just curious to see who is making what kind of power and what parts you have. (feel free to copy & paste)
vehicle: 2011 flex
motor: reman (heads ported, studs, mls, intake ported)
turbo's: factory (ported)
fuel system: stock
t stat: 160
map: 3bar
water/meth: yes devils own 2 nozzles
intake: k&n filter
intercooler piping: stock
intercooler: stock
exhaust: custom 2.5" DP to stock mufflers
tune/tuner: 93 perf+ meth Unleashed
spark plugs NGK -1 .030 gap
coils: MSD red tops
catch can: UPR duel valve
nitrous: nitrous express single stage 75 shot (not ran on dyno)
how long on set up: 3 months
dyno numbers: 411hp 458tq
Vehicle: 2010 SHO nonPP
Motor: Stock
Trans: Stock
Trans mounts: Gen2
Turbos: GearHead
Fuel System: Stock
Water/Meth: 100% Methonal
Meth Vendor: Alky Control
Nozzle Size(s): M10 M5
Intake Manifold Sensor: 3bar
Intake: Airaid
Thermostat: 160
Throttle Body Spacer: Econoaid Throttle Body Booster by Airaid (spins air for better fuel/methonal atomization)
Intercooler: GearHead
Intercooler piping: EcoPowerParts Hotpipes
Spark Plugs/gap: Sp542 .028
Exhaust: 2.5 stainless turbos back, double x pipe no cats, no mufflers 4" quad tips
Catch Can: UPR dual valve catch can
Tuner: SCT X4 AJPTurbo 93+Meth
Boost: 19 psi
How Long on Setup: 2 months
Mustang Dyno Pull: 463hp 569tq
Vehicle: 2013 SHO "M"
Motor: Stock
Turbo's: Stock
Trans Mounts: Gen 2's
Fuel system: Stock
T-Stat: Stock
Map: 3bar
Meth: Nope....Corn Life
Intake: Stock Air Box With K&N Drop In
Intercooler Piping: Stock
Intercooler: Gearhead Upgraded IC
Exhaust: PPE Catted DP to Stock Mufflers (no dyno runs yet)
Tune/Tuner: E30 AJPTurbo
Tuning Device: SCT Livewire TS+
Spark Plugs Sp542 .028
Coils: Stock
Catch Can: UPR Dual Valve
Boost: 14 psi (Turbos are tired)
How long on set up: 1 year
Dyno Numbers: 391hp 470tq (Pre DP's)
Final Numbers: ?????????????
IDK @ the moment but hopefully will have some time to put her on the rollers soon!
Had some goodies added to the list since having it last Dyno-tuned @ 415whp-465wtq over 2 years ago!
Most recently added New Gearhead Intercooler-MSD Coils and EPP Dual Intake to the mix! Z
Redhead 2013 Performance Package SHO
Livernois Custom Methanol Tune
3-Bar Map
Reische-170-Stat
Full Race Tial-10psi BOV in Black
PPE-Gloss Black Hot Pipes
PPE Catted DP
Corsa Sport Cat Back Exhaust
H&R Sport-Springs
Airaid-Dry-flow-CAI
CFM Performance Billet Valve Cover Breather In Gloss Black
Llumar 20%Ceramic window Tint
MSD Ignition Coils in Black
Extreme Roof Spoiler
Redline Fluids all around
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection
LMS-Custom-Dyno-Tuned @ 415whp-465wtq|
Best Trap Speed of 115.54 mph
https://www.ecoboostperformanceforum.com/index.php/topic,7881.0.html (https://www.ecoboostperformanceforum.com/index.php/topic,7881.0.html)
(http://i.imgur.com/jjJ6tO6h.jpg)(http://i.imgur.com/dcuu0Wsh.jpg?1)
Vehicle: 2013 SHO PP
Motor: Stock
Trans: Stock
Trans mounts: stock
Turbos: stock
Fuel System: Stock
Nozzle Size(s): M5
Intake: stock with K and N drop in
Thermostat: 160
Intercooler: stock
Intercooler piping: stock with noise make delete
Spark Plugs/gap: stock .030
Exhaust: EPP catted DP's
Catch Can: LMS
Tuner: Liver wire TS AJPTurbo 93+Meth/ E30
Boost: 16.5 psi
Mustang Dyno Pull: 413hp 473tq Done at 4020' da at 58*F 77% Humidity
Vehicle: 2010 SHO Non PP
Motor: Stock with Billet oil pump gears
Trans: Stock with Dual Ford expedition Coolers
Trans mounts: stock
Turbos: Upgraded Billet Comp Wheels + TurboSmart Wastegate Actuators
Fuel System: Stock w/Boostane
Water/Meth: 100% Methanol
Meth Vendor: Alky Control + Devilsown nozzles/fittings/ trunk tank
Nozzle Size(s): Devil's Own D05,D07, 2xD01 pre turbos
Intake: Airaid/ Roush CAI
Thermostat: LMS 160°f
Intercooler: Csf stock w/ aluminum tanks
Intercooler piping: stock with EPP noise maker delete pipe + meth nozzle bung
Spark Plugs/gap: sp542 .026
Exhaust: livernois / ARH catless DP's
Catch Can: Meth
Tuner: Gearhead (formerly LMS) SCT X4
Boost: 15.5psi (still logging on base file)
Oil/Fluids : Amsoil everything
Sent from my PH-1 using Tapatalk
Quote from: 76fomoco on July 27, 2019, 05:01:57 PM
I have made it my lifes quest to gain 3hp and beat your dyno results....
let it be known
Quote from: FLEXXX on July 29, 2019, 05:59:39 PM
let it be known
LOL I should have waited until I had DA around 2500' as this is what the shop sits at. This should have been good for about 4% more power. I will have it on the dyno again in a few weeks with AJP's E30 tune and from what I have seen on the track it will be very close to the meth tune for power.:)
It's in my signature... parts included...
