As a general rule, accumulation of oil around a hose that recirculates charged air is a sign of a boost leak. This appears to be a little dryer than most that I've seen. But this kind of accumulation doesn't happen without a leak.
(https://uploads.tapatalk-cdn.com/20171202/c9a99eba96c181e348894a4be2ea35c8.jpg)
Can you datalog?
Very possibly. If the PCV system is performing well otherwise, you would get less of an accumulation at the leak site.
I don't have a lap top to data log. Does anyone know the part number for this pipe?
It might be a wise time to invest in some HOTPIPES.IMHO. Z
AIR PIPE - FORD (BA5Z-6C646-A)
$257.80
https://parts.levittownfordparts.com/oem-parts/ford-air-pipe-ba5z6c646a/?c=Zz1jb29saW5nLXN5c3RlbSZzPWludGVyY29vbGVyJmk9S0QwOTA2MzUmcj0xMiZhPWZvcmQmbz10YXVydXMmeT0yMDE0JnQ9c2hvJmU9My01bC12Ni1nYXM%3D
https://parts.levittownfordparts.com/auto-parts/2014/ford/taurus/sho-trim/3-5l-v6-gas-engine/cooling-system-cat/intercooler-scat/?part_number=aa5z9u465a
Quote from: ZSHO on December 02, 2017, 01:20:17 PM
It might be a wise time to get some HOTPIPES.IMHO. Z
$257.80
Thanks for the link. Agreed on the Hot pipes. Especially since the oe part is so damn expensive. Just wish I could buy just that one from them.
Clean it, find the crack and plastic epoxy it. Should be good as new. They even sell it in black.
https://www.amazon.com/Permatex-84145-Permapoxy-Black-Plastic/dp/B00THUUVSU
Also that clamp looks like it's been removed before.
Quote from: glock-coma on December 02, 2017, 04:03:59 PM
Good eye. I didn't notice until you said something. But you're right. The color change in the lettering, shows that the clamp has been moved.
Did you happen to check out the rear?
I would also add a 1/4 clamp to the waste-gate hose that connects to the intake charge pipe! they have a tendency for coming off due to boost psi .
Those Darn VTA Mods ! Lol . Z
Quote from: ZSHO on December 03, 2017, 07:13:16 AM
Did you happen to check out the rear? Z
Well ahem......
That's a double entendre if I've ever seen one.
LOL
Quote from: bpd1151 on December 03, 2017, 07:16:36 AM
Well ahem......
LOL
I will let you know when I wake up and get a cup of Joe. Lol .Z :sleeping:
I did check the rear turbo hose. No signs of leaks. I prefer zip ties to those 1/4 clamps.
Did you ever figure anything else out about this I'm having a Wastegate flutter on my 13 sho and I believe it's because of the same hose
