I have to replace the turbo on the "DRIVERS SIDE" of the car, would that be considered left or right? It's the easier one in the front
Left. Imagine the engine turned 90 degrees with the belts facing the radiator. From the drivers seat perspective, bank 2 is left hand, bank 1 is right hand.
Ford Part Number AA5Z-6K682-F
Part Turbocharger
Replaces AA5Z-6K682-D
$431.83
FYI- Engine Oil, Oil and Air Filters MUST be changed to ensure proper replacement Turbo function. Z
https://parts.levittownfordparts.com/oem-parts/ford-turbocharger-aa5z6k682f/?c=Zz1lbmdpbmUmcz10dXJib2NoYXJnZXItYW5kLWNvbXBvbmVudHMmaT1NRjE2MzYwNSZyPTImYT1mb3JkJm89dGF1cnVzJnk9MjAxMyZ0PXNobyZlPTMtNWwtdjYtZ2Fz
I would change oil feed and return lines as well. Mine did not look to good at 51k when I replaced my turbos. It's not a ton more money for piece of mind
As ALWAYS thanks a million. You guy's are the "BEST"
Best of luck, then :D
Be thankful it's the front turbo. I personally think it's the easier one to do.
