Information released Sept 27, 2018
Quotes
I've been doing some turbo mapping.... This is the closest thing you will see to a real turbo map for our stock turbos.... I generalized some of the load points to show them at peak HP (5200 rpms or so). Now you can see where the efficiency is.... yikes! 220000 rpms is the absolute limit of where you should run these turbos as well.
(https://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=9480.0;attach=19135;image)
(https://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=9480.0;attach=19137;image)
compressor flows more but is actually smaller... Trying to maximize response/flow relationship.
stock housings machined for larger compressor and turbine. Same thing ATP does.
Efficiency peak doesn't change for the most most, but the island moves higher into the areas where we use it.
Price not finalized, probably around $1,800
Interesting.
Very clear improvement. Looks to be 68% efficiency @25psi vs stock 45% @25psi. And 25psi is A LOT. And 70% efficiency up to 23psi vs stock 12psi. Seeing is believing 😉
ARGH all these wonderful turbos coming out after I swapped mine out already for stockers. :banghead: :banghead:
Quote from: shoNoff on September 28, 2018, 02:16:20 PM
Well you needed new ones and they were the least expensive.
Matt at gearhead has some awesome stuff in the works, just don't expect it anytime soon. Everything is still being developed. I am really looking forward to the intercooler
Quote from: Jordan on September 28, 2018, 07:58:42 PM
Yea man I can't wait for the intercooler.
