Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: MKS Tom on June 21, 2019, 05:01:39 AM
Title: Can catted down pipes general any smell?
Post by: MKS Tom on June 21, 2019, 05:01:39 AM
I recently installed PPE catted down pipes on my MKS.  I have noticed a few times at night an off-putting smell on a WOT pull since they have been on.  I know smells are associated with catless, but mine are catted.  I don't think it is my tune being too rich.  I doubt at it is a failing PTU or cat as it only started the when these were installed, the first night I thought it was a skunk as I live in a rural area so I didn't associate it with the car and I have no mechanical issues doing on.  Car shifts and runs just fine.  It only seems when I get on it and thus far I have only noticed it at night as I work 2nd shift.  If it is a byproduct of them then so be it, but just trying to narrow it down.  Thank you for any input.
Title: Re: Can catted down pipes general any smell?
Post by: 802SHO on June 21, 2019, 06:13:10 AM
Are you smelling it in the cabin or after parking it and shutting it off?  New exhaust piping generally has a slight odor to it as it gets hot, I could understand if you smelled it after parking it.  After just a few days it should dissipate.
Post by: ZSHO on June 21, 2019, 06:45:58 AM
Have you also used the A/C Prior to Key OFF!  Its been quite humid the past week along with new pipes. Z
Post by: SHOdded on June 21, 2019, 11:10:35 AM
Recheck the bolts and studs, could be loose.  May need to double gasket.  Also check the flex pipes for cracks.
Post by: shoNoff on June 21, 2019, 12:04:03 PM
I run ssw catted downpipes. I've been running them for roughly 13k miles with stock cat back. Never had a funny smell from them.
Post by: MKS Tom on June 21, 2019, 01:43:32 PM
In the cabin.  I usually let my remote start let the car idle for a few minutes before leaving work, AC on.  Bolts seem fine and I don't believe I have an exhaust leak as it sound just as it did prior.
Post by: MKS Tom on June 21, 2019, 01:51:15 PM
I had my mechanic install them.  I provided new gaskets, bolts, studs, etc as well as the provided gaskets and bolts from PPE.  It's weird I don't notice it at all while normal driving or even in the day, but I also don't recall really getting on it during the day since they have been installed either.  It's always at night as I get off at 1 am.  Same pattern.  If I drove home normal, I don't get the smell.  It's not every day.
Post by: MKS Tom on June 21, 2019, 02:11:18 PM
I live only 4 miles from work.  When it's been noticed, it has been on a WOT on a back road shortly after leaving work.  When I get home I can't smell anything outside the vehicle and it has already dissipated inside the cabin.  It's just a quick awful scent from that pull, not even sure if it has been on every time I have gotten on it but it doesn't show up under a normal drive home.  No CEL from these pipes and it is under the same tune revision as prior.
Post by: shoNoff on June 21, 2019, 02:48:36 PM
Who is your tuner? I'd have them update the tune for the pipes. It will make a difference.
Post by: MKS Tom on June 21, 2019, 03:16:34 PM
I am going to be switching to Brad shortly.  Not looking to bash the tuner.  I don't think that is the issue, but I was never told one way or the other if my regular datalogs or the idle log I sent indicated anything problematic.  I don't believe it is the tune, but I do not know that kind of stuff.  I don't wish to have "tuner" drama in any way.
Post by: shoNoff on June 21, 2019, 03:56:50 PM
Quote from: MKS Tom on June 21, 2019, 03:16:34 PM
I can speculate who it is by your answer. I wasn't bashing your tuner at all. The tune needs to be updated with the pipes on. That is what I was getting at. I have both AJP and Unleashed tunes for my car. Both updated the tunes when I put the pipes on. Neither tune has a smell and both run really well.
Post by: ZSHO on June 21, 2019, 04:28:53 PM
I would check n inspect the under-carriage or engine bay for any visual signs of any leaks! Check the oil level for a peace of mind! I know the PTU FLUID can smell downright Bad! TOL. Z
Post by: MKS Tom on June 21, 2019, 06:40:12 PM
Quote from: shoNoff on June 21, 2019, 03:56:50 PM
It was the most professional way I could think of to answer it without ignoring the question as others would want to know that. I will say that I never contacted another tuner prior until 2 days ago or even had sent them as much as an email or DM. I think Facebook is great to meet others whom are into the platform but it also creates drama and this constant paranoia of "tuner wars" where fake accounts chirp about nonsense and people get real weird pretty fast for no apparent reason.
Post by: MKS Tom on June 21, 2019, 06:44:59 PM
Quote from: ZSHO on June 21, 2019, 04:28:53 PM
It is certainly possible and thankfully I have a warranty if that is the case.
I don't believe it is though as I didn't see a leak and the timing of this lined up with these being installed.
Also, the smell isn't often and seems to only be at WOT. Also my ride home is short and it's no less than 5 minutes and no more than 10 minutes after I smell it I am in my driveway. I have went on the ground after I got home and couldn't smell it. That would indicate it was a gas rather than burning oil but who knows.
Post by: CroR1 on June 21, 2019, 07:12:13 PM
Catted or cattles,  smell is normal.
Post by: SHOdded on June 22, 2019, 04:58:07 AM
Would check the flex pipe for sure.  Common place for exhaust leaks esp when the exhaust system is disturbed, or with age.  Otherwise we are looking at the cabin exhaust flaps behind the rear bumper, and interaction with recirc mode on the climate control (if windows are closed).
