Ecoboost Performance => Ecoboost Tuning! => Datalogging and Gauges => Topic started by: StealBlueSho on October 12, 2018, 09:15:35 AM
Title: LMS TouchScreen MyCalibrator PIDS List as 10/20/2018 *UPDATED
Post by: StealBlueSho on October 12, 2018, 09:15:35 AM
Here is the full list of PIDS available via the LMS TouchScreen MyCalibrator. These I am sure will be updated as the product matures. Some of these pids show up as Not Supported when trying to use them. I had to pull these off the touchscreen device by hand as the software doesn't list them on the computer.
Note: There are NO units associated with any of these PIDS.
NOTE: ANY HELP DECODING THESE WOULD BE APPRECIATED! I WILL UPDATE THEM AS I FIGURE THEM ALL OUT
Airflow
   -MAF
   -MAF_Khz
   -MAF_Vlt
   -BP- Barometric Pressure - inHG
   -MAP - Manifold Absolute Pressure - ADC (Analog to DC counts at 10 bit conversation)
   -BP - Baro Pressure - inHG
   -Wastegate_DC - Percentage
Fuel
   -Rear_02_Corr_B1
   -Rear_02_Corr_B2
   -Rear_02_Err_B1
   -Rear_02_Err_B2
   -AFR_Matured
   -Clsd_Loop_Fuel
   -DSD_Lamba - Desired Lambda
   -FRP 1 - FRP Desired in PSI
   -FRP 2
   -Injection_Timing
   -Act_Lambda_B1 - Actual Lambda Bank 1
   -Act_Lambda_B2 - Actual Lambda Bank 2
   -Lambda_B1 - Not Supported
   -Lambda_B2 - Not Supported
   -LTFT_B1 - Long Term Fuel Trim bank 1 in decimal format.
   -LTFT_B2 - Long Term Fuel Trim bank 2 in decimal format
   -Pulsewidth
   -STFT_B1 - Short Term Fuel Trim bank 1 in decimal format
   -STFT_B2 - Short Term Fuel Trim bank 2 in decimal format
   -Open_Loop_Fuel
   -FRP_Absolute - Actual FRP in PSI
   -FRP_G
   -Fuel_Level - Fuel level in percentage
   -PM
Misc
   -Engine_Torque
   -Torque_Source
   -MIL_Light_Is_On
   -LOAD - Load in WHOLE numbers.. 0, 1, 2 etc..
   -Run_Time - How long the calibrator has been on
RPM/SPEED
   -DSD_RPM - Disired RPM
   -Output_Shaft_Spd - OSS Speed
   -RPM - Do I really need to tell you this one?
Spark
   -KnkSen1_Cnts - Raw noise data from Knock sensor bank 1
   -KnkSen2_Cnts - Raw noise data from knock sensor bank 2
   -Lrnd_knk_Mod - Not sure?
   -KnKAdder - Timing corrections based on knock sensor feedbacks
   -Oct_Adjust - Reads 0 all the time?
