Here is info on how to make vehicle changes using forscan.
Mobile application is ONLY a data logger must use a computer to make changes.
Download link http://forscan.org/download.html
https://youtu.be/0I2KEEMPSt8
Info about getting license to make changes.
without license it's just diagnostic logging software.
http://forscan.org/forum/viewtopic.php?f=5&t=836
Code edits not in forscan yet.
Remove double honk
bdycm
726-16-01 0211 57 as built
726-16-01 0201 47
AWD distribution driver gauge
ipc
720-01-02 8AFC-4CF0-3F2B asbuilt
720-01-02 BAFC-4CF0-3F5B
Enable Engine Hour Display
720-01-02 88FC 40F0 3D1B to
720-01-02 88FC 40F3 3D1B
Nav on IPC:
Before (compass on IPC)
720-01-02 BAFC 40F3 3F52
After (nav on IPC)
720-01-02 BAF8 40F3 3F4E
(https://uploads.tapatalk-cdn.com/20170424/3f0ba19b1bbe182489f010bf56b42ab9.jpg)
Turn off amp and have clean preout from radio from fusion forum
http://www.2gfusions.net/showthread.php?tid=3704
Ford fusion write up for FORScan
http://www.2gfusions.net/showthread.php?tid=4573
Change factory splash screen.
http://www.fiestastforum.com/forum/showthread.php?t=11920 page 5
https://drive.google.com/folderview?id=0BySleg7SM4KcSzVYeF9ueGlKWVE
http://forscan.org/forum/viewtopic.php?f=5&t=2331
http://www.f150forum.com/f118/forscan-software-enable-disable-features-your-truck-348987/index540/
Online updated spreadsheet of what you can change from f150 forum.
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#gid=815852466
Mustang spreadsheet
https://docs.google.com/spreadsheets/d/1-gytuV9qPfxvLLcFBIl6nt9h5MGW-NWEPc04cN-ro60/htmlview#gid=0
Taurus spreadsheet-currently down trying to find something similar
https://onedrive.live.com/view.aspx?resid=6DF661C7B798C246!36209&ithint=file%2cxlsx&app=Excel&authkey=!AOW_-cRixqVIJWM
Good forscan forum for the Taurus
https://forscan.org/forum/viewtopic.php?f=5&t=2662&hilit=2015+ford+taurus+awd
Flex spreadsheet
https://docs.google.com/spreadsheets/d/1qe8PznI_XvEb5NPaRCN5OBXpcdrIvx6qvenWbHRtRA8/edit?usp=sharing
Flex forum
https://www.fordflex.net/forums/viewtopic.php?f=3&t=17209
Explorer forum
http://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848/
Explorer spreed sheet
Sync2 https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/htmlview#gid=0
Sync3
https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2016-2018_Explorers
I recommend
http://www.obdlink.com/mxwf/
Or
http://www.obdlink.com/mxbt/
Go WiFi if you have iPhone
Others say kiwis are a good cheap option I've used the first kiwi it was fine but know it couldn't do hi and low can speed.
https://www.plxdevices.com/category-s/195.htm
Kiwi3 it's has poor reviews on the play store.
Here is some information about reading hex for odometer.
https://youtu.be/XKXn_EcZblY
Where did u get ford scan?!
I believe you can download from FORScan.org
AFAIK, still requires a Windows OS to access full capabilities.
Quote from: SHOdded on October 29, 2016, 10:00:15 AM
You are correct. They have an Android and iOS version but both don't have as much capabilities as the Windows version.
Or wine on Mac and Linux.
Anyone willing to give me there vin if they have a loaded 16/15 Taurus sho w/o pp?
Just found this program to compare as built data and one day I wanna try adding adaptive cruise control and maybe some other stuff
http://www.compulsivecode.com/Project_AsBuiltCompare.aspx
http://forscan.org/forum/viewtopic.php?f=5&t=2012&start=10
I'll try to make a video tomorrow showing how slow so you can get an idea maybe someone with the wifi version can make one?
If all you need is a VIN, I'd search the sale listings: dealers, private listings, even ford.com.
I'd give you mine, but I have a PP (no ACC). You're still going to need the ACC components (radar, etc.).
Thanks yea I just checked Chicagos area they have alot of sho's
Question for you FORScan gurus.
Can you get into BCM parameters and see any TPMS info?
Also, what bluetooth adapter are you guys using? If I pull the trigger, I want to make sure I get something compatible.
Thanks!!
You can see tpms info what exactly are you looking for tomorrow morning I'll take a look at it.
By far the best odb device is the obdlink MX I like Bluetooth version because it's easy to connect and still have internet on my phone but the wifi has quicker data refresh.
https://www.amazon.com/gp/aw/s/ref=is_s_ss_i_0_8?k=obdlink+mx&sprefix=obdlink+
Quote from: Gjkrisa on January 10, 2017, 12:47:30 AM
This looks very neat..
https://www.amazon.com/gp/product/B006NZTZLQ/ref=s9_psimh_gw_p263_d3_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0FDJ7ETZ3DC8DSKYGSP2&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846&tag=scantonet-20
Yes that is the one I own.
Awesome! Ordered the MX, thanks!
I'm not really sure what I'm looking for. LOL
Do you have the ability to see your sensor IDs and/or add/change/remove the IDs that are present?
I'm thinking step 1 is to read/clear any stored BCM codes to see if that allows me to train new sensors, but if I had to, I was wondering if I could manually add the codes I read from the TPMS service tool into the BCM.
Codes or PIDs, Mike? You cannot add PIDs into any module. You can add PIDs to Torque Pro to read the existing PIDs in the vehicle's modules. You cannot add PIDs to Forscan, period. forscan.org forums are a good resource to browse through/ask questions in as well.
Quote from: SHOdded on January 10, 2017, 07:47:51 AM
Thanks, Manu.
I don't
think I need to add any PIDs. I was curious if it was possible to manually add the 8 digit alphanumeric TPMS ID to an existing cell on the BCM. Like if there was old sensor data stored, could I replace it with new sensor data?
And/or if there was a stored DTC on the BCM, would I be able to clear them with FORScan?
I'll try over on the Forscan forum you mentioned as well. Can never have too many hooks in the water! :)
Thanks for the feedback!
