Just curious to see what everyone is doing.
I am running a 2.5g tank and I mix
1 gallon of straight meth with 1.5g of boost juice.
100% meth
Quote from: FLEXXX on June 05, 2019, 10:21:36 AM
What does the boost juice do I thought that was meth that they just gave a name
Quote from: Gjkrisa on June 05, 2019, 11:21:36 AM
Boost Juice is premixed Methanol with water, 50/50 I believe but not sure.
https://www.snowperformance.net/Snow-Performance-Boost-Juice-p/sno-40008.htm (https://www.snowperformance.net/Snow-Performance-Boost-Juice-p/sno-40008.htm)
SNOW PERFORMANCE BOOST JUICEā¢ 50/50 HIGH PERFORMANCE WATER-METHANOL FLUID
I run 100% meth.
Why? because i am trunk mounted and stupidly used the 1/8 line ... so my pump fights a narrow delivery line with tons of resistance over length so mixing would reduce the amount of meth delivered in addition to the limited amount i get now.
if i were under he hood mounted i'd probably go 1/2 boost juice and 1/2 pure meth ..
eventually i will go with 1/4 braided line, nozzles etc for a trunk mount system.. but if i spend that money now my wife will MURDER ME ...
100% meth with alky controls kit with AJP 93+meth tune and a M5 nozzle. the LMS kit (alky) comes with a M15 nozzle.
Alky Controls kit mounted all under the hood with a Snow 375ml hyper-sonic nozzle with 100% meth. Seemed easier than running lines all over the car and I don't have to mix anything.
cool to see the reply's
I have considered moving the tank and pump under hood, I am waiting to see what I do with the intercooler before I do move it as I might go with a water to air set up and will need the room.
50/50 snow performance boost juice. I don't use it for power, but rather to help IATs, it also happens to work well as washer fluid since that is what I use as my tank.