   -Spark 1
   -Spark 2
   -Spark 3
   -Spark 4
Temp
   -Cat_Temp_B1
   -Cat_Temp_B2
        -ACT
   -ACT2 - Temps from Manifold in F
   -CHT_Temp
   -ECT 1
   -ECT 2
   -ACT2
ETC
   -Act_Thrt_Ang
   -Dsrd_Thrt_Ang
   -Pedal_Pos
   -Rel_ Pedal_Pos
   -TPS
Trans
   -Lockup_Status
   -Output_Shaft_Spd
   -Prk-Neu_Sense
   -Spd-Ratio
   -Turbine_Spd
        -New-Dr_Status
   -Conv_DC
   -Slip_Across_Conv
   -Conv_Current
   -Ovrshoot_RPM
   -Shift_Flare_RPM
        -Shift_Lag_Time
   -Shift_Slip_Time
   -Shift_Sol_A_DC
   -Shift_Sol_B_DC
   -Shift_Sol_C_DC
   -Shift_Sol_D_DC
   -Shift_Sol_E_DC
   -Solenoid_E_DC
   -Cur_Trans_Ratio
   -Gear_Commanded
   -Shift_ID
   -Shift_Type
   -Tap_Down
   -Tap_Up
VCT
   -Ds_ExhCam_Pos
   -Ds-ExhCam_B1
   -Ds_IntCam_B1
   -Ds_IntCam_Pos
   -ExCam_Pos_B1
   -Exhcam_Ang_B2
   -ExhCam_Err_B1
   -ExhCam_Err_B2
   -IntCam_Ang_B2
   -IntCam_DC_B1
   -IntCam_DC_B2
   -IntCam_Err_B1
   -IntCam_Err_B2
   -IntCam_Pos_B1
Title: Re: LMS TouchScreen MyCalibrator PIDS List as 10/12/2018
Post by: SHOdded on October 12, 2018, 09:41:18 AM
Wonder if PIDs are specific to the vehicle or for multiple models.
Post by: StealBlueSho on October 12, 2018, 09:42:07 AM
Quote from: SHOdded on October 12, 2018, 09:41:18 AM
Based on the amount of PIDS are comeback as unsupported I would say Multiple Models.
Post by: lamrith on October 12, 2018, 11:47:38 AM
I just cannot get this out of my head this morning.
Sorry, could not resist.  Awesome work SBS, you are all over it!
Post by: StealBlueSho on October 12, 2018, 02:15:51 PM
Just got off the phone with LMS, they are looking into a few things I mentioned not making sense. Will update...
1: The MAP PID doesn't appear to be displaying boost correctly.
2: No way to monitor ignition correction via the knock sensors.
There are others but baby steps.
Post by: Livernois Motorsports on October 12, 2018, 03:13:18 PM
Just to update everyone we are still developing new things for this tuner with the features and the datalogging aspect was meant to be a future thing and not perfect yet as we are still releasing and adjusting things to this, with every version update on the tuners we are slowly adding things but they do take time and we will be adding these as soon as we can as an update for you all!
Post by: StealBlueSho on October 12, 2018, 03:43:29 PM
Quote from: Livernois Motorsports on October 12, 2018, 03:13:18 PM
Awesome! Just trying to make heads and tails of the new tech. Thank you for the support. I was hoping to consolidate down my devices into this one device.
I think the datalogging is more secondary to having accurate and readable gauges.
Post by: StealBlueSho on October 16, 2018, 06:05:44 PM
Updates some more information on the PIDs.. particularly LOAD which is in whole numbers.. needs to be in hundredths to make sense...
I am hoping LMS comes out with an update for this soon............
Post by: StealBlueSho on October 20, 2018, 03:16:04 PM
LMS did a major update to the PIDS... removed A TON of PIDS that did were not supported and added some important ones..
We can now monitor Short and Long term fuel trims and timing corrections based on knock feed back.. (Knock in SCT land)..
So the vitals are JUST about there... STFT, LTFT, Knock Corrections, Temps, etc... I did notice they removed the boost desired which sucks.. or they moved it.. still playing around...
I still have not deciphered MAP... maybe LIVERNOIS can help with that one...
Happy to see improvements..
Title: Re: LMS TouchScreen MyCalibrator PIDS List as 10/20/2018 *UPDATED
Post by: StealBlueSho on October 20, 2018, 08:00:45 PM
Updated new available PID list as of 10/20/2018 - I would say this is a major revamp.
Post by: StealBlueSho on October 21, 2018, 09:25:41 AM
Sooo with a tip off from Matt Robinson at Gearhead I finally was able to figure out the MAP PID to calculate boost...
The data being seen IS the analog to digital counts based on the 10 bits equation...essentially...
You use a 10bit ADC to voltage calculator (knowing that a 3bar goes up to approx 4.999v at peak) to calculate a 10bit ADC number to volts..