I see, you want to populate the data values into the PIDs and force recognition that way. Great idea, IDK if it is possible though, hope it is. Then we would find out whether the system periodically scans these values and resets to the most current discovery or simply leaves them alone :)
Quote from: SHOdded on January 10, 2017, 09:46:40 AM
Correct! That was my thought. Force it in and see if it's accepted. Sheesh, when it's put that way, I feel ashamed. LOL
I
just posted on the FORScan forum as well. Here's the link for anyone who wants to follow along. I'll be sure to post a resolution here as well, if/when I get this figured out.
http://forscan.org/forum/viewtopic.php?f=5&t=2943
Use forscan to change to different factory splash screens
Quote from: Gjkrisa on January 12, 2017, 05:20:29 AM
http://www.fiestastforum.com/forum/showthread.php?t=11920 (http://www.fiestastforum.com/forum/showthread.php?t=11920)
Anyway to add a custom one? Work with Sync2 I assume?
Would be cool to have Ford Racing or SHO
Quote from: derfdog15 on January 12, 2017, 10:53:20 AM
At one point I think I saw a thread (different forum) on doing custom splash screens via SD card flashing. It required some minor manipulation to the Sync update code.
IIRC, I think it was a Raptor forum because the Raptor guys were getting Lincoln splash screens after a Sync update. I believe one of the posters explained how to update the code to add your own screens. Didn't look all that difficult, but I haven't tried it myself.
If it can be done with FORScan, that would probably be a lot simpler. :)
To add your own splash screen you would need to some how do it with flash card.
Now that we have a physical update someone can reverse engineer it and just make it change splash screen. Maybe even make a theme.
Has anyone tried this yet on a SHO? I assume that is SYNC 3 only as well - the Sync 2 addresses would probably be different. If one of you SYNC 3 guys is feeling adventurous you should try it out!
I plan to do it tomorrow.
Quote from: ecoboostsho on January 13, 2017, 10:34:22 AM
I didn't spend much time looking at but may have Info you want
http://www.fiestastforum.com/forum/showthread.php?t=11344
Very cool. Will take a look!
Sent from my XT1096 using Tapatalk
Just did this is what I had to change to get Lincoln presidential splash
Quote from: Gjkrisa on October 28, 2016, 10:54:00 PM
Hey anyone know much about these features in FORScan what do you change?
Only thing I've done is turn off the honk when double locking and turn the turn signals to daylights.
Found this on a forum how to disable double honk on 2016 explorer
(https://uploads.tapatalk-cdn.com/20170114/3c6db2dee61071e86198c4cf898473d1.jpg)
Fd0-02-01 xxxxx4xxxxxx and fd0-02-02 8xxx
Playing with these was fun when I get more time im going to try more random things in here and print out the f150 doc to have some understanding
I wish there was a way to add the complete value that's not in there already I may try to edit the backup file and add the one that should be for the disable double honk.
Do any of you guys have issues with your OBDLink MX BT dropping connections? My connection drops out frequently enough to not want to attempt programming. I don't want to brick a module because a signal dropped part way through a flash.
I have not.
get obd link app to verify you didn't get a clone
(https://uploads.tapatalk-cdn.com/20170115/7af0bca6a51683fe2f3772de662a7eb0.jpg)
Also before you change anything just make a backup of all the modules you have to do it one module at a time. It saved me when I didn't fully understand what I changed
Quote from: Gjkrisa on January 15, 2017, 10:06:31 AM
Thanks for the tip on backups. Pretty sure I didn't get a clone, but I will get the app to verify.
Not had a fallout yet. 3+ years in service. But then again, y'all's rides have more sophisticated systems than mine.
Quote from: Gjkrisa on January 15, 2017, 10:03:32 AM
I have not.
Quote from: SHOdded on January 15, 2017, 10:50:50 AM
I'm running Windows 10, and the connection goes between "connected" and "paired". Apparently this is normal with Windows if a signal isn't being actively transmitted. Registered the device with the OBDwiz application, and everything seems kosher.
When I execute service procedure to program a module, it seems to stay connected, but if I clear a DTC, it will work once, then I get a "No ELM found. Please check connection and try again". If I close FORScan and reconnect it works again. I turned off a power save feature in my device manager for Bluetooth, but this didnt seem to make much of a difference. Guess I will just proceed with caution.
interesting i have windows 10 also but i have a asus bluetooth adaptor i had to buy and just used windows bluetooth device control to add the obd device .
ive never cleared a dtc with the laptop though.
let me know if you make a change to the modules and still have it disconnect just something id like to know.
if so id try to just register using windows Bluetooth.
I have only used Forscan Lite on Android to clear codes (with ignition in ON but with engine off), and never had an issue with pairing. Sounds more of device issue on the Windows side. I know when I tried to use Forscan on Windows 7, it was a bit picky with its' Bluetooth adapters/connections.
Quote from: SHOdded on January 15, 2017, 03:57:25 PM
Yeah, I'm leaning towards Windows goofiness. I did make a change to the BCM to turn off the double horn honk, and it worked with no issue.
I'll keep you guys posted if I have any other problems. Thanks! :)
It may already be here somewhere, but here is what I did to disable the double honk on '15 SHO.
726-16-01 0201 47
Quote from: Izzybird on April 23, 2017, 02:42:06 PM
726-16-01 0201 47
Thank you I will try this!
726-16-01 0201 47
It worked!
How did you figure that out?
Anyone using a wifi adapter with Forscan? I want to go that route because the bluetooth isn't compatible with the iPhone app (so they say).
Quote from: Gjkrisa on April 23, 2017, 04:17:46 PM
It worked!
[/quote]I noticed on the exploder forum that the third digit number needed to be changed to a zero and just gave it a try. How long do I have to go through the verification questions before I can post? It's already getting old.
Quote from: Izzybird on April 23, 2017, 05:44:21 PM
It worked!
[/quote]The security verification feature should go away after the 5th post. Z
Quote from: ZSHO on April 23, 2017, 05:51:37 PM
It worked!
[/quote]
Thank you
I wanted to try the AWD Gauge but that line doesn't offer to write and I did not want to try "write all", I'm still green to all this. I just got the adapter Friday.
@Izzybird what year is your SHO? Due add your signature with your current vehicle and any mods you may have,thanks. Z
BTW you should be good to go after this post.
Quote from: Half-Fast on April 23, 2017, 05:22:51 PM
Theoretically the Kiwi BT adapter IS iOS compatible, and is well-rated on Amazon if you want to give it a try.
Otherwise for wifi, I have found Veepeak/vGate/iCar adapters to be the fastest/last the longest. Still no contest against the MX BT adapter, but not bad.
https://www.amazon.com/gp/aw/d/B00OCYXTYY/ref=pd_aw_sim_263_1?ie=UTF8&psc=1&refRID=GYMPDJB9238KCHBX9KC0&dpPl=1&dpID=41FBr8BHCiL
Obd link is who I trust no need to mod to get high low can to work
Quote from: Izzybird on April 23, 2017, 05:59:21 PM
Ohh give me the line for wed please?! I've done the write all it's safe but just in case I have a manual save of all the modules and the as built file from before
I enabled the AWD gauge on my SHO. On my 2015, I changed 720-01-02 from 8AFC-4CF0-3F2B to BAFC-4CF0-3F5B. Of course, the last byte is the checksum. Works great, although I rarely use it.
