got my sp542 replacements ... (pics) (oddity)
Started by TopherSho, March 11, 2020, 11:16:55 PM
TopherSho
well they look the part ...  but there is an oddity.  It appears they are pre-gapped to .028/.029 ?    I cannot find my feeler gauge but my old wire guage .030 wont pass,  it is a hard no on all 6 plugs.
part number is below and does not have any good details from the googlez
cyfs
092ypt3
hmmm doesnt seem right ...
Best 0-60 public road 4.35s
TopherSho
TopherSho
https://shoforum.com/index.php?threads/spark-plugs-sp578-new-part-number-for-542.139471/
this seems to indicate im good... of course this is the internet and all .. anyone else have any feedback?
ridered74
Quote from: TopherSho on March 11, 2020, 11:36:16 PM
I've been running mine at .026 for the last year. I think you would be fine running those.
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
SM105K
I bought a new pair of 542's last weekend, all were pre-gapped to .028 as well.
TopherSho
Either of you two fine gents note the part number on the ceramic ?
SP578 Ford CYFS12YPT
SP580 Ford CYFS12YT4
SP534 Ford CYFS12YT3
SP542 Ford CYFS092YPT
TopherSho
Quote from: SHOdded on March 12, 2020, 11:41:11 AM
My ceramic has a 3 on the end of it ( CYFS092YPT3 ) .  Wonder if that means revision 3 of the ceramic tip,  mine is the new ''long tapered'' type.
Here are the SP-542's.. Whats the part number on the actual spark plug! Z
Part Number: 95822- ILTR7N8
ridered74
Quote from: TopherSho on March 12, 2020, 10:01:27 AM
I did not. If we're being honest, my add generally doesn't allow me to retain anything past the first sentence of any post so I assumed your hangup was more gap based.
TopherSho
Update,  I do NOT like these plugs.   I have lost 4 tenths of a second of my 0-60 ... way way not happy.
Dropped from a repeatable 4.4 to a 4.8 ... super pissed since they cost a bunch
ridered74
Quote from: TopherSho on June 26, 2020, 05:26:57 PM
I switched to the M-12405-35T plugs about a month ago. They seem to be OK.
TopherSho
I failed to update the thread,  my bad.  A reset seems to have solved it... but i'm baffled and still kinda annoyed that changing plugs had such an effect ..
