Good Morning!
Can anyone help me identify these 2 parts and part numbers - this is a 2014 PI.
First one is a small box with a big relay attached to it, this part was originally connected to the firewall side of the degas bottle (both parts connect together) I had to move it when I put in the OCC.
Second one is a hose from the intake all the way across the firewall to the driver side.
https://imgur.com/a/91xHd (https://imgur.com/a/91xHd)
The last PIC is your brake booster line for vacuum IIRC.
The first couple of pics could be a PI option only ! Dunno. Z
How many amps is the relay ?
Here's a great source for the wiring for reference on the PI.
https://www.fleet.ford.com/truckBBAS/topics/2012/modGuide.html (https://www.fleet.ford.com/truckBBAS/topics/2012/modGuide.html)
VACUUM HOSE - FORD DG1Z-9C490-B
Number 13 on Diagram below
https://parts.levittownfordparts.com/auto-parts/2014/ford/police-interceptor-sedan/base-trim/3-5l-v6-gas-engine/brakes-cat/hydraulic-system-scat (https://parts.levittownfordparts.com/auto-parts/2014/ford/police-interceptor-sedan/base-trim/3-5l-v6-gas-engine/brakes-cat/hydraulic-system-scat)
https://parts.levittownfordparts.com/oem-parts/ford-vacuum-hose-dg1z9c490b/?c=Zz1icmFrZXMmcz1oeWRyYXVsaWMtc3lzdGVtJmk9S0QwOTI5MTUmcj0xMyZhPWZvcmQmbz1wb2xpY2UtaW50ZXJjZXB0b3Itc2VkYW4meT0yMDE0JnQ9YmFzZSZlPTMtNWwtdjYtZ2Fz (https://parts.levittownfordparts.com/oem-parts/ford-vacuum-hose-dg1z9c490b/?c=Zz1icmFrZXMmcz1oeWRyYXVsaWMtc3lzdGVtJmk9S0QwOTI5MTUmcj0xMyZhPWZvcmQmbz1wb2xpY2UtaW50ZXJjZXB0b3Itc2VkYW4meT0yMDE0JnQ9YmFzZSZlPTMtNWwtdjYtZ2Fz)
Thanks for the info Z. That vacuum hose is definitely what I was looking for.
As for that degas mounted electrical box with the relay on it, I do have the truckmod guide for the 2014, but I don't see that part in either guide. There is a ford part number on it, but it doesn't seem to come back to anything that would remotely describe it.
Thanks again for the assist!
Quote from: klrsmith on March 03, 2018, 03:57:37 PM
@- klrsmith It's my pleasure. :) I guess you also got me thinking. :hmmm:
What's the actual part number ? I can try to cross-reference the part for ya.
Is there any type of bracket holding it in place ? Z
The larger main part shows DG1T-14A099-AB on it's outside cover. The Relay inside under a separate cover shows AW7T-13350-AA and I think (I can't get in there far enough to verify without taking stuff apart) but it seems to be part of a wire harness which has a EG1T-14290-KB barcode tag attached. Oh the bracket on this part is made to fit into the cutout on the degas bottle - they are literally made to fit together...
At least I couldn't find anything with those PN's - If it was part of a lighting package wiring harness, I would know that it's cool to remove it... but the lighting packages listed in the options of course only have a 3 digit option code.
www.fordpartsgiant.com (http://www.fordpartsgiant.com) usually has a broader selection of hard to find parts. Z
https://www.fordpartsgiant.com/Page_Product/PartDetail.aspx?Vin=1FAHP2MT6DG234788&Filter=()&SubCategoryUrl=wiring-covers&Diagram=&PartNumbers=5F9Z-14A099-AA (https://www.fordpartsgiant.com/Page_Product/PartDetail.aspx?Vin=1FAHP2MT6DG234788&Filter=()&SubCategoryUrl=wiring-covers&Diagram=&PartNumbers=5F9Z-14A099-AA)
Cool, that's a great site - I would guess this piece is part of a PI lighting package, part of this (at least very close harness) - EG1Z-14290-KA - "HEADLAMP PREP PACK, WIRING PREP, With Level 3 Headlamps, With Level 4 Headlamps". Tracing this harness down, I should find disconnected connectors or just cut cable - if so I'm planning to remove it. Already tight working on these freaking sideways mounted engines :-)
