Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: elund126 on June 27, 2020, 03:41:07 PM
Title: AC Compressor pulley replacement
Post by: elund126 on June 27, 2020, 03:41:07 PM
I gave my daughter my 2010 Taurus SHO. I noticed that the AC Compressor pulley was wobbling when the AC engaged and was making some crazy loud noises. Ordered new parts, that arrived earlier this week. I went out to start the car this morning and the motor would not turn over, the starter just clicked and stopped. It was not low voltage. Took the serpentine belt off and confirmed I could turn the crankshaft pulley manually. Started the car no problem without the belt. I also noticed that the AC compressor pulley has seized, which was preventing the engine from turning over. I am trying to remove the AC compressor pulley, but, am having a hard time getting to the bolt. Has anyone successfully changed out the AC compressor pulley? How the heck did you get to the bolt? Thanks in advance.
Title: Re: AC Compressor pulley replacement
Post by: 6500rpm on June 28, 2020, 12:10:32 PM
I'd make sure that  the compressor itself isn't  locked. If it is, make sure there's  no metal in the system before  putting a new compressor on.
Post by: Macgyver on June 28, 2020, 02:56:00 PM
You need a new compressor. Only way to do it right. Odds are it is smoked.
Post by: elund126 on September 28, 2020, 02:17:28 PM
I ended up replacing the entire compressor with a reman unit. I also replaced the belt. I ended up buying the A/C manifold gauges from Harbor Freight and got the system all pressurized and filled with coolant (and compressor oil!!). It wasn't too bad of a job, the hardest part was putting the belt back on!
Post by: Macgyver on September 28, 2020, 04:29:11 PM
Quote from: elund126 on September 28, 2020, 02:17:28 PM
You didnt have to apply a vacuum to it before adding the refrigerant and oil ?
