Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: irondoor19 on February 19, 2019, 06:37:02 PM
Title: Torque converter is Bad, Pump cracked
Post by: irondoor19 on February 19, 2019, 06:37:02 PM
s*** SHO again,  YEA I have been absent...
At the dealer getting the oil leak fixed, (under warranty)
Lo and behold the torque converter is junk and
pump has a crack in it...can not catch a break,
Time for a trans and converter upgrade....! ..?
Title: Re: Torque converter is Bad, Pump cracked
Post by: bpd1151 on February 19, 2019, 07:55:56 PM
You've by far, had the worse luck that I can readily recall with this platform.
Goodness.
Post by: AJP turbo on February 19, 2019, 08:31:21 PM
Quote from: bpd1151 on February 19, 2019, 07:55:56 PM
Goodness.
Well irondoor or that one younger guy with the flex or maybe even topher!
Well that sucks
Post by: TopherSho on February 19, 2019, 10:20:23 PM
Quote from: AJP turbo on February 19, 2019, 08:31:21 PM
Goodness.
Well that sucks
Ooh ooh!  I haven't broke that yet! .. (yet...)
Tough break... i know how it feels sir..  when it runs great its *amazing* .. but dammit it keeps breaking!
Post by: SHOdded on February 20, 2019, 01:30:39 AM
Racing puts stress on stuff :)  Where is the oil leak coming from?  Turbos, feed lines, ...?
Yeah the TCs have been saying goodbye.  I think the 6F50 and 55 share the same part number for 2010-12 MYs!  Dunno if that means the innards are the same.
Converter Assy Select vehicle options to narrow down result
Ford 9E9Z-7902-B    Production Date: 06/2009-02/2012
9E9Z-7902-B
Converter Assy
184K
Base Number:   7902
Callout Name:   7902
Replaced by:   9E9Z-7902-BRM
$282.55$264.96
Ford AA5Z-7902-A   Production Date: 06/2009-05/2010
AA5Z-7902-A
Converter Assy
4 Bolt Converter
Base Number:   7902
Callout Name:   7902
Replaced by:   AA5Z-7902-ARM
$420.48$360.13
AA5Z-7902-ARM  Production Date: 06/2009-05/2010
Converter Assy
Remanufactured
Callout Name:   7902
$420.48$360.13
So far the only real upgrade is a) fluid and b) the Sonax Zip Kit  Plenty of pie in the sky promises if you are inclined to believe them.
Post by: irondoor19 on February 20, 2019, 10:36:10 AM
Quote from: SHOdded on February 20, 2019, 01:30:39 AM
Oil Leak is from the timing cover, so that was from day one of the engine install, the
dealer has been wonderful, up until the list of additional items they want to sell me,
along with the warranty issue. Turbos are fine, And after all that, my head is spinning...
Post by: StealBlueSho on February 20, 2019, 06:04:20 PM
Quote from: irondoor19 on February 20, 2019, 10:36:10 AM
Circle D has a slightly upgraded TC and Matt Robinson has a billet upgrade coming out in 8-10 weeks? You would need to email him...
Post by: SHOdded on February 20, 2019, 07:46:57 PM
The Circle D will not help your 1/4 mile times, but no idea on the beating it can take.
Curious to see what Gearhead produces for the TC.  This will be a "moving" part, so fingers crossed it works out.
Post by: StealBlueSho on February 20, 2019, 07:58:53 PM
Quote from: SHOdded on February 20, 2019, 07:46:57 PM
Matt said a Billet Multi Disc Torque Converter and better coupled at WOT so the converter has to do less working... according to him.. 6-8 weeks out... should be strong enough to hold well over 500hp I am assuming..
Post by: 802SHO on February 20, 2019, 09:08:49 PM
Quote from: StealBlueSho on February 20, 2019, 07:58:53 PM
Man this just keeps getting better and better!  Matt Robinson to the rescue again!
Post by: bpd1151 on February 20, 2019, 09:15:26 PM
Quote from: 802SHO on February 20, 2019, 09:08:49 PMMan this just keeps getting better and better!  Matt Robinson to the rescue again!
It is refreshing to see another vendor stepping up and fabricating product for the platform, and picking up the torch so to speak, where other vendors may have left off.
Odd to wrap my head around the fact that my SHO is 9yrs old, and that an IC upgrade has just now recently been released.
Kudos indeed.
Post by: abs on February 20, 2019, 10:38:04 PM
The 6F55 torque converter mounts the flywheel with 4 bolts and the 6F50 torque converter has only 3.  The parts are definitely different.  There was also some reference by Ford to number of internal modifications of the 6F55 torque converter.  If you are going to install a new one, make sure you get the right part.  Also, these converters are designed to have some allowed "slip" during torque converter clutch lockup and they use a specialty carbon fiber material to allow this.  Apparently the material was first developed by GM and then, I assume, Ford got access to it as part of the collaboration on the transmission design between the 6T70/75 and the 6F50/55.  So, be careful to make sure that any aftermarket converter has the proper type of clutch material available . . .
Post by: SHOdded on February 21, 2019, 01:39:23 AM
What year torque converter are you referring to, abs?  Is the difference present in all MYs of the SHO?
Post by: irondoor19 on February 22, 2019, 03:10:00 PM
And a pic from the top of the converter looking at the destroyed Ring
Bottom Ring supposed to be completely gone, will drain and take a pic next Week
Post by: irondoor19 on March 08, 2019, 12:25:08 PM
Well it's not the pump correct the gear inside the tranny and who knows What else.. so new rebuild remanufactured tranny  from
XP...Damn my life sucks
Post by: SM105K on March 08, 2019, 12:44:13 PM
Quote from: irondoor19 on March 08, 2019, 12:25:08 PM
What is the warranty look like on one of those XP units?
Post by: SHOdded on March 08, 2019, 06:49:03 PM
:o :(
Post by: irondoor19 on March 08, 2019, 11:39:23 PM
Quote from: sm105k on March 08, 2019, 12:44:13 PM
Real good full write up with pics tomorrow...!
OK so much stuff going on that i will turn this into a few threads:
Transmission
New Intercooler
and why i hate my life...! all with Pics
