Quote from: 4sfed on January 04, 2019, 09:57:37 AM
Quote from: sm105k on January 04, 2019, 09:42:02 AM
So for everyone else... Which is better 500 cfm @ 3 psi or 500 cfm @ 10 psi?
First off, I love multiple choice!
Second, this gauge seems pretty cool.
Third, if better = more horsepower, I'll go with 500 cfm @ 10 psi.
It's a trick question.....both theoretically should make the same HP if atmospheric conditions are the same.
However, if the turbo that makes 500 cfm @ 3 psi is turned up to 9 psi.... we can assume it should produce more then 1000 cfm if not more. That is called turbo efficiency.
We can quickly go down the rabbit hole about boost psi (remember that it is a measurement of restriction). More boost usually means more heat, more compressor surge, more back pressure, higher IAT's ect. Sometimes more isn't better, esp if you are operating outside of the compressor map. The small turbos on our SHO's I believe are a bit undersized. However, they do work well in the bottom and mid range great. I think twin 58 mm turbos would be awesome on these cars.
However, it is widely accepted that more volume (cfm) with less boost pressure is better.
