Racing Department => Dyno Results => Topic started by: scott320 on January 13, 2015, 04:20:28 PM
Title: Tablets for Data logging
Post by: scott320 on January 13, 2015, 04:20:28 PM
 So I want to mount a tablet in my SHO for torque pro data logging .  I found a cheap Netbook tablet at walmart. It has the google play store, so getting the torque pro app should be easy.  Just wondering if the tablet choice is important to set this up i my car?  Any help will be great.
http://www.walmart.com/ip/Nextbook-7-Tablet-16GB-Quad-Core/38334381 (http://www.walmart.com/ip/Nextbook-7-Tablet-16GB-Quad-Core/38334381)
Title: Re: Tablets for Data logging
Post by: SHOnUup on January 13, 2015, 04:26:08 PM
I have a pretty basic tablet, Samsung Tab2. Does great, little rough to read on certain light angles. Not to bad having tint all the way around. If I was to upgrade it'd be one with glare blocker. But see no need to.
Rich
Post by: SHOdded on January 13, 2015, 06:20:46 PM
Seems to have decent specs with the latest wifi & bluetooth & OS version.  Should work.
Nextbook NX700QC16G with WiFi 7" Touchscreen Tablet PC:
Technical Specifications:
    Android 4.4 (Kit Kat) OS
    1.6GHz MediaTek MT8127 ARM Cortex-A7 Quad-Core processor
    Nextbook 7" Tablet has 1GB DDR3 of system memory
    7.0" touchscreen, 1024 x 600 resolution
    option to expand via microSD slot to 64GB more
    16GB quad-core tablet has a built-in 802.11b/g/n WiFi and Bluetooth v4.0
Post by: jtoddk98 on March 04, 2015, 12:15:11 PM
Quote from: scott320 on January 13, 2015, 04:20:28 PM
I bought a Moto G on eBay for $38, mounted it to a Garmin suction cup and put it on the top of my windshield on top of the rear view mirror. I got a 12ft USB cable on Amazon for $6 and wired it through the headliner, down the driver side a pillar, down the dash, and into the console where I have a little 2port usb charger that plugs into the 12v outlet, The phone draws so little power so I'm not worried about it draining the battery.
Post by: Gray Brick on March 05, 2015, 01:53:31 AM
Got any pics of this setup?
Post by: jtoddk98 on March 05, 2015, 08:14:44 AM
Here's one from when I had an older android phone. I was able to put the Moto g higher up so it doesn't block the rear view mirror because the charge port is on the bottom, not on the side like this old phone. Have my 9500ix handing from the rear view mirror post
Post by: SHOdded on March 05, 2015, 08:54:55 AM
Looks great :thumb:
Post by: BigB15 on May 20, 2015, 11:39:36 PM
I have a HP Stream 7" , on suction mount .
Running Dash Commander
and a BT OBD device
Post by: FoMoCoSHO on May 20, 2015, 11:58:10 PM
Galaxy Pro 8.4 running DashCommand which is lightening fast on this tablet
Post by: f8tlSHO on November 16, 2015, 12:56:14 PM
Quote from: FoMoCoSHO on May 20, 2015, 11:58:10 PM
Is dash command a good program to use? I can get that on my iPhone. Or my buddy was gonna sell me a galaxy tablet. I also found this one that looks like it supports torque pid files.. It's called engine link
(http://images.tapatalk-cdn.com/15/11/16/4b93e260fa47b1898ef390c8e00070e7.jpg)
Sent from my iPhone
Post by: ecoboostsho on November 16, 2015, 02:27:55 PM
Can you enter custom PIDs in Dash Command by chance?
Post by: 66 Galaxie on November 16, 2015, 06:29:28 PM
Quote from: f8tlSHO on November 16, 2015, 12:56:14 PM
Sent from my iPhone
I also have an iPhone and have done some playing with both EngineLink and Forscan lite.
Engine link does allow for custom pids but they don't always work.  In particular I haven't gotten tire pressures to work or fuel rail pressure.
Forscan Lite doesn't allow custom PIDs but has a more extensive list of pids loaded and does show me data for tire pressures and fuel rail.
What PIDs are you looking to access?
Post by: f8tlSHO on November 16, 2015, 06:49:36 PM
Rear fuel pressure, boost, knock retard
Sent from my iPhone
Post by: 66 Galaxie on November 16, 2015, 08:21:43 PM
I'll try to take a look tomorrow and check for you.
Post by: f8tlSHO on November 16, 2015, 08:25:39 PM
Quote from: 66 Galaxie on November 16, 2015, 08:21:43 PM
ok
Thanks
Sent from my iPhone
Post by: FoMoCoSHO on November 16, 2015, 10:54:21 PM
Quote from: ecoboostsho on November 16, 2015, 02:27:55 PM
Yes but when you use the gauges instead of the standard dashboard, the performance slows to Torque levels.
Post by: f8tlSHO on November 17, 2015, 12:19:58 PM
Does anyone use a kindle fire? They are only 50$..
Sent from my iPhone
Post by: 66 Galaxie on November 17, 2015, 01:23:56 PM
Quote from: f8tlSHO on November 16, 2015, 06:49:36 PM
Sent from my iPhone
Engine link does boost but does not do rear fuel pressure or show knock regard.  I will look into the actual PIDs and try building them as custom PIDs and report back.
ForscanLite does boost, fuel rail pressure and rear fuel pressure.  It lists knock timing but I need to take the car for a drive later to see if it actually reads it.  My suspicion is it does read it since it will show knock readings for all cylinders and does show normal spark advance
Post by: ecoboostsho on November 17, 2015, 01:40:10 PM
The knock PID works in Forscan on my car just fine. The individual cylinders do not.
Post by: FoMoCoSHO on November 17, 2015, 01:48:58 PM
Quote from: f8tlSHO on November 17, 2015, 12:19:58 PM
Sent from my iPhone
Last time I checked only amazon approved apps are allowed and none of the diagnostic stuff was listed. Unless that has changed, you would have to side load the app.
Post by: MKSecobeast on June 18, 2017, 01:33:49 AM
I have and they have a program similar to torque. I forget what it's called, but search for torque and the one i'm talking about pops up. It has everything that torque has I do believe..
