Detailing, SYNC, AV, Security, Electrical, and Lighting => Exterior Modifications => Topic started by: ZSHO on February 09, 2019, 08:01:15 PM
Title: Lower Deflector!
Post by: ZSHO on February 09, 2019, 08:01:15 PM
I noticed the Front Lower Deflector located right under the Front Bumper area does not provide a sufficient seal on the bottom sides of the vehicle and acts as a cleavage instead,while letting water intrusion and such contaminants enter the Undercarriage structure of the vehicle..
Has anyone tried Sealing the small exposed sections with some (PVC) Polyvinyl Chloride type plastic material for a better overall seal!!
This was discovered while trying to remove my ALKY PUMP the other day..
The part in Question is pictured below..Thanks. Z
(https://i.imgur.com/GCI3dByh.jpg)
(https://i.imgur.com/HrM220uh.jpg)
(https://i.imgur.com/xFcqDmjh.png)
https://parts.levittownfordparts.com/oem-parts/ford-lower-deflector-ag1z8327a/?c=Zz1ib2R5JnM9cmFkaWF0b3Itc3VwcG9ydCZpPUpOMTAwMzE1JnI9NyZhPWZvcmQmbz10YXVydXMmeT0yMDEzJnQ9c2hvJmU9My01bC12Ni1nYXM%3D
Title: Re: Lower Deflector!
Post by: shaundizzle15 on February 09, 2019, 10:16:18 PM
Funny you mention this, I haven't tried to seal it however I was thinking about a one piece lower cover. Essentially something that would remove that piece and the piece that covers the oil filter etc, with one streamlined piece. Seemed like it would help aero and prevent the contamination your talking about.
Post by: ZSHO on February 10, 2019, 10:09:18 AM
I was able to obtain a PIC for reference,right under the Reservoir Tank and also Under the Drivers side there is a Good portion of the (Under cover) exposed to the Driveway Floor letting water & such contaminants enter the under carriage of the vehicle.
The point i'm trying to make is for anyone running Methanol Injection as the Meth Pump is more exposed and susceptible to water intrusion even with Condom sleeve of the pump on could ultimately lead to failure IMO!  Z
(https://i.imgur.com/gsZWjUVh.jpg)
Post by: Sabtaj1 on February 11, 2019, 05:02:47 AM
I had my meth pump mounted up inside the bumper on my flex near the washer res.  I would recommend finding a better mounting option.  I had my pumps fail twice mounted there.  Second time it happened I was tuned a little hot on e85 mix and blew 4 large holes in the block and had a whole piston just sitting on top of the PTU when I dropped the engine.  It was cute....  Maybe look into making some type of enclosure for it.  I wish I would have made something.
Post by: ZSHO on February 11, 2019, 06:49:41 AM
To Cold out now,but do have some extra PVC Plastic lying around and will put it to good use. Z   :)
Post by: autobahn terror on February 11, 2019, 07:10:57 AM
Quote from: Sabtaj1 on February 11, 2019, 05:02:47 AM
Not to revel in your misfortune or anything, but do you have some pictures of the carnage?
Post by: Sabtaj1 on February 11, 2019, 10:09:33 AM
(http://i886.photobucket.com/albums/ac68/Sabtaj1/FC79DB21-D574-4CAA-97A1-D0FC052C64A2_zpsvnbv5lnm.jpeg) (http://s886.photobucket.com/user/Sabtaj1/media/FC79DB21-D574-4CAA-97A1-D0FC052C64A2_zpsvnbv5lnm.jpeg.html)
Plus holes all over the oil pan area.  Damn thing still ran too.  LOL  was just a little shaky but you woulda thought it was a diesel with hoe much oil ended up coming out of it.
Post by: TopherSho on February 11, 2019, 10:45:52 AM
Quote from: Sabtaj1 on February 11, 2019, 10:09:33 AM
....... wwooooooowwwww.... :(
Post by: TopherSho on February 11, 2019, 10:49:25 AM
Now I HAVE to ask, who was the tuner?  PM me if you don't feel going public.  We all know that pre-DEt is bad,  but your timing must have been insanely high and did not compensate for ping when it detected it.  that is CRAZY bad levels of detonation to chuck the whole piston cap out the side...
