Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: avidmotion on December 01, 2020, 09:34:18 AM
Title: New 25% upgrade oil pump Melling
Post by: avidmotion on December 01, 2020, 09:34:18 AM
I saw on YouTube a "must have" for olderveccoboost motors. A Melling direct fit replacement oil pump with 25% more goodness. Comes with 2 springs pre-installed is the 100, YouTuber recommended the 85
Title: Re: New 25% upgrade oil pump Melling
Post by: 402Sho on December 01, 2020, 09:41:10 PM
I saw this too I'm wondering if it would also be good for a new engine build that will be pushing higher hp's, let's hope someone knows
Post by: bpd1151 on December 01, 2020, 10:33:49 PM
From what I was told, "NO".
Additionally, there's a risk of cavitation and running the pan dry as more volume is being pushed throughout.
No plans to include this in/on my build.
Post by: 402Sho on December 08, 2020, 10:01:00 PM
Thanks for answering this, I just ordered a new oem pump to be safe.
Post by: BOT_ROCKET on December 09, 2020, 04:11:06 PM
Quote from: bpd1151 on December 01, 2020, 10:33:49 PM
I just watched the video from Fordtechmakuloco as well. I don't have a 3.5 so this doesn't really apply to me, but I'm curious; Where did you hear that? I'm not an oil pump expert, so correct me if I'm wrong here. You're engine shouldn't be getting so much additional oil that it runs the pan dry as long as the engine isn't too worn out, correct? This pump would simply ensure proper oil pressure if your engine is worn to the point that the stock pump can't keep up with additional flow rate needed due to worn clearances. This assumes the same spring rate, which I don't know what the stock spring is rated at.
Post by: bpd1151 on December 09, 2020, 04:29:16 PM
I immediately passed the advertisement along to my (current) engine builder when it was shared with me by a fellow SHO owner.
We discussed whether to incorporate it, and among other reasons not to, those were the two highlights I recall from the convo.
He had had the technical reasons against its implementation, and it was beyond my knowledge/understanding.
Thus why I kept my original reply generic in nature.
Post by: avidmotion on December 09, 2020, 08:42:59 PM
I just fyi the info since I see everyone rebuilding, and he mentioned older higher mileage SHOs 3.5 l eccoboost, f150 etc.
I respect Fordtechmakuloco .
[/size]However I respect this forum more.