Interesting note, if you have navigation, this also changes the speed limit indicator on the right IP from the US version to the "international" version (white circle with red border).
Quote from: SHOdded on April 23, 2017, 06:55:05 PM
IOS maybe, but the iPhone app needs wifi according to this link http://forscan.org/comparsion.html (http://forscan.org/comparsion.html)
Am I reading that right
Seems so. Worth a post on the forscan forum and/or a call to kiwi directly, if you want to pursue.
Hawkeye93 has it, my checksum was different. Went for it and clicked "write all", now I have the AWD Gauge. I thought it'd be fun to play with for a couple days.
Quote from: hawkeye93 on April 23, 2017, 07:30:49 PM
Confirmed thank you !
Now I need engine hours.
Although I used trip 2 never reset and surprised never reset after power lose or messing with forscan.
If you haven't messed with forscan for awial it's time to go back thru I just got the car to not tell me when I'm not wearing a seat belt.
That is interesting I'm curious if there is away to get speed limit posted from a non nav unit kinda seems not if that changes when you have nav.
There is probably another spot to edit or another way of turning it on so that doesn't change.
I'm pretty sure you can enable navigation on a non-nav car using FORScan; I read about it on one of the other forums. Obviously, you need to buy an SD card. I have factory navigation, so I didn't mess with it.
Wife said she had to change the screen off the AWD Gauge on her commute this morning, said she kept staring at it. Lol
AFAIK the only way to add Navigation,instead of compass on the right side of the instrument cluster is through IDS Software and then you will need a Vin-specific AB File in order to program the Data for the IPC.IIRC
Here's mine below and has been working flawless for almost two years now. Z
(http://i.imgur.com/oPOt18mh.jpg?1)(http://i.imgur.com/1FjMOnPh.jpg?2)
Quote from: ZSHO on April 24, 2017, 11:15:52 AM
With forscan you can do just about everything you can do with IDs there was info in the fiesta forum that added nav I can't find it now as I didn't want to add nav but wish that the camera would pick up the speed limit signs.
Or I was wishing is the camera only used for auto hi beams?
If I find it I need to add to list of things can do.
Seems like I remember the Fusion guys saying Ford had blocked Nav Enable for now.
So which windows version do you guys recommend the regular or the wine edition?
Quote from: lamrith on April 25, 2017, 01:58:02 PM
Regular
wine is for Linux or Mac
Ford GT!
ftp://http://youtu.be/kBVsGlfX9lw (http://youtu.be/kBVsGlfX9lw)
(https://uploads.tapatalk-cdn.com/20170427/c07f53797522e98653425a21fe621063.jpg)
Quote from: Gjkrisa on April 25, 2017, 11:14:11 PM
Ford GT!
https://youtu.be/kBVsGlfX9lw
Nice!
I would love to have that but with SHO to replace the GT and then keep the Ford Performance. Has anyone found a way to load custom flash screens versus just enabling what is already apparently loaded in the unit?
No have not read anything on that but should be in the works since we finally got sync update file someone just needs tear it apart.
I agree would be nice to have just Ford performance
Maybe one of the 350 ones do that. Use to read there was one but I was confused what was changing so thats when I just started doing random things in that and found the Lincoln so I kept with that till I found f150 updated the spreadsheet.
Quote from: lamrith on April 26, 2017, 01:37:49 PM
Ford GT!
Nice!
(https://uploads.tapatalk-cdn.com/20170426/d4fa8250d06bcfd56ee899b8bc487343.jpg)
The visual design variant is how to change theme.
I was able to get lincoln theme but gt theme doesn't want to work :(
Sweet. Ordered my OBD2 MX lastnight, will get FORScan loaded on laptop so I am ready to mess my car up good. :-p
Plan to mess with splash screen and add the AWD readout.
Have to start diggin thru those Fiesta/F150 threads for any other goodies to mess with.
Thanks GJ!
Quote from: lamrith on April 26, 2017, 03:00:00 PM
Thanks GJ!
Cool go thru this and get your code when it comes in think the code only last 8 days now but generating a new is easy when it expires it just sucks when it's a been a bit and forget to renew it and have to generate a new one
Quote from: Gjkrisa on April 26, 2017, 03:03:44 PM
Thanks GJ!
http://forscan.org/forum/viewtopic.php?f=5&t=836 (http://forscan.org/forum/viewtopic.php?f=5&t=836)
8 days? I got mine last night, and it's 8 weeks
Quote from: Half-Fast on April 26, 2017, 03:48:50 PM
Thanks GJ!
Thank you I didn't remember
Another thing I'd love to find is my rear doors don't unlock automatically untill I turn the vehicle off.
I wish all doors would unlock when I go-to park.
For those who have no desire to use the Bluetooth adapters, I have had absolutely zero issues with this adapter thus far.
https://www.amazon.com/gp/product/B01F0GVBWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 (https://www.amazon.com/gp/product/B01F0GVBWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1)
Might work with an OTG adapter for Android devices. Not sure what to do for iOS tho. I like cabled if I can swing it.
Just made a video on FORScan.
:thumb: :thumb:
Quote from: Gjkrisa on April 26, 2017, 06:51:22 PM
Getting the doors to unlock shifting to park seems to be proving elusive, hopefully someone will crack it soon. Do you have global close enabled? I've got it enabled but it doesn't work, open works fine.
So all the info I am seeing on splash screen changes is Synch3. Does it work for Synch 2?
I'm sure there are things you can change in sync 2 but don't know what they are people have added reverse camera and nav just editing the sync 2 I believe
http://forscan.org/forum/viewtopic.php?f=6&t=3898
ipc
Well I got the AWD to show, but I noticed that it only shows me fuel level and not the dual fuel/rpm bar gauge like yours does. All good regardless. Driving in S mode using the paddles has been fun and really changes the feel of the car. It will be nice to see how the awd is kicking in and when as I goof around.
Might be because I've had the temp gauge option on or recently used the paddles before turning the option on or maybe just some other programming different. I can try to take a picture of my settings to see what else is different.
Quote from: Gjkrisa on May 06, 2017, 11:29:22 AM
http://www.2gfusions.net/showthread.php?tid=3704 (http://www.2gfusions.net/showthread.php?tid=3704)
http://www.2gfusions.net/showthread.php?tid=4573 (http://www.2gfusions.net/showthread.php?tid=4573)
That is some damn good info
Never mind, I found a discussion on the forscan forum and it appears enabling global close does nothing on the taurus. Anyone messed with secure idle? On 726-42-01 I had x1xx xxxx xxxx, which should be enabled but the shift lever does not lock when the fob is out of the car. I switched the 1 to 0 for the heck of it and got service advancedtrac and the ABS light on, guess I could go do a burnout or something..
