I still don't think you need slicks on the rear. I would be looking at either Hoosier 17" DR's (only 22 lbs) or 18" Nitto DR's (28-30 lbs). You will have to find similar diameter rears. Reason I went with Nitto's was that I could install on 18" x 9" TSW Interlagos. They were about the only lightweight 9" wide wheel available. Went with 18" because I wanted to eventually match 4 summer tires (Michelin Pilot Super Sports) on 4 !8" x 9" Interlagos, which I did last summer.
If you get any spin on front, the slicks on rear won't spin, and you may get a possible shutdown. Better to allow rears to possibly spin by using a lightweight summer or A/S tire.
If you go with non radial tires, you need to do it all the way around. Not good to mix.
