Anyone have this info that could pass along?
Mine came with that info. If I remember right it was 80 ft/lbs. Been awhile tho so I could be wrong. Weird that you didn't get that info with yours.
Quote from: ridered74 on March 03, 2020, 11:25:57 PM
Thanks ridered74. I should be getting my set this Friday. I wasn't sure if they would come with the torque specs or not, so I wanted to ask ahead of time. I didn't recall seeing anyone post it and I'm a stickler when it comes to proper torquing.
I went with 4 ugga duggas.
Quote from: SM105K on March 04, 2020, 07:57:46 AM
4 ugga duggas seems about right...... With the correct number of beers consumed and properly correlated calibration of ugga dagga, that should work out to exactly 80ft/lbs. :biggrin:
Quote from: 10ECOMKS on March 04, 2020, 08:58:05 AM
My man!
I've been racking my brain trying to remember, but I'm old as dirt so that didn't go well. I feel like it was either 80 or 105 but I didn't save the instructions and don't remember for sure. If yours don't come with the specs I would try 80 first and if there is a lot of NVH maybe tighten it up to 105. Pretty sure 80 is 2 ugga duggas and 105 would be right about 4 ugga duggas.
Quote from: ridered74 on March 04, 2020, 08:03:20 PM
Thanks for your input ridered74. Mine didn't come with torque specs, so I torqued them to 80ft/lbs. ...It felt right. It didn't take much to brake the bolts loose
For anyone interested...the factory torque spec for the (4) 15mm front and rear mount bolts is 66ft/lbs on the frame sides (farthest forward and farthest rear) and 76 ft/lbs for the bolts that are on the engine/transaxle sides of the mounts.
....miss placed uggga torque wrench, but is it 80 lbs then for the 2nd gen AD mounts?
Anyone have torque specs on the 2nd gen AD wishbones?
Ok then.....ill try 80 lbs.....
