Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: Desmond1491 on October 29, 2019, 01:03:39 AM
Title: Ford told me to get a new engine smh !!!
Post by: Desmond1491 on October 29, 2019, 01:03:39 AM
What do you guys think ?  65 psi for cylinder 5 I know that is low but is it fixable?
Title: Re: Ford told me to get a new engine smh !!!
Post by: SHOdded on October 29, 2019, 06:47:20 AM
i am a little confused.  they say relative compression was equal across all the cylinders, were ALL the cylinders low compression?
https://www.tiepie-automotive.com/en/articles/relative-compression-test (https://www.tiepie-automotive.com/en/articles/relative-compression-test)
Causes of low compression:
https://dannysengineportal.com/engine-compression/ (https://dannysengineportal.com/engine-compression/)
But yeah, generally if even 1 cylinder is low compression, the best option on an ecoboost is to replace the engine, time & $$$ wise.
The power of an oscilloscope.  This guy walks you through basically what the dealership did.
https://www.youtube.com/watch?v=5ZBHHeX1oZI (https://www.youtube.com/watch?v=5ZBHHeX1oZI)
Can you post a video of the engine cranking, you can hear that low of a compression pretty easily, and assuming the battery is good at the time of the test, figure out if there IS a problem even without scoping.
Post by: TopherSho on October 29, 2019, 10:30:01 PM
Get a second opinion as always...
oddity :: equal across all cylinders may have been a typo ... but when my mechanic did a compression check i got results for ALL cylinders independently rated not just one.
What happened to the fuse?  report lists it as missing .. ?
Post by: Desmond1491 on October 30, 2019, 06:56:43 PM
Anybody know any good places I can get a engine from so I can swap the one out I have now ?
Post by: SHOdded on October 30, 2019, 07:05:13 PM
LKQ, car-part.com, etc.
Post by: Desmond1491 on October 30, 2019, 07:26:31 PM
How do you know if you have a oil cooler or not ? There is two different Types of engines
Post by: SHOdded on October 30, 2019, 08:30:18 PM
You have a 2010.  Your MKS does not have an oil cooler.
Post by: bpd1151 on October 30, 2019, 08:37:18 PM
 But that said, an oil cooler can be easily retrofitted if you so desired
Post by: Desmond1491 on October 30, 2019, 09:12:51 PM
Ok just making sure just don't want to get the wrong one
Post by: SHOdded on October 30, 2019, 09:20:08 PM
Technically, any engine from the transverse 2010-2019 family will fit, but there will be some (not major) differences when you cross model lines.  Especially if you decide on a Police Interceptor engine or Explorer engine.  Easily overcome, but just to be aware.
Post by: Desmond1491 on October 30, 2019, 09:27:49 PM
I got it .... just want to get the same one for my year model so it's no confusing
