I am wondering if there is a way we can get some information compiled in one place and make it a Sticky?
I do not have the answers to any of this, but was just debating a possible swap and realized this was critical information needed to make a decision that would make for a good sticky thread here in the Swap area.
If I missed one or have any of them wrong below let me know, I will update the OP as I get information. Also if there is additional info
CAR/SUV AWD 3.5ECO (Transverse mount):
- Engine Type: Transverse Mounted twin turbo V6
- Length In(mm):
- Height In(mm):
- Width at heads In(mm): 22" (559)
- Width at widest with fact. turbo In(mm):
- Width at oil pan In(mm):
- Weight lbs (kg):449(203)
- RPM Range:
- Bellhousing pattern:
- Factory trans options:
- Factory HP: 365 @ 5500rpm
- Factory Tq (lb/ft): 350 @ 1500-5000rpm
CAR 2.0ECO (Longetudenal mount):
- Engine Type: I4
- Length In(mm):
- Height In(mm):
- Weight lbs (kg):328 (149
- RPM Range:
- Factory HP: 240@5500rpm
- Factory Tq (lb/ft): 270 @ 1900-3500rpm
CAR 2.7ECO (Longetudenal mount):
- Engine Type: V6
- Length In(mm):
- Height In(mm):
- Weight lbs (kg):440 (200)
- RPM Range:
- Factory HP: 315 @ 4750rpm
- Factory Tq (lb/ft): 350+ @ 2750rpm
TRUCK 3.5ECO (Longetudenal mount) dimensions/specs:
- Engine Type: Longetudenal mounted Twin Turbo V6
- Length In(mm):
- Height In(mm):
- Width at widest with fact. turbo In(mm): 28.5 (724)
- RPM Range:
- Factory HP: 365 @ 5000rpm
- Factory Tq (lb/ft): 420 @ 2500rpm
Few updated from a wiki I found. Still no detailed measurement info though which for a conversion is the most important aspect.
https://en.wikipedia.org/wiki/Ford_EcoBoost_engine#3.5_L
