https://youtu.be/_90sYQpr4ZE
Nice engineering Ford.
Probably shouldn't advertise it on YouTube.....:/
Good chance it's only my janky keypad. Check yours.
Interesting indeed! Thanks for posting and welcome back stranger. Z :)
Quote from: ZSHO on September 20, 2018, 08:57:19 PM
Z my man, I've been lurking but car has been behaving :). I'll probably end up taking the door panel off and unplugging the keypad, don't use it anyway.
My MKS does the same but my key fob has to be in range. Don't have to enter a code just touch the keypad... Even just the handle.
This did not work on my car
Quote from: StinkinLinkin13 on September 20, 2018, 09:18:38 PM
Maybe the Lincoln is different? My key was across the street so no way it would reach.
Not sure what is wrong or going on with the OP's car but that is not normal at all. We have a Taurus and a Lincoln and you can't do that with either of them without the fob close by. Same with my old MKS....fob had to be in the general area. I am not sure exactly HOW close it needs to be, though.
Quote from: Brucelinc on September 21, 2018, 09:30:27 AM
same here bruce
I just tried this. Works when my key is in my pocket. Doesn't work when my key is in the house.
Quote from: polskifacet on September 20, 2018, 09:12:53 PM
Polski do you happen to have the code! I would try to change the code IMO! Hope it helps any....
BTW I can confirm it does NOT work on my car. Z
Page 74
https://drive.google.com/file/d/1yxQq6tiQM2x9ntd-FKwjznWNilqK3-8v/view?usp=drivesdk
Maybe try taking the battery out or wrapped in tinfoil see if it still works .
I will try to have the key outside the house but not in distance for the key to work by the handle and see if it works.
I also didn't have a secret button over the 1/2 I had to be a hair over the area for the number
If you have access to forscan it can tell you your factory code
Quote from: ZSHO on September 21, 2018, 12:45:49 PM
Polski do you happen to have the code! I would try to change the code IMO! Z
Page 74
Didn't work on my car tried it multiple times
This works for my car IF the key is within 5' of the car. ( I just put new battery in the fob)
Even key in my pocket didn't do it
Unless they changed the button or had to wait had to lock door first did it with the keypad
Hilarious my user code was set to five 1
Hahaha that explains it
Quote from: polskifacet on September 26, 2018, 10:03:21 PM
That's amazing! I've got the same combination on my luggage!!!!