Post by: SM105K on February 11, 2019, 11:21:47 AM
Quote from: TopherSho on February 11, 2019, 10:49:25 AM
Exactly why I refuse to use meth as secondary fuel system.  I learned my lesson many years ago with Nitrous.  Lost a fuel solenoid on a kit and ended up losing a couple of pistons.  Thank God it was just a SBE 302 with AFR Heads and a Nitrous cam, so it wasn't expensive to swap and replace the parts, it just cost me a grand because I lost the race.
Post by: ZSHO on February 11, 2019, 12:21:03 PM
I was curious if anyone can see the ^^^ PICS kindly posted by Sabtaj1! TIA.Z
I tried to restore any PB PICS!
(https://i.imgur.com/y1TxO21h.jpg)
Post by: SHOdded on February 11, 2019, 12:54:52 PM
No problems here.  PB has stopped preventing people from seeing pics, watermarking them instead.
Post by: TopherSho on February 11, 2019, 01:52:51 PM
Quote from: sm105k on February 11, 2019, 11:21:47 AM
With Brads tune I am not as concerned about sudden meth loss.  IIRC unless you have modified the spark behavior (how much to drop on knock;  how quick to drop; how fast to try to recover) the ECU should stop catastrophic damage with just meth.   With the meth i only run 4-5 degrees more timing,  if it drops octane suddenly i suspect the ECU would correct it extremely fast.  Brad would need to comment more ..
Post by: ZSHO on February 11, 2019, 02:04:22 PM
I was curious how many of you running Meth in the colder Frigid winter months!
I might start a separate Topic on this discussion! Z
Post by: SM105K on February 11, 2019, 02:31:00 PM
Quote from: TopherSho on February 11, 2019, 01:52:51 PM
After buying the intercooler, and then the Extreme HPFP down the road...the only thing that would interest me in meth is cleaning the valves.
With purchase of the GH IC and an new Extreme HPFP, would meth even be needed anymore except for the valve cleaning properties?
Post by: ZSHO on February 11, 2019, 02:48:20 PM
   :jacked: . Z   ;)
Post by: TopherSho on February 11, 2019, 05:18:59 PM
Quote from: sm105k on February 11, 2019, 02:31:00 PM
Well that's probably a preference thing .. I put in the meth before the IC was available,  and the IC has yet to be fully tested long term so i am still hesitant.  BUT for me the added octane makes a big difference along with the temp drops.  i think we will see that while the IC is great for iat2, i do not think it will outright replace meth in the 105/110f summer days at the track.  i think meth will still have a reasonable edge over just the IC on track days where your in the lanes for 20 minutes before you can run and the pavement is 135f as i have IR gunned it.
lastly for me at least i cant run e20/e30 .. i cant pump my own in my state soooo i have to trust the pump jockeys and they cant even get premium right.  if i could go e20/e25/e30 i might have considered the IC,  but as long as i live here in oregon with the lack of good e85, and not pumping my own i will stick to the meth.  but i am upgrading to a alky pump and brained lines this spring.
if you can run e25/e30 with the IC .. i do not see a reason to go meth *if* you do not have it already.
2c and all that ;)  cheers
Post by: Sabtaj1 on February 12, 2019, 01:01:51 AM
Well...  I didn't mean to thread jack.  Sorry....  Kinda my fault for pushing it.  Unleashed was doing the tuning.  I was pushing it on my own part with the meth and e85 mix.  The flex was consistent 12.0-12.1 @ 115-116mph with 1.76 60'...  I wanted 11's on stock turbos bad.  I was soooooo close.  But I dont think anyone has made it down to where I was in a flex yet.  I think it came down to the pump failing, It was a cold evening and hammered on it and within a split second, BOOM.  I blame myself.  But still recommend fabbing up a box to protect the pump no matter where you mount it.  Since I had two s*** out.  One no sleeve (snow) other with a sleeve (devils own) and neither backed their product.
Post by: TopherSho on February 13, 2019, 10:06:05 AM
Quote from: Sabtaj1 on February 12, 2019, 01:01:51 AM
Holy hell.. 1.76/12.1 in that brick!  Yeah your on the bleeding edge of power-handling.  wowzers!