I think the global open opens all doors when driver opens their door and car is off...
If that's as far as we can get to global open I don't know what Ford was thinking?
trying to be a pioneer in passenger safety?
What if there was a roll over does it still act the same way?
Global open rolls the windows down when you hold the unlock button on the fob down, global close should roll them up when you hold the lock button down. I enabled global close, but apparently it does nothing on some models including Taurus. Global open is awesome! If it starts raining and I've left the windows up, I can just roll them down with the fob and get a good washin' on the interior. (Sarcasm)
So messing around a bit in FORSCan I decided to look into disabling the factory eq processing. Strangely enough the 727-01-02 is set to 0031 on my ACM... and other SHO vin that I have looked up? Anybody run across this?
The 00xx is the correct setting to disable it.
Can't find the post but person asking about the tach and fuel on awd guage
(https://uploads.tapatalk-cdn.com/20170508/15de13a0a1685cd3942c0899dff9711b.jpg)(https://uploads.tapatalk-cdn.com/20170508/41bc4f6234257304e590b5cb95cb88a0.jpg)
Quote from: ShoBoat on May 07, 2017, 09:51:14 PM
Yeah I have global turned on even went and turned the driver setting on and didn't work but good thing since I still have the window shades for the kid down
Quote from: Gjkrisa on May 07, 2017, 11:39:35 PM
AHh hhaa!! Thanks I recall seeing that before and I think I turned it off as I was using the RPM display all the time.
Thanks bud!!
Does anyone know what the window safety sensor name is?
Global open does not work because we don't have the safety sensor.
Quote from: Gjkrisa on May 14, 2017, 09:57:28 PM
Are you talking about the Bounce-Back feature? If so, I thought any window with the auto up feature had to have bounce-back for safety.
Yes I'm curious if you can see the module in forscan so you would know if you can enable the feature and have it work or not
Quote from: Gjkrisa on May 15, 2017, 09:47:58 AM
Global open on the front 2 windows works, its global close that we can't seem to get working on the SHO. Which is weird as they do have auto up on the door switch. Even if you try to enable it in FORScan it still won't work. I have tried it.
Hmm I can't seem to get open to work just double click unlock and hold unlock right?
Quote from: Gjkrisa on May 15, 2017, 01:07:55 PM
Yes and it must be enabled in the left cluster
(https://uploads.tapatalk-cdn.com/20170515/cd80c0bffcf1d217869fd51f821b7e36.jpg)
(https://uploads.tapatalk-cdn.com/20170515/d3c4669a311f42cfca18e178421f614c.jpg)
Yea I did that still no go but I might of had timing off or something I'll try again later
Quote from: Gjkrisa on May 15, 2017, 01:59:19 PM
My car is a '13 PP. I just checked and made sure it was "on" in left dash settings. I have not altered anything for the windows using FORScan.
click-clickhold worked for me. It was a loong hold on the second click, 3-5 seconds? I also did a slow sequence. Not clickclick... more like click and clickhold. When I tried it fast it dis not work.
This one seems to work just pressing unlock and holding it a few seconds. They start rolling down when I let off the button.
Remote close isn't an option it appears
Quote from: Half-Fast on May 15, 2017, 06:34:27 PM
There's the option to turn it on, it just appears to not do anything on the Taurus platform. If that's what you meant, my bad.
Yea with remote close we need the safty module I'd like to look into how to get that and turn it on or if some are coming with it how you can tell if you have it
http://forscan.org/forum/viewtopic.php?f=5&t=2662 (http://forscan.org/forum/viewtopic.php?f=5&t=2662)
Wish I would have seen this thread before I spent all day trying to figure out the double honk disable and AWD Gauge, they were right here the whole time.
I assume you've already seen this Gjkrisa?
http://forscan.org/forum/download/file.php?id=1563 (http://forscan.org/forum/download/file.php?id=1563)
Hmm I wonder if TPMS can be enabled on the left stack on a 2013 SHO?
If only we knew someone with a '13 to try it..
Let us know!
Quote from: Izzybird on May 18, 2017, 10:06:23 AM
No I haven't seen that yet. Thank you.
Quote from: ShoBoat on May 18, 2017, 10:27:52 AM
I thought of that too need to find a vehicle that has it. Although it was not on fordpi.com so I'm guessing it doesn't work.
Still worth a look into though.
Quote from: Gjkrisa on May 18, 2017, 11:01:50 AM
Doesn't the new Explorer have it?
Quote from: ShoBoat on May 18, 2017, 11:52:04 AM
Cool I haven't been inside any newer Ford's just mine and my dad's 2012 V10 f250
Some decent reading if anyone is bored.
https://forum.xda-developers.com/windows-mobile/general/myford-touch-hack-enable-features-t3321397
http://www.explorerforum.com/forums/index.php?threads/tire-pressure-sensor-fault-under-1k-miles.433028/
Here is how it looks on the explorer, I know that mine for example has the capability as we found the PIDs for it and I can display it on the torque app. Wondering if it can be enabled on the SHO
Quote from: ShoBoat on May 18, 2017, 04:09:22 PM
Thank I will try to look into it using the adb compare tool.
726-08-01 x1xx xxxx xxxx Tire Pressure Monitor enabled observed through testing on 1-5-17
726-08-01 x0xx xxxx xxxx Tire Pressure Monitor disabled
This was from the F-150 forum.
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=0
We do have that address mine is set to BCM 726-08-01 0200 38
Quote from: ShoBoat on May 18, 2017, 04:28:38 PM
726-08-01x1xxxxxxxxxxTire Pressure Monitor enabledobserved through testing on 1-5-17
726-08-01x0xxxxxxxxxxTire Pressure Monitor disabled
Thanks that's the possible tedius part.
now just need to see what bit although an sync 2.2 seems like flipping most bits are the same as f150 but I feel this one should be different.
I would first try 1 then 0
Quote from: Gjkrisa on May 18, 2017, 04:32:33 PM
You are probably right, its more likely to be the same as the Explorer as we share the same cluster. I have yet to see it on a Taurus.
726-08-01 0200 38
from a 2017 SHO
726-08-01 0101 0000 0038
from a 2017 Explorer sport
Quote from: ShoBoat on May 18, 2017, 07:01:54 PM
726-08-01 0200 38
from a 2017 SHO
Nice!
