Did the TSB 14-0113 didn't help and the PCV Valve that came with new Crankcase Vent Oil Separator Don't have the electric plug on it like OEM one that came on it call the ford dealer and said the one they sent was the right one just leave the plug unplug Does anyone no if that will turn on a cel or what it does before i unplug it ????
It should set off a code IIRC but the plug is for Electric heated PCV version on the 2010my Job 1. Production Date- 06/2009-12/2009
The 2011+ do not have a heated PCV . Plug below. Z
Electric heated version. Ford Part No.: AA5Z-6A785-A
PCV -Ford Part No.: 2C5Z-6A666-AA
(http://i.imgur.com/dXewmacm.jpg)(http://i.imgur.com/3co0OLkh.jpg)
Separator Assy - Oil
https://www.fordpartsgiant.com/parts/ford-separator-asy-oil_aa5z-6a785-a.html (https://www.fordpartsgiant.com/parts/ford-separator-asy-oil_aa5z-6a785-a.html)
PCV
https://www.fordpartsgiant.com/parts/ford-valve-asy_2c5z-6a666-aa.html (https://www.fordpartsgiant.com/parts/ford-valve-asy_2c5z-6a666-aa.html)
https://www.fordpartsgiant.com/parts-list/2010-ford-taurus/emission-control-crankcase.html (https://www.fordpartsgiant.com/parts-list/2010-ford-taurus/emission-control-crankcase.html)
I would also add that the electric heated version is a bit more expensive. Z
AA5Z-6A785-A
Production Date: 06/2009-12/2009
$79.21
Ford 2C5Z-6A666-AA
Valve Assy
With Electric Heated PCV
Fitting Vehicle Options:
$34.26
Non-Heated version
AA5Z-6A785-F
Production Date: 12/2009-
$62.52
AA5Z-6A666-D
Valve Assy
$5.03
Do not want to be the bearer of Bad News: there may be more going on here...
How many Miles,
Is there a Ton of smoke at idle, AND
Pure White smoke out the Exhaust...?
Currently i have the same issue, of course i Also
blew the Turbos, and New were installed..
but that is not the problem, as we performed the TSB,
including the Valve Cover, and Now On to engine removal...
well there was when i pulled the turbos off but have not got them back on yet
Quote from: mcrmb1 on May 01, 2017, 12:01:58 PM
You may be in the same boat as me....?
and if so Not Good... PM me if you want
