We loaded up the two cars and took off for an overnight fishing trip after Christmas. Slept overnight in the fish house. Went out to get something out of the car the following morning and both front windows were down and my sunroof was open??? Electrical gremlins? I tried to start it a couple of hours later when it warmed up to a balmy -8F or so and it wouldn't start. Tried it 3-4 times. It would turn over fairly slow and just when it was about ready to take off it would stop cranking. If it wasn't push button start that evidently stops after 5 seconds of cranking I'm pretty confident it would have started. So, I hooked up the wifes 2014 Taurus SEL to it with the jumper cables and after letting her car run for 10 minutes or so with the cables hooked up my car popped right off. It's not the original battery but it's a cheap aftermarket one. Don't know if it's bad or not so will have to get it tested. Thinking some electrical gremlins might have drained the battery overnight. It's a little unnerving knowing I could leave my car overnight somewhere and the damn windows and sunroof will open on it's own. Anyone ever heard this one before? I've seen other issues related to cold weather but not this one. But, it also reminds me of the key FOB shortcut to open your windows on a warm day so if somehow my key FOB that was in my pants pocket on the floor somehow magically did whatever you have to do on the buttons to make it work. I don't see that happening though. I used to know how to do this on my old car but not this one. Any ideas guys? What's the coldest weather you have ever started your SHO in?
https://www.cnet.com/how-to/how-to-instantly-lower-your-car-windows-with-the-key-remote/ (https://www.cnet.com/how-to/how-to-instantly-lower-your-car-windows-with-the-key-remote/)
Battery. Crapped out. Replace it with an MC 850.
Key FOB opened your windows. You likely pressed it by accident, not knowing, or being aware of that feature. Read your owners manual. It explains it.
Finally, starting in cold? For me, -33 a few years back. But that was when I still drove it during the winter. Not anymore.
Quote from: bpd1151 on December 27, 2017, 12:07:15 PM
So it looks like you just hold the unlock button for 2 seconds to roll the windows down according to Google? I'll try it here on my lunch break. On my old car it was a sequence of buttons you had to push so that's why I thought that would be damn near impossible to do by accident. So the one time it happens by accident just so happens to be the time my car won't start due to cold weather and a weak battery. Story of my life....
Holding down the unlock button for an extended period of time opens your windows and sunroof in the SHO. It does the same thing in the Lincoln MKS. However, it also works in reverse in the Lincoln. In other words, you can press the lock button and hold it and everything will close. At least in the 2010 through 2012 SHO, that function to close all the windows and sunroof with the key fob wasn't there. At the time, some of us laughed and said apparently they trust the Lincoln owners not to close a window on someone's arm, but not the Ford owners. LOL
On one occasion, in my six years of ownership, I have had all the windows down and roof open when I came out of my office. It's possible that I accidentally hit the fob button for an extended period of time...... Though to this day, I still doubt it........ and I think something else caused it. I have absolutely nothing to prove that though.
So are all 4 windows and the sunroof supposed to open? I had just the front two and the sunroof open.
Just the front and sunroof open.
Yup, it works. Both front windows and the sunroof open. I find it odd that it's this easy to do though. Seems like you could accidentally do it fairly often pretty easily just having to hold one button for a few seconds. Like I said, on my old vehicle you had to push a sequence of buttons.
I do believe you can go through the settings in the gauge cluster and disable that functionality if you don't want it.
-13*F... I didn't realize people were living on Hoth. As a Florida boy, that just seems so insane. I don't get along with cold weather, lol.
If you make it too easy, people hate it. If you make it too cumbersome, people hate it. LOL, Ford can't win! Always wanted a flip hardshell cover tho, as fobs end up in many places they shouldnt be ;)
Def have the battery checked with a digital tester that looks not only at voltage but CCAs. CCAs are more important. And the higher the reserve capacity the better. An AGM battery is in your future, and that should prevent recurrences of said gremlins for some time. Odyssey is the tops providing a huge CCA, but MC Tough Max 850 should be good also. Similar offerings of the 750 CCA variety are available from a number of sources including Sears, Advance Auto, and Autozone.
Quote from: Agentlongwood on December 27, 2017, 02:59:50 PM
-13F isn't that cold. Cold is when you have to heat propane tanks just to make vapor. ;)
Quote from: SHOdded on December 27, 2017, 03:04:30 PM
Yep you cant win but the same would apply to the cover idea. Great idea but people would balk at it saying. "OMG I gotta open the cover every time..... Gawd that sucks"
IKR?
Since having the MC-650 battery replaced under warranty have the updated MC BXT-65-850 for three years now and has served me quite well considering the SHO has been my DD!!
The Motorcraft BXT-65-750 is another worthy contender since primarily offered on the PI platform with all its gadgets to protect and serve should be considered! Z
You service the battery regularly, right, Z? What is your secret routine?
