Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => PCV/Catch Cans => Topic started by: TimmyATL on January 07, 2019, 10:50:41 AM
Title: High flow PCV valve. UPR
Post by: TimmyATL on January 07, 2019, 10:50:41 AM
I see that UPR uses check valves in their catch can set up for the 10-14 SHO. They give a option of a high flow PCV valve. Is this advised to install for best results? Is itjust a hogged out connector? Or just stick with the factory PCV valve. Thanks for all your input. I
Title: Re: High flow PCV valve. UPR
Post by: SM105K on January 07, 2019, 11:01:16 AM
I stuck with the factory PCV, it works great with UPR's catch can.
Post by: 802SHO on January 07, 2019, 01:58:11 PM
I upgraded my check valve to the billet pro series check valve after talking with one of UPR's reps.  I asked about the difference in check valves and he said the check valve that comes with the kit works great but since I make multiple trips to the track and drive the car so hard and often he recommended I upgrade due to the extened operating time under WOT and boost pressure being over 16psi.  You simply swap it out with the original check valve and its roughly $40.