No go I've tried even 202 and says failed
Quote from: Gjkrisa on May 19, 2017, 11:41:57 PM
Damn it, oh well I guys I'll keep looking thanks
I was able to get a list of compare from 17 sho and explorer I feel like the new sho has more lines then 2016 I have like 10 and there looks to be 20 in newer
http://s86.photobucket.com/user/gjkrisa/library/forscan%20explorer%20vs%20sho
I did something wrong or wasn't looking at it probably there are 60 lines
Haven't played with forscan for a while now, some friends caught wind that I had it and now I have four trucks and a fusion waiting for me to make some changes. Lol. Guess it's time to generate another extended license. Can anyone confirm that secure idle is functioning on their Taurus? It's a no go for me thus far, but I haven't messed with it much. I'd really like to use that feature.
What is the secure idle?
If you exit the vehicle in park running, with your fob on your person, it will lock the shifter in park until it sees the fob again.
Hmm I think mine will just let you go just don't turn the car off
I'll have to double-check
The Taurus still runs on the what I refer to as the old electrical platform. Nearly every other non-euro based model as switched to the newer platform. 11-15 Explorer/11-14 F150/11-17 Flex/11-17 Taurus/11-14 Edge are the same style. 15+ Edge/15+ F150/16+ Explorer are on the newer (Fusion style) electrical platform. Some modules such as the APIM are consistent across platforms however the BCM and IPC are not. You can not put an IPC from platform into another either as the older platform has a gateway incorporated into the IPC and the newer platform uses a separate Gateway Module.
Anyone have a 17 Taurus and that can access programming? Would like to run a test on it.
So I have a 2013 PP. Have any of you guys attempted the audio mods? Turned off the EQ? reconfigured the output to be line level out of the amp and variable?
Has anyone gotten the door chime to disable?
Quote from: jbeez on July 07, 2017, 06:13:38 PM
I would be interested in the Audio stuff.
Unfortunately, a lot of the stuff the F150 and fusion guys are discovering will not work on the Taurus. From what I understand, we share the same BCM coding as the 11-15 explorers. That's how I figured out how to disable the double honk, by using the info posted by a explorer owner. Some good info on the forscan forum, along with as built comparison tools. We need someone with the time and desire to dig through our cars and figure it out, the wife gives me the stink eye every time she sees me in her car with the laptop. And I have had no luck disabling the door chime JBEEZ.
For those of you that have existing global open and wish to try global close:
726-04-01 0001 0134
726-48-02 0000 0000 0178
This was attempted on a 2014 and did not work. Just throwing it out there for those with 15/16/17 to test.
Quote from: jmr061 on July 08, 2017, 01:50:01 PM
726-04-01 0001 0134
Doesn't work on 16
Quote from: Izzybird on July 08, 2017, 10:59:55 AM
Which explorer forum you use? Do they have a spreadsheet?
https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/htmlview#gid=0 (https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/htmlview#gid=0)
https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2016-2018_Explorers (https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2016-2018_Explorers)
http://minkara.carview.co.jp/userid/2504789/blog/38116633/ (http://minkara.carview.co.jp/userid/2504789/blog/38116633/)
Anyone have a '17 and playing with forscan? Curious if everything is still the same or not. The wife claims she wants to step in to a new SHO before hers hit 50k on the odometer.
For the sho everything basically is same since 15 except for sync3 although curious if they might have put in ability to turn on auto tilting mirrors in reverse 16 doesn't have the spot as far as I'm aware
SO getting the TPMS gauge to work on the left side is a no-go? That's a shame as that would be pretty useful info to have.
Quote from: Mustang5L5 on September 06, 2017, 11:30:09 AM
Thanks yeah i tried getting into it also just thought maybe i was missing something i wonder why on their performance orentated family car they would not put the Tom's there the pid to read how much pressure is there
Can't do it on the instrument panel, but you can display the tire pressures in Torque:
https://www.ecoboostperformanceforum.com/index.php/topic,3141.0.html (https://www.ecoboostperformanceforum.com/index.php/topic,3141.0.html)
QuoteTire pressures: Discussed in detail on page 5.
6/12/14 update on Tire Pressures: We can't get Torque to respond to these PIDs for the 2011 as I believe they are in a different module that it refuses to access...the 2011's are on MSCAN which may be preventing it and the 2013's have a BCM on the HSCAN which means the address is probably different. No luck for now...
2013+ tire pressures (psi):
LFTP
PID: 222813
Equation: (((256*A)+B)/3+22/3)*0.145
LRTP
PID: 222816
RFTP
PID: 222814
RRTP
PID: 222815
That's how I've typically done it. I just view the PID's through a scan app on my phone with a Bluetooth app and ELM327. Still, would be nice to pull up a screen and see it instantly, especially as we are about to head into the winter and the tire pressures drop over the next few months. Oh well
Changing gears, has anyone discovered how to enable the climate control menu on the right display screen?
Using Forscan, so far on my car I've done this
- Enable navigation
- Eliminate the double beep when you step outside car with engine running
- Change number of flashes when you half press the turn signal from 3 to 4.
Quote from: Mustang5L5 on September 06, 2017, 05:34:18 PM
- Enable navigation
How did you enable navigation?
Quote from: Gjkrisa on September 06, 2017, 07:35:19 PM
- Enable navigation
Should all be in this thread.
https://forum.xda-developers.com/windows-mobile/general/myford-touch-navigation-activation-t3368080
To sum it up here's what I did.
Use Forscan to enable Nav (literally changed 1 bit)
installed .png file on USB, and loaded it into MFT by importing it as a wallpaper and unlocking Nav
DId a master reset on the MFT
At that point, it was asking for the SD card, but wasn't seeing it. I had Sync 3.8, so I downloaded some Navigation update files for the system (listed as optional on some of the posts, but I had to do it) and installed via USB. After that, I put in the ford SD card with maps, and had navigation.
Spend a good couple hours researching this before I tried it, but if I had to do it again I could probably get it done in 30 minutes...mostly spent waiting for Sync to install the nav files and reboot.
CHanging the one bit also changed the Compass screen on the right side of dash to Navigation as well.
Wow! Lots of information in this thread. Trying to bring myself up to speed, but wanted to say...
On my '13 MKS, my windows roll up and my sunroof closes if I hold down the lock button on the key fob. Is that one of the things people are trying to activate? I do not have Forscan nor have played with any of this. It's just that way from the factory.
There's unfortunately no way to close your windows,sunroof via key fob IIRC. Z :(
https://www.ecoboostperformanceforum.com/index.php/topic,1670.msg21078.html#msg21078 (https://www.ecoboostperformanceforum.com/index.php/topic,1670.msg21078.html#msg21078)
Quote from: ZSHO on September 08, 2017, 07:29:43 PM
Really surprised that my car can do it, but a SHO can't. Everything else is darn near exact between the two models.
