Manufacturer Communication Number: SSM 47662
Summary
For 2010-2019 vehicles equipped with turbocharged engines, when diagnosing and/or replacing turbo related concerns, all steps within the Workshop Manual (WSM) procedure must be followed including replacement of all mandatory discarded parts. For all turbocharged engine applications, the turbocharger oil supply filter (6C683 gas engine/6L625 connector style or 6A968 diesel engine) must be replaced whenever the turbocharger or the turbocharger oil supply tube are replaced. Turbocharger bearing failure may occur if oil starvation occurs due to a restricted filter.
MAKE MODEL YEAR
FORD EDGE 2012-2019
FORD ESCAPE 2013-2019
FORD EXPEDITION 2015-2017
FORD EXPLORER 2011-2019
FORD F-150 2015-2019
FORD F-650 SD 2017-2019
FORD F-750 SD 2017-2019
FORD FLEX 2010-2019
FORD FOCUS 2013-2018
FORD FUSION 2013-2019
FORD MUSTANG 2015-2019
FORD TAURUS 2010-2019
FORD TRANSIT 2015-2019
LINCOLN CONTINENTAL 2017-2019
LINCOLN MKC 2015-2019
LINCOLN MKS 2010-2016
LINCOLN MKT 2010-2019
LINCOLN MKX 2012-2014, 2016-2019
LINCOLN MKZ 2013-2019
LINCOLN NAVIGATOR 2015-2017
There's a turbo filter?
There are screens in the oil and MAYBE the coolant lines feeding the turbos.
How often should you be looking at these filters?
only when turbo replacement is required, or you find debris in the oil.
Quote from: Gjkrisa on March 26, 2019, 10:34:08 AM
Filters- X2 .
$27.34 NEW OEM TURBOCHARGER FILTER 3.5L V6 FORD LINCOLN
AA5Z-6C683-A .Z
https://www.ebay.com/itm/BRAND-NEW-OEM-TURBOCHARGER-FILTER-3-5L-V6-FORD-LINCOLN-AA5Z-6C683-A/362555418386?hash=item5469fca712:g:L3UAAOSwxbFcYl5g (https://www.ebay.com/itm/BRAND-NEW-OEM-TURBOCHARGER-FILTER-3-5L-V6-FORD-LINCOLN-AA5Z-6C683-A/362555418386?hash=item5469fca712:g:L3UAAOSwxbFcYl5g)
(https://i.imgur.com/sAyXGTj.jpg)