Post by: MKS Tom on June 23, 2019, 10:50:02 PM
My guess is it is likely a normal smell that some people get or a leak that I cannot detect at idle.  I checked for leaks today from the PTU and don't see any.  I highly doubt a cat is going bad at the same time.  I do not believe it is the tune being too rich with me running the same tune switching plug gap (.030 to .026) and adding the pipes, but I am switching tuners regardless so that would answer that part.  I lean towards I am one of the people who is getting it for whatever reason as some do and some don't.  Next time I have it in the shop I will have everything checked for leaks in the exhaust, which should be soon as the dual CAI is done and I would rather pay my mechanic to install it.  lol
Post by: MKS Tom on June 25, 2019, 01:26:13 AM
I have a boost leak as I am set up for 17 psi on my tune and I am only getting 12-13 psi.  That is likely the cause.  I am going to try to source the leak soon.  If I cannot fix it myself it will wait to go back to my mechanic until the dual CAI comes in as I am going to have him do that for me anyways.  I am going to guess this is likely the smell, just have to source the leak with some soapy water.
Post by: ZSHO on July 10, 2019, 01:19:33 PM
I most recently installed the PPE Catted DP and can confirm that they do emitt a strong odor after performing a few pulls on the Highway!
I dont recall that on my last set! Dunno.
I'm assuming because they are new and due to the high heat exhaust gases they will need to break in and monitor for any notable changes.  Z
(http://i65.tinypic.com/2qtfn5s.jpg)
(http://i68.tinypic.com/34ec9eg.jpg)
(http://i64.tinypic.com/348on6c.jpg)
Post by: SM105K on July 10, 2019, 02:51:13 PM
Those look good Z!
Post by: ZSHO on July 10, 2019, 03:24:30 PM
Quote from: SM105K on July 10, 2019, 02:51:13 PM
Those look good Z!
Thanks brother! Everything is new from Turbo to Flange/Flex pipe with no signs of visible leaks!   :)
I wish the Undercarriage was clean as yours! Z
Post by: SM105K on July 10, 2019, 03:39:20 PM
Quote from: ZSHO on July 10, 2019, 03:24:30 PM
Those look good Z!
Thanks brother! Everything is new from Turbo to Flange/Flex pipe with no signs of visible leaks! Z  :)
Sweet.
Post by: 802SHO on July 11, 2019, 06:49:55 AM
I concur very nice replacement and in true OCD form.  Well done.
Post by: ZSHO on July 11, 2019, 07:13:03 AM
Thanks for the kind words Fellas!  :) Bit of extra TLC goes a long way IMO!
The SHO feels much smoother than before especially on a cold morning startup @ idle and probably due to the new Gaskets,hardware and 02's all around!
Good rule of thumb DO NOT RE-USE OLD Gaskets as mentioned a while back as they are only for one time use only!
To the OP did not mean to Hi-jack your thread. Z
Post by: MKS Tom on July 14, 2019, 10:07:51 PM
I haven't noticed anything in 2 weeks.  I thought possibly I had a boost leak at one of the charge pipes that I disconnected to access the rear plugs was a cause of it.  Regardless, it has not smelled in a while.  Hopefully it stays that way.
Post by: ZSHO on July 24, 2019, 11:16:41 AM
I can officially say that after a couple weeks of the PPE DP INSTALL the smell completely dissipated and smells like fresh Roses with a hint of the new car smell once again! Z  :)
Post by: MKS Tom on July 25, 2019, 03:22:49 AM
Mine has gone away too.  They are awesome pipes so I am glad it was not a long-term thing.
Post by: AJP turbo on July 25, 2019, 01:58:48 PM
Quote from: MKS Tom on July 25, 2019, 03:22:49 AM
What do you contribute the smell going away to?
Post by: MKS Tom on July 26, 2019, 04:45:11 AM
Quote from: AJP turbo on July 25, 2019, 01:58:48 PM
I am assuming it was gasket material as ZSHO alluded to.  I'm not sure exactly. I did notice that the charge pipe was not put back flush against (thought I had it very tight) from when I had removed it to gain access to the rear plugs when I changed them all the night before dropping it off to have my mechanic install the downpipes.  I doubt it was that, but I do think it seemed stronger when I had the AC on too on those few times I had happen and less of a smell when it was off.  Who knows.   The first night I had pulled logs for you I had ran logs on the other tune and didn't notice it, but that was an very long night as I ran those logs, returned to stock, took 3 hours for the update the SCT, loaded your tune, and ran logs.  All the while trying not to hit deer or alert my local police with my excess speeding at 4-5 am to get log info.  lol
Post by: ZSHO on July 26, 2019, 07:01:56 AM
Quote from: MKS Tom on July 26, 2019, 04:45:11 AM
They needed some time to "break in" as these are catted DP that's all! Z
Post by: MKS Tom on July 26, 2019, 02:33:45 PM
Quote from: ZSHO on July 26, 2019, 07:01:56 AM
The reason he is asking me is I approached him with the issue prior getting his tune.  I was keeping it out of boost as it was only at WOT in the event I had a tune issue before switching to his.  I began to drive it like a grandmom for 7-10 days prior so it may have cleared out by then without me knowing it.  When I got on it for datalogs for both tunes the one night of getting on it I didn't notice anything but I had also tightened up my charge pipe too that wasn't flush.  I am guessing it is simply the break in for the pipes/gaskets but we were trying to source this for a bit.
