Ecoboost Performance => How To Articles => Topic started by: EcoPowerParts on July 31, 2013, 05:28:50 PM
Title: "How- To" SCT Livelink datalog
Post by: EcoPowerParts on July 31, 2013, 05:28:50 PM
Originally posted by CoreyMS
IF YOUR NOT DATALOGGING, HOW DO YOU KNOW YOUR ECOBOOST VEHICLE IS RUNNING RIGHT?
I get a lot of questions about this and it's time everyone knows how. Datalogging via the SCT Livelink program is pretty straight forward. It has a guide me function that shows you what to do, but once you've done it a couple times you realize it's not hard. This first post will show how to setup the datalogging via a laptop connected in the vehicle. I generally do not follow the guide me functions, it is just redundant.
To start, download SCT Livelink Gen II
http://www.sctflash.com/software/LiveLink_GenII.exe (http://www.sctflash.com/software/LiveLink_GenII.exe)
Some functions can be done with the X3/SF3 connected to the computer without the vehicle, we will continue to that later.
So, you have your laptop connected via USB cable to the SCT device and the SCT device connected to your OBD-II port. Lets try to connect it. Turn the key on, OR start the vehicle.
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/comm_zps60910505.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/comm_zps60910505.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/checkcommunication_zpsd917dbc5.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/checkcommunication_zpsd917dbc5.jpg)
Click "check communications". Once it connects it should look like that.
IF you are having a problem communicating disconnect everything, the SCT from the truck, the USB from the computer and the SCT, then reconnect it all and try again.
Also, in bad cases you may need to restart your computer. The drivers should install when you connect it. If you can update your tunes via "SCT Device Updater" then you should have all the drivers.
Once you get communications, Click "Vehicle Info"
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/vehicleinfo_zps037210f4.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/vehicleinfo_zps037210f4.jpg)
If this is your first time, "Validate all PID's". Then "Select Items".
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/validateall_zps6f0ba7d0.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/validateall_zps6f0ba7d0.jpg)
Since we are limited here on how many pictures per thread, multiple posts will be needed.
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems_zpsa86e52fd.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems_zpsa86e52fd.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems2_zps29b0b11b.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems2_zps29b0b11b.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems3_zps63b0a76a.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems3_zps63b0a76a.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems4_zps44da1a48.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems4_zps44da1a48.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems5_zps0566f515.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems5_zps0566f515.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems6_zps88da4e8b.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems6_zps88da4e8b.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems7_zps4e960b64.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems7_zps4e960b64.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems8_zpsb0381592.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/selectitems8_zpsb0381592.jpg)
Now you select your items to log.
I have created a configuration file to make this easy, we will get to that soon.
Next, click "Configure Datalog"
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/configure_zpse000be85.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/configure_zpse000be85.jpg)
The logging screen will come up. To start logging click the "start" button.
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/start_zps45dffaa3.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/start_zps45dffaa3.jpg)
To "Stop"
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/stop_zpscb616d76.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/stop_zpscb616d76.jpg)
If you start a second one, it will prompt you to save your datalog. Alternatively, you can click the file tab top left and go to save as, and select datalog.
__________________________________________________ __________________________________________________ ____________________
For ease of having to select your parameters I have created this Configuration file.
https://dl.dropboxusercontent.com/u/28632738/DLFConfig.cf4 (https://dl.dropboxusercontent.com/u/28632738/DLFConfig.cf4)
To load a configuration file,
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/loadconfig_zpsc15e6834.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/loadconfig_zpsc15e6834.jpg)
If it asks to merge this configuration with what is already selected click no.
Now, what if you don't have a laptop but you still want to datalog. The X3/SF3 has this ability, but the normal files that come with it are worthless on the Eco. Bring your device to your computer and load Livelink. You will need to load this configuration file, just as before. The difference is to be able to do this on device, the max number of parameters is 20. So I made a different configuration for you.
Load this configuration. Now, we need to Export a DLF file to our device.
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/saveDLF_zps78b1a051.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/saveDLF_zps78b1a051.jpg)
(http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/DLFexport_zps80ffc5eb.jpg) (http://i24.photobucket.com/albums/c6/whtranger/HOWTO%20DATALOG/DLFexport_zps80ffc5eb.jpg)
Now you should be able to use the device alone to datalog, then return to the computer and Import the data, button just under export DLF.
Title: Re: "How- To" SCT Livelink datalog
Post by: Needmoreboost on July 31, 2013, 08:15:18 PM
Thanks for this as I owe Torrie some logs.  Don't bother logging with just the device as the data is useless.  fyi
Might get on this now.   :bow:
Post by: painterpatt on August 03, 2013, 02:54:15 PM
You have to use laptop to get load dont you. I'm getting knock under med accel. And Torrie couldnt read the email from sct
Post by: painterpatt on August 03, 2013, 04:47:55 PM
And how do I do that ? New to this datalog stuff sorry
Post by: breeves002 on August 06, 2013, 11:18:25 PM
Thanks for posting this! I am getting my SCT X3 tomorrow and am excited to use these great features :)
Post by: Needmoreboost on August 07, 2013, 09:39:35 AM
Pretty important step for everyone running tunes.  Any tune emailed to you originally is a CANNED tune.  FYI
Post by: melc on October 28, 2013, 03:59:47 PM
Quote from: Needmoreboost on August 07, 2013, 09:39:35 AMIF YOUR NOT DATALOGGING, HOW DO YOU KNOW YOUR ECOBOOST VEHICLE IS RUNNING RIGHT?
Very good point!! I have the following questions I am hoping to get help on.
- Is there a site that will help me understand what these PID readings mean? Example on my datalog would be a Knock Sensor reading range of -.025 to 0.75 (Good, Bad??) or a Spark Advance reading range of 3.5 - 47.5.
- Which PID are vital to datalog?
I just recently installed Torrie's W/M kit and get some logging done for him but I am really curious what my vehicle is telling me in those logs.
Thanks,
Post by: EcoBrick Bob on October 28, 2013, 07:55:14 PM
I have been datalogging since 2010 and the new LiveLink II is by far the LEAST friendly of all the SCT logging software.  The only advantage it has is that you can log more than 18 parameters at a time.  The descriptions of the actual parameters are different than the earlier "easy to understand" names.  These new LLII names are all based on specific formulas.  Also, it won't allow me to add an analog item or more (A/F from my wide-band Innovate) when I used it with my G8.  Talked with the SCT programmer who developed this back in early August and she was also surprised.  Agreed there are lots of "bugs" to work out.  I went back to LiveLink 6.5 which I find easier to use.  However all Livelink versions have their issues...
Post by: FiveLeeter918 on June 02, 2017, 04:07:12 PM
Hey Mike, sorry for bringing back the dead, but do you still have these config files available? The DB link seems to be dead.
Post by: sho in pdx on July 26, 2017, 01:53:08 AM
Can I get that config file as well?