Ford product differentiation at work :)
Quote from: sholxgt on September 08, 2017, 07:41:31 PM
Might be hardware related as to the reasons for that. Perhaps the motors are different enough to justify the higher price point of the Lincoln, and Ford decided not to extend that to the Taurus line in general. For instance, there's a feature called "secureidle" which locks the shifter in Park if you get out of the vehicle and won't allow it to shoft out of park until it detects the key again. Great for police vehicles, but if you enable it on the civilian Taurus it doesn't work. The shifter on the police cars is column shift however, so the hardware is completely different.
But what you refer to is known as "Global open" and "global close", but enabling the bit, won't necessarily enable the function on the car.
______
Next up on my list of things to do is add heated steering wheel. I know how to enable the soft touch icon on Forscan to add the icon to my touchstreet and I've purchased a heated steering wheel module. Just need to find where it goes to verify the wiring is there, before I invest in a steering wheel.
I just got Forscan, found it through the ford-trucks forum looking for my 2017 f250. They have an extensive spreadsheet going on there as well.
I found this thread through google after I messed with my truck and I found really good information on here for my 2016 SHO. Climate menu on the left side did not work for me. But I was able to change the blinker to flash 4 times, added the engine hours and AWD gauge, removed the double horn honk all with your help. THANK YOU!
I found a good one today on the superduty forum, this is thanks to LIVNITUP on there and wanted to share it here as I tried it on my SHO and it worked.
APIM 7D0-02-01 5753-xxxx-xxxx
This allows the viewing of text messages as well as adding a destination in the nag screen while driving.
Apparently this didn't work with SYNCv2.0 but was confirmed to work with the leaked SYNCv3 that is out there. I confirmed it worked on my SYNCv2.2 SHO this evening. Now the keyboard will not be disabled when the car gets over 5 mph. No more pulling over to add a destination.
Quote from: Marobrown on September 13, 2017, 08:46:39 PM
I know this is an old thread, but just got forscan, found it through the ford-trucks forum looking for my 2017 f250. They have an extensive spreadsheet going on there as well.
Welcome there MaroBrown! This is on your 16 SHO? any pics ? Due setup an intro at your earliest convenience,thanks. Z
https://www.ecoboostperformanceforum.com/index.php/board,14.0.html (https://www.ecoboostperformanceforum.com/index.php/board,14.0.html)
That won't work on an Older Taurus running the Sync 2 setup correct?
As for engine hours. I'm struggling on this one.
720-01-02 xxxx xxxX xxxx
X = 0 engine hours off
X = 3 engine hours on.
Except when I change the bit to a 3, I get an incompatible configuration error and it won't let me write it.
Thanks, forgot about the intro, taken care of. Yes it's mine 2016 non PP, bought new in August last year. Here is a pic.
(https://i.imgur.com/lpq1n6d.jpg)
Quote from: Mustang5L5 on September 13, 2017, 09:14:05 PM
Yes, as far as I know it is only for the SYNC3 system.
The engine hours change worked for me adding the 3 in that location.
Wow missed that hrs update! Than you I just found another spreadsheet for the flex they seem to have lots of time to test things
Just to clarify....you guys are using this to write changes?
(http://www.obdlink.com/mxbt)
https://www.amazon.com/VINT-TT55502-ELM327-modified-ELMconfig-FOCCCUS/dp/B01N18TOFB/ref=redir_mobile_desktop?_encoding=UTF8&psc=1&ref=yo_pop_d_pd (https://www.amazon.com/VINT-TT55502-ELM327-modified-ELMconfig-FOCCCUS/dp/B01N18TOFB/ref=redir_mobile_desktop?_encoding=UTF8&psc=1&ref=yo_pop_d_pd)
This is what I'm using.
Thanks guys. I ordered a OBDLink MXBT. Just made some changes with it / ForScan....very cool.
So I finally decided to start doing some deep diving of how to find options first I compared identical Tauruses to see what codes changes just for vin then I have my pp vs one with nav next separate photo when I update it will be 17 sho with nav vs 17sho with everything but pp don't remember if the nav has a moon roof think it did.
Also was going to add name of what modules they correspond with so that picture will probably be changed soon as well
(https://uploads.tapatalk-cdn.com/20171119/0ae0ba7089eab63a3639cbe44abe497f.jpg)
(https://uploads.tapatalk-cdn.com/20171119/3c31d1a12c2a2c65b0418dae5f11702a.jpg)
I saw somewhere there is a "compare" program that will read the as built files. Would that help / make it easier when comparing.
Quote from: WhitePlatinumSHO on November 19, 2017, 09:20:09 AM
This is how I'm doing this only writing down the difference but also noting where and how.
Later ignoring all the ones that seem only changed by vin I'm going to plug everything in and see if I can turn anything on also see what type of hex I need to turn it on 1 or 0 or a or h already possibly noticed something's have changes in 3 lines but we usually only make one change
So I broke my laptop screen don't feel like paying 300 for a new one unless someone has a hook up for $50 on a 15in Vaio laptop
So no more playing with forscan probably till May.
:o don't think it is as easy to find laptop screens as it is cheap digitizers for smartphones ...
Gjkrisa nice work posting all this forscan stuff...I never really read it but now you convinced me to grab it up..I have an ids tool that I used a while back to install a boss 302 cluster in my mustang gt
Question: can forscan do pmi or programmable module installation ?...I needed the ids to do that for the cluster swap
Quote from: Gjkrisa on January 18, 2018, 06:34:36 PM
Most Laptops have secondary video output. As long as your screen is not totally dead and even if it is. You can hook it up to any TV or monitor. Usually there is a key for it on the keyboard. Hit secondary function key (blue) and it sometimes is F4 . Look for a dual screen picture on your keyboard.
I mean as for playing in the car with it I use currently for a media box
Quote from: Gjkrisa on January 18, 2018, 11:41:46 PM
Ahhhhh Gotcha.
I am sure you know and they can be a pain to install but you can buy new screens.
Lenovo has decent refubs and such in their outlet. I dont trust Ebay for used/refurb Laptops.
https://www3.lenovo.com/us/en/outletus/consumer-notebook/lenovo/100s-series/Lenovo-N23/p/80UR0002US
Quote from: Macgyver on January 19, 2018, 05:18:17 PM
Ahhhhh Gotcha.
Wow these are about the same prices as eBay thank you and reason I don't want to buy a new screen be more then a used laptop
I have gotten over 5 but less than 10 over the years from here. They always look and seem new. No complaints. Just make sure you get a Non Chrome one. ;-)
Quote from: Gjkrisa on January 19, 2018, 07:24:55 PM
Ahhhhh Gotcha.
