I have a minor annoying issue with the center mounted gear shift:
it is loose and wiggles back and forth (Just annoying) and wonder if
anyone has had this issue, and if there is a simple fix. my Mech says NO,
but after the nine month issue with my car (i want a second opinion)....!
Do you mean twist in place? Or has lots of forward and back play? Mine was loose going forward and back, then it stopped being able to shift at all ..
Is it just the shift knob? Yes you can tighten it then it's solid, no more wiggle.
Yes:
Just the shift nob, Wiggle only, no forward or backward issues
So how do you tighten it...?
Quote from: irondoor19 on November 25, 2019, 10:08:58 AM
Yes:
Mine used to be a little loose...felt cheap. After following this video its been tight as a tiger since.
https://youtu.be/SCde1obozQY
WOW: THAT WAS EASY,
not like the rest of my repairs,
every now and then a squirrel gets a nut, thanks again
