Started by ONLYA6, February 08, 2014, 08:30:39 AM
Quote from: ONLYA6 on February 08, 2014, 08:53:16 PMSo I cut time O2 bung shorter and got the sensor to clear the oil cooler, barely, but now I have this. Hopefully PPE can pull through and get me another front downpipe this week. Heading to Livernois Thursday!Sent from my iPhone using Tapatalk
Quote from: ONLYA6 on February 08, 2014, 09:31:45 PMIt won't do any good. The rear downpipe is bolted up to the cat back and it's fine. Since the xpipe is right after the connection it's all rigid. Even if I loosened the Corsa exhaust back at the rear before it goes out to the mufflers since it's all one piece in the mid section I couldn't make up that much of a gap. Sent from my iPhone using Tapatalk
Quote from: EcoPowerParts on February 08, 2014, 09:01:30 PMQuote from: ONLYA6 on February 08, 2014, 08:53:16 PMSo I cut time O2 bung shorter and got the sensor to clear the oil cooler, barely, but now I have this. Hopefully PPE can pull through and get me another front downpipe this week. Heading to Livernois Thursday!Sent from my iPhone using TapatalkWe've been emailing Paul, he should respond ASAP. I'm just baffled why yours doesn't fit but Mikeb does. BTW, on my car it was like that or close to that, you take the back exhaust off the hangers, install the bolts and put it back on the hangers. Have you tried that?
Quote from: FoMoCoSHO on October 22, 2015, 04:29:00 AMQuote from: EcoPowerParts on February 08, 2014, 09:01:30 PMQuote from: ONLYA6 on February 08, 2014, 08:53:16 PMSo I cut time O2 bung shorter and got the sensor to clear the oil cooler, barely, but now I have this. Hopefully PPE can pull through and get me another front downpipe this week. Heading to Livernois Thursday!Sent from my iPhone using TapatalkWe've been emailing Paul, he should respond ASAP. I'm just baffled why yours doesn't fit but Mikeb does. BTW, on my car it was like that or close to that, you take the back exhaust off the hangers, install the bolts and put it back on the hangers. Have you tried that?Mike, was this just an issue on this car?When I got the pipes from you I had non-PP and now I have PP.