I had a great experience with these folks...
https://us.refurb.io/
Owned it for a while now, zero problems and it was perfect when it arrived.
Quote from: sholxgt on September 08, 2017, 06:49:33 PM
What is your VIN. I'd love to see the as built. I was able to turn on globalup and down on my 17' F150 when neither is enabled from the factory.
I've used FORscan so far to do the following.
1. 5 blinks for quick turn signal.
2. AWD gauge
3. Added time to the engine off radio off delay.
4. Removed the horrible Performance Pack EPAS steering programming. I changed to standard SHO. So much better! Might try a limited code and see if that's different.
What I'd like to do next is..
1.Global roll up/sunroof close or auto sunroof close when car is shut off. My old Marauder did this. I miss it dearly.
2. Front LED accent lights set on as DRL without other lights on.
What is the max time you could put into the Radio off delay?
Yeah that sun roof auto close would be great.
So has anyone found anything useful for the pre 2013 SHO/MKS?
One thing I would like is to have my gear display at all times instead of just when in manual mode.
Quote from: FoMoCoSHO on February 04, 2018, 03:08:46 PM
You want gear display, I'll give it to you.
Quote from: AJP turbo on February 04, 2018, 03:19:45 PM
Awesome, thanks!
I agree. Legit question doesn't need a 13 year old reply.
Gjkrisa im confused by the last couple posts.
Fomo was saying he was hoping to get gear display on his car. So I simply said if you would like it then I will give it to you in your tune...I'm not sure what the 13 year old comment was all about or from who?
I did think it was a legit question and that my response could not have been any more clear
I'm lost?
I think he's referring to SHOwoosh's comment?
It didn't bother me but it is his thread and I respect his desire to keep it clean and on topic.
Quote from: AJP turbo on February 04, 2018, 11:55:49 PM
I'm lost?
Yes if that is truly what you mean then i am sincerely sorry. It's hard to get full context thru just a few 2d words.
Cool video i found decifer hex for changing odometer in Toyota Corolla
Isn't odometer tampering of any sort illegal?
Quote from: FoMoCoSHO on February 07, 2018, 11:14:35 PM
Oh yeah...That looked like an old cluster...I had to jump through hoops to even buy a boss cluster for my mustang GT and the car won't start with a different cluster....And I had to buy my own IDS because the dealer wouldn't do it. But it was worth it because I got great satisfaction when I told the dealer I'd do it myself and he said only Ford techs can get IDS and I laughed and said I already have it lol
Yes it is but learning how to do it is very fun
Could this be used to make the massage chairs pop up on the sync screen? That way I can adjust the speed, turn both bottom and back massagers on, all on the screen.
I know the 2015s can do this, but I have a 2013 and really want this option to control the seats massagers through the sync screen
Please let me know anyone
Quote from: gotpball44 on March 28, 2018, 03:32:16 AM
I'd say probably you can use http://www.compulsivecode.com/Project_AsBuiltCompare.aspx if you know a VIN that has what you want you can find a car with that option think your going to be looking in the apim area
https://www.motorcraftservice.com/quickguides/quickguides then go-to asbuilt info
Finally got some more time to play don't know if anyone else has had these same questions but autounlock driver 1-4 I'm guessing is for each driver key not sure how you would program what is 1 thru 4 but I think I remember when I got my keys it was labeled what one was the master key so I picked that one gave my wife the second one so that should be 1 and 2 then how ever you add the next chooses 3 and 4
I'm guessing autounlock vehicle level is just when you drive off it will autolock
I found d out two stage unlock is just how many times you hit unlock on the fob one stage unlock all four two stage driver then the 3 others
Pase configuration I tried inop I don't know what that stands for but makes it where the key has to be in the chip holder spot to read the key to state the car
Haven't tried disabled affraid it may not let me use the push start button to let me reconnect and change it back
Not sure what passive keyfob does key still works when I disabled to lock unlock and start car using the touch sensors or from key (https://uploads.tapatalk-cdn.com/20180804/29945f45306e1748d2db086e8e43538d.jpg)
There was a hardware change that allows for this. The 2013 massagers do not communicate with the APIM so while you may be able to add the buttons on screen they will NOT work with the 2013 massager modules. The 2015+ I believe will also let you use the back and butt massagers at once where earlier ones are either or.
Quote from: LostnEye on August 06, 2018, 05:16:29 PM
X2 could only play with the (Butt) massage feature on the 2015MY! Z :D
With my 2016 I can have both on
Looks like 2016+ then.
Something I wish I could add, which was standard on my Lincoln LS was syncing the heated/cooled seats with the climate controls so they would get cold/hot based on how much AC/heat the climate control was calling for. That car had hard buttons for heated and cooled, pressing both together would sync them. My Navigator has the same buttons but would not do it.
Quote from: LostnEye on August 08, 2018, 12:50:14 PM
The AC seats are just blowing air from the rest of the system into the seats so having the AC seats on will adjust temp of the seat to same as air. Same with heat I noticed that by raising the main temp that my seats would get warmer or colder from 72-80 I felt the most difference
Quote from: Gjkrisa on August 08, 2018, 01:59:33 PM
What I am saying is with the LS you could set them as "always on" and would automatically cool or heat based on the climate control setting. You wouldn't have to turn them on manually anymore, similar to the remote start in the Taurus where you can have them come on while the car is warming up. From the Lincoln owners manual:
Automatic heated/cooled passenger seat: To engage, press the
passenger side heat and cool seat controls simultaneously. The center
light above the passenger side heated and cooled controls will illuminate
and the display will show . This allows the seat to automatically heat
or cool based on the climate control temperature selected. Press either
control to disengage.
Quote from: LostnEye on August 08, 2018, 02:11:02 PM
Even after turning off then back on the seats stayed syncd?
On the LS yes.
Tons of good info in this thread.
Turned global up on for the windows.... no go.
Awd gauge works.... neat... I'll see how it does on the ice this winter, lol
Global down works. Cool feature, but no global up seriously takes away from it.
I'm pretty disappointed we can't get the TPMS gauge/info. I suppose I should have read more into it, but that was the main reason I wanted forscan. With the aggressive temperature changes we get it'd be good info to have.
Not sure what else is needed or if there's anything else I want to change.
Thanks to all those who experimented and put out the relevant info!
Quote from: ToMang07 on August 29, 2018, 11:12:03 AM
I banged my head for a few days trying to figure out global up when this thread got rolling, it's a bummer. But hey, if it starts raining hard at least you can run all the windows DOWN. smh..
Lol, serious derp on Ford's part.
