Bought a dud used 2010 SHO that had a blown turbo, then dropped a ring into the pan after 1000 miles, ended up putting a brand new set of turbos on and ordering a brand new Ford long block and had a bud with a shop throw everything together now everything runs great but am still curious if it has the new valve covers installed. I called the dealership I ordered the long block from and they said they had no clue. Is there a visual difference from the original valve cover and the updated one? or will I have to just have to order the new valve cover and figure it out myself?
AA5Z-6582-E was the replacement part number.
TSB https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79067.html#msg79067 (https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79067.html#msg79067)
Do you know if theres a visual difference I can spot without removing the valve cover?
They probably changed the baffling, so changes would be on the inside. MIGHT be a part number on the outside but from the looks of these pics it is on the inside ...
Quote from: SHOdded on July 12, 2019, 12:04:13 AM
That's what I thought too.
bummer.