Quote from: SHOdded on December 28, 2017, 08:03:26 AM
Yes sir! I believe nothing is maintenance free and will require some form of preventative maintenance and can call it my annual inspection!
I usually add roughly a pint of distilled water right before the cold winter months for good measures. Z :)
Quote from: ZSHO on December 28, 2017, 07:15:55 AM
I think daily drivers are easier on batteries than cars that are only driven a few days a month. Over the years, I've replaced very few batteries in vehicles that I drive on a consistent basis.
Quote from: SilvererSHO on December 28, 2017, 10:27:12 AM
That all depends on the driving characteristics!
I tend to drive my SHO everyday locally with frequent key on/off short trip intervals per day which can ultimately take a toll on the Battery IMO! Z
Funny all this talk of batteries, etc.
Even though I have my SHO plugged in, in the garage, went out this morning to fire her up, and dead. Dead dead dead.
Surprised, I was wondering how old my "new" Motorcraft Tough MAX BTX-65-850 battery is/was..... much to my surprise, 4.5yrs has already passed since I purchased that replacement for the factory 650 that crapped out on me, back in 2013.
Man time flies. Geezuz. Here I was hopeful I was still under the 3yr / 36 mo. warranty. Nope. No dice. Not even close. Oh well.
So I paid $119.95 back in early 2013, and was happy to have ordered (another) new one, and got away with $139.95 almost 5yrs later. So a $20 increase not to shabby.
Picking it up tomorrow.
Nice grab!
Quote from: ZSHO on December 28, 2017, 12:55:14 PM
And I do just the opposite with my daily drivers.
So, had no idea about the key fob window/moonroof thing and I just went and tried...no joy. I even tried it after doing a remote start...still no dice. When through the Synch config, never saw it in there either.
What am I missing?
Quote from: jbrown9999 on March 16, 2018, 08:20:02 PM
What am I missing?
Stock wheels ? TPMS active! Z
Actually, not stock wheels but they do have TPMS sensors in them. What does that have to do with key fob window function?
Quote from: jbrown9999 on March 16, 2018, 10:35:10 PM
If the TPMS are not functioning correctly it can cause intermittent issues with the remote features...did it ever work before? Z
Well, s***...maybe when they switched my winter tires in without activating TPMS again. I'll have to try that tomorrow.
Quote from: jbrown9999 on March 19, 2018, 11:14:44 PM
Mine did it to me without the TPMS sensors in my winter tires working (I'm the OP). I've inadvertently opened the windows and sunroof twice now.
short of letting air out of my tire to test, how can i tell if my tpms sensors are working or not?
Should have PIDs to monitor, no? Either your tuner or Torque Pro ...
Quote from: jbrown9999 on March 20, 2018, 05:39:35 PM
If you find a quiet enough place to do it (which seems to be the hardest part) you can turn on the ignition and run to one of the tires. Get down on your hands and knees and put your ear right on the tire in the location of the TPMS. You only have 3 seconds so you have to be pretty quick about it. You MIGHT have to turn the ignition on while you're on your hands and knees and then crawl to the tire if you're not quick on your feet. You'll hear short buzzes, followed by a steady buzz and then silence if they're working and short buzzes and then silence if they are not working. You never hear the steady buzz if they're not connecting.
When you get done with the diagnosis give me a call and I'll swing by to take you snipe hunting.
I got a warning message on mine.
IIRC I used Torque to figure out the location.
When I bought winter wheels I thought I might have issues since they came off a different brand car but all I had to do was swap the wheels and it worked without issue.
I should get a dashboard idiot light if it doesn't connect to the tires right? So, without that, and knowing the first time I put them on they were configured, why doesn't my damn key fob work?!
Quote from: jbrown9999 on March 21, 2018, 04:33:03 PM
Try it on another key fob! Battery up to par!
The key fob might need to be programmed. Dunno. Z
http://www.fordservicecontent.com/ford_content/catalog/accessory_files/Ford%20Programming%20Instructions.pdf (http://www.fordservicecontent.com/ford_content/catalog/accessory_files/Ford%20Programming%20Instructions.pdf)
FWIW, My dashlight stays off for 30+ miles every morning before it comes on and I know for a fact that the TPMS sensors I have on my winter tires/rims are wrong for my car. The steelie rims are off a '16? Ford Explorer Police Interceptor that I thought would be a direct match for my car but they are not. I can't remember what year but they changed them. My summer tires with working TPMS sensors are in the same garage that I park my vehicle in so that may be why the idiot light on the dash stays off for so long. It doesn't stay off that long on my commute home. I'm assuming the summer tires in the corner of my garage lose connection with my car as I'm backing away from my closing garage door so you'd think the idiot light would come on by the time I'm at the end of my driveway every morning.
Well, I never get the idiot like, which tells me my TPMS are working, but for some reason the key fob Windows down/moonroof open; does not.
That's all. I'm not super pressed but I'd like all the stuff on the car to actually work.
