I was getting a startup tick and thought it was my chain...
Amazing it wasn't louder and went away after startup.
Don't see those busted too often, must be all the power you are forcing through there :D
Glad it was a simple fix.
Still a PITA to take everything apart on jack stands.
I wonder if it was bad enough to throw off my fuel trims.
Under hood heat also started to become a problem.
Quote from: Gray Brick on May 18, 2019, 11:23:01 AM
Did you reuse the gasket when you swapped the turbos? That could have caused that problem...always best to replace gaskets that are in very high heat area's when swapping parts.
The very reason I aways recommend to change the Gaskets especially being close to 500 deg exhaust heat!
Definitely would of thrown your Fuel trims off!
Glad you caught in time. Z
I changed all gaskets when the turbos were replaced.
I am assuming the bolts from the turbo to the manifold became loose and created a small leak that became larger and larger.
Yes, that could very well be true. Just like Ford says with wheels, checking the bolts a couple hundred miles after install is a must. Dunno if loctite would have helped any.
Bit of RTV Sealant goes a long way. Z
https://www.amazon.com/Permatex-81158-Silicone-Adhesive-Sealant/dp/B000AL6WLA/ref=sr_1_3?keywords=black+silicone+sealant&qid=1558388585&s=gateway&sr=8-3 (https://www.amazon.com/Permatex-81158-Silicone-Adhesive-Sealant/dp/B000AL6WLA/ref=sr_1_3?keywords=black+silicone+sealant&qid=1558388585&s=gateway&sr=8-3)
No sealant necessary on this one...
The factory gaskets are double wall crush type.
Hmm! Here are mine! Z
(https://i.imgur.com/6UwBEPzh.jpg)
