I'm going to eventually swap a 160 thermostat in , before I do it can anyone tell me if I need to bleed out any air or will it bleed out itself after the install ? I'm guessing full coolant to fill line after it loses some and drive it .
with cabin heat on MAX, yes. Normally a few drive cycles and it should stabilize. If it does not, you will have to burp it. A Lisle SpillFree Funnel is helpful in these stubborn situations.
Quote from: SHOdded on March 05, 2019, 12:16:56 PM
I'll have to give it a shot
:thumb: :thumb:
Don't have an SHO.
Oh, and be careful taking the bolts off the housing. They strip easily. LME does not supply the gasket for the tsat, so you will need to reuse the old one. Note where it goes on the tstat. The nipple/vent should be in the 12 o clock position when installed.
Quote from: SHOdded on March 05, 2019, 08:31:55 PM
Don't have an SHO.
Thanks for that tip man
Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while. :)
If so, there are shop manual pages for the t-stat install and bleed procedures on this thread (reply #6): http://www.ecoboostperformanceforum.com/index.php/topic,7094.0.html (http://www.ecoboostperformanceforum.com/index.php/topic,7094.0.html)
Assuming the parts are the same, make sure you get the o-ring installed in the correct order. ;)
Quote from: MiWiAu on March 26, 2019, 03:22:03 PM
Nice good find, reishe has on their website that our cars don't need a bleed after thermostat install. The system automatically degasses itself. Refill coolant and go then .
Quote from: 18SHO on March 27, 2019, 02:38:11 PM
I experienced a little "gurgling" on mine after tstat swap, so I did a little more in depth bleed and it went away. YMMV. :)
Quote from: MiWiAu on March 27, 2019, 03:23:39 PM
Really? Describe in depth bleed if you don't mind
Quote from: 18SHO on March 27, 2019, 08:32:37 PM
It's a pdf attachment in the thread I linked above. In addition, I parked on a steep incline in an attempt to get the degas bottle to the highest point (hoping any air would evacuate easier).
I wouldn't sweat it too bad. Keep the degas bottle topped off and you can probably just drive as normal. If you hear weird noises, you could try to follow the procedure to rectify.
Quote from: MiWiAu on March 27, 2019, 08:50:03 PM
That link for bleeding doesn't work unfortunately only the install of thermostat
Quote from: 18SHO on March 27, 2019, 08:51:54 PM
Hmm. I opened the attachment just before my prior reply and it worked for me. Maybe the mods can help?
Quote from: MiWiAu on March 27, 2019, 08:56:37 PM
Got it to work! Seems simple
Thermostat first,then gasket.I would make certain to have some extra coolant on hand for a peace of mind. Z
(https://i.imgur.com/57zF5z3h.jpg)
(https://i.imgur.com/wrw65Gdh.jpg)