Then you take the volts output and calculate that to PSI based on the following formula I dug up from an old GM website..
(V*8.94)-14.7.. that gives you psig number... Which then tells you how much boost you are running.... easy to do on the fly while driving right?!
Example:
Say your MAP sensor is reading 660 on the LMS device... you take that number and plug it into the following calculator..
http://www.learningaboutelectronics.com/Articles/Analog-to-digital-conversion-ADC-calculator.php (http://www.learningaboutelectronics.com/Articles/Analog-to-digital-conversion-ADC-calculator.php)
Make sure to use 10bits as the reference range, and 4.999 for the total voltage supplied...
The calc spits out 3.225..
Then you use the GM formula to get the PSIG... so (3.225*8.94)-14.7 = 14.1psi
Of course this is a rough number given you are subtracting theoretical sea level of 14.7psi in air... it does not take into account the barometer so its not accurate.
OOOOORRRRRRR Livernois could be super nice and provide us a Boost in PSI PID so we don't need to do rough calculations in our heads while driving lol.
Post by: bpd1151 on October 21, 2018, 10:45:02 AM
Poking a lil fun here.......
After reading over your lengthy dissertation and all those back n forth criss crossing numbers, factors, equations, and blah blah blah, oh my goodness it's quite obvious for everyone to see BJ, that you LLLOOVVVVEEEEEEE playing with numbers.
That said, why in the hell would LMS want to take all that fun away from you, by making it easy for 'ya????
Whether stationary, or on the fly?????
Bwahahahahahaha :poke:
Post by: StealBlueSho on October 21, 2018, 10:59:38 AM
Quote from: bpd1151 on October 21, 2018, 10:45:02 AM
You are 100% correct in that I genuinely enjoy working with numbers, always have! Instead of paying for adult magazine subscriptions I pay subscriptions for science journals....
Right now I am currently working on machine learning and deep learning algorithms (linear algebra, calculus, and probability matrices, etc etc) so I can better support my customer base who have a need to utilize machine learning etc etc...
I digress... the intent behind all of this is multi pointed...
1: LMS no longer sells the old MyCalibrator (but still very much supported) so the forum is going to start at some point getting pinged for information. Look at all the questions surrounding SCT stuff and it's pretty straight forward... so this will be a good starting point for customers of LMS who purchased this tuner.
2: I know LMS monitors this post, and instead of emailing them constantly, they can get an idea of what people are going to be looking for in their device. If they are going to compete, they are going to need real world data on what people want. This will help with that. It's quite clear they are developing this in house, and it's going to take time to refine it...
If LMS doesn't want me to post this information I'm sure they would have called me by now.
Post by: bpd1151 on October 21, 2018, 11:04:29 AM
BJ, you do realize I prefaced my post with "poking a little fun here" right?
If I didn't like you, I wouldn't bust your balls.
Yes you've been overly technical and helpful. I'm poking fun so you don't blow a personal gasket.
Love you buddy. Breathe. Relax. Happy (belated) sweetest day there schnookums.
Post by: ZSHO on October 21, 2018, 04:45:11 PM
I think LMS should utilize SBS Resources and Fount of knowledge with there newly released MY Cal.  Z   :)
Post by: StealBlueSho on October 21, 2018, 04:51:43 PM
Quote from: ZSHO on October 21, 2018, 04:45:11 PM
Nah, I doubt they need it, more valuable from a end user experience reference than a technical one. LoL!
Post by: SHOdded on October 21, 2018, 04:52:14 PM
Always good to have independent analysis.  That is why there is something called "feedback" :D
Post by: Chaplain on December 08, 2018, 12:39:53 AM
I just want to see boost and temp gauges.
Post by: StealBlueSho on December 08, 2018, 05:39:47 AM
Quote from: Chaplain on December 08, 2018, 12:39:53 AM
There are temps and boost. Just can't read the boost since the units aren't labeled.
