still interested.
Post by: wraitherx on May 13, 2020, 09:12:16 AM
Understandable and thanks for the update!  I'm interested as well!
Post by: SM105K on May 13, 2020, 10:55:04 AM
Interested as well.  I can turn and burn a trip for fitment as well.  I can be in Ontario in about 4.5 hours.  I am sitting on cut H&R's as well.
Post by: Dxlnt1 on May 13, 2020, 07:00:12 PM
Im just seeing this but could've helped out. I am roughly 30-45 minutes aways from Ontario. If you still need protype car to test firment lemme know!
Post by: avidmotion on May 19, 2020, 06:55:37 AM
sub
Post by: FiveLeeter918 on June 26, 2020, 08:49:27 PM
still waiting on a manufacturing update unfortunately
Post by: xartic1 on August 01, 2020, 11:18:02 AM
I have an Explorer Sport and I just came across this thread. I have done some cross referencing of the Explorer's rear sway bar and the Taurus and it looks like the parts are cross compatible with one another (Sport and SHO) according to FordPartsGiant.
Has anyone looked into getting the Explorer's Steeda rear sway bar to see if it would work?
Post by: Noahjohn on November 18, 2020, 05:45:35 AM
Interested!!
Post by: StealBlueSho on November 24, 2020, 09:30:17 PM
Worth every penny
Post by: Lincmark8 on May 16, 2021, 04:37:24 PM
Is this for 2009-2012 and / or 2013-2019? I have a 2011 Lincoln MKS w/ ecoboost. Same exact suspension setup as SHO. I live 45 minutes from Ontario. Any day  I can go for fitment.