Quote from: Izzybird on August 29, 2018, 12:12:17 PM
I've read thru the posts and couldn't find if anyone has asked this silly/dumb question.
Can you use the OBD adapter from your handheld tuner unit (IE SCT) and connect with laptop hdmi port using FORScan? Or is the best approach to get a bluetooth adapter? I dont mind using my laptop and plan on using it for diagnostics to see if a miss-fire is occurring. Possibly looking at Mode 6 diag results to see if its below the min/mav values and therefore not throwing a CEL.
Thanks in advance.
HDMI? I don't think you can do that without an HDMI-Bluetooth or HDMI-Wifi Converter. Usually a USB port or Wifi is the way to connect depending on the revision of the tuner.
Quote from: SHOdded on November 21, 2018, 01:05:07 PM
I was thinking of trying to use the OBD adapter from my SCT and connecting it directly to my laptop and seeing if it will connect.
I've attached the image of the adapter that came with the SCT I mentioned above. It may not work at all. Probably figures why no one has mentioned it because it is a dumb question lol!
Do you have a closeup of the connector - certainly looks like an HDMI ... HDMI can be spec'd to carry Ethernet, so possibly using that?
https://www.cmple.com/learn/learning-center-hdmi-cables-with-ethernet (https://www.cmple.com/learn/learning-center-hdmi-cables-with-ethernet)
If your laptop is able to pick up the ethernet thru HDMI is may be possible all the can signals are pretty close to the same so I have read but haven't gotten that far in the actual reading of everything.
You maybe abel to wire or get a HDMI converter to some other port like HDMI to vga then strip a VGA cord then convert it to serial but that is very complicated and probably around the same price of just getting a dongle but if you were to figure it out it could make it cheaper for someone else
Quote from: Markboni55 on November 21, 2018, 03:39:23 PM
Hello everyone that has scanned the can Network to figure out pids I needs some help figuring out how to do this and or find of the Ford explorer sand mode sends a code in hopes to make a button you can press to have the sho going to traction control off quickly
ecoboostsho is the original pid scan meister on this forum. perhaps he will chime in or you can pm him directly.
X2 Dave (ecoboostsho) is the PID Master! Z :)
Hey there! Appreciate the references but I am far from an expert on CANBUS communications - that said I will happily chime in what I do know. (I did get your PM as well Gjkrisa). The challenge with scanning the PID's per se is that the method I used originally to figure out the numeric values for them involved using a known scan tool to do so. The modules communicate directly between them via addresses on the CANBUS so you need to be able to intercept that communication or have it originate on the scan tool. With a scan tool (like FORSCAN for instance) you could sniff the traffic between the PC and the car to see what the responses were. If you are actually trying to intercept a communication between modules (like what the Explorer does when you put it in SAND mode as the example you sent me via PM) you have to have a way to see that PID response and that won't be easy.
Bottom line is if you can replicate the action/request with a SCAN tool and use a serial sniffer to see it then we can interpret the results and possibly make some progress. Without that I don't know of a way to essentially see all of the traffic on the CAN bus and even if you could picking out the one thing you are after would be difficult because we don't really know what we are looking for.
Quote from: ecoboostsho on February 28, 2019, 10:41:43 AM
Right yeah I had gotten a log on my phone but had messed up a few times so when I finally started logging the packets it supposedly filled the 1mb buffer and only showed me 15 lines of which also have no idea what they were so yeah was curious how you could even tell what your even looking at so that makes sense
They mention on a artical on obd hacking that you just keep flipping your trigger few different patterns so you can find that one object
Thank you for that little bit of insight.
You remember any of the commands of what you used to establish connection and get it all prepared?
Quote from: Gjkrisa on February 28, 2019, 11:03:58 AM
Here are some notes I made for myself a long time ago. You may need to tweak the STP setting and the STCAFCP to get what you want (assuming all this still works). This is based on an OBDlink MX adapter which utilizes the STN1100 chip set. After you establish a serial session with the car you can type the following to set things up. You may need to tweak the settings depending on your terminal server serial connection to get the display you are after.
ATI (Just prints ELM 327 version ID string)
STI (Prints Firmware ID string)
STP53 (Sets Protocol to 53 - MS CAN as an example)
ATPC (Protocol Close)
ATE0 (Echo off)
ATL0 (Line Feed Off)
ATH1 (Headers On)
ATST32 (Sets timeout to 32ms)
ATS0 (Print Spaces off)
ATAT1 (Adaptive timing Auto)
ATCAF1 (Automatic Formatting On)
ATTP6 (Try Protocol 6)
ATBI (Bypass Initialization sequence)
ATAL (Allow long messages)
ATSH0007E0 (Set header to 00 07 E0 - this is typically your scan tool address if I recall correctly)
STCAFCP7E0,726 (Adds a flow control 11-bit ID pair, 7E0 is your scan tool and 726 is your target module address...you could request a known PID from the AWD module and see what header it responds with and use that going forward)
Here is the entire guide for the chipset...
https://www.scantool.net/scantool/downloads/98/stn1100-frpm.pdf (https://www.scantool.net/scantool/downloads/98/stn1100-frpm.pdf)
You can actually monitor all messages and then filter for what you are after...challenge is you don't know the PID but I think you could at least limit it to the communication between the module in question.
It's been quite awhile since I dug in to this so take the above with a grain of salt and maybe experiment a bit! (But don't go too crazy. :) )
Has anyone found MKS codes? I just got Forscan today. I am just trying to learn it and find out what is available and useful for my MKS. Thank you.
Forscan in any of its' versions is not customizable. Torque Pro is. If you are looking to add custom codes, Torque Pro is the way to go.
Can you take snapshots of what PIDs are available for your MKS in the PCM module? Then we can compare to what is now available with Torque Pro.
Quote from: MKS Tom on April 27, 2019, 04:35:06 AM
If you get a 2 month free license using the pc software and you find the place to make changes in the one not labeled as built it should have a pretty big list or stuff to change but not everything is changeable if you don't have the right modules
Only thing they didn't add in to preselection was changing sync3 theme
Just found this guy wial I was trying to figure out how to use forscan to control things like bleeding brake fluid thru the abs controller
This is a exel sheet for Taurus :D
I have that service function available for my 2007 Edge. If you contact them directly, they may add it for the Taurus, but it takes time.
Quote from: SHOdded on February 09, 2020, 07:39:57 PM
It already should work haven't tested it but all I have to do is add a read pid for break pressure then select the control pid for the breaks and then when I hit the play button it should open a screen to control the abs controller
Something else I found interesting at the bottom they have the "module" for 3.5
https://ecutools.eu/chip-tuning/pcmflash/
Found this today
Going to go thru see what else I can find
