Sure why not. If you have two values and you are watching the increase/difference between the two readings, I thought it would be easier to have the gauge do the arithmetic. In my case I wanted to see the total heat gained by ambient air as it went through the process of being delivered to the intake manifold so I used the sensors at each extreme. I'm sure it would work just as well using the values of the two middle sensors.
