Detailing, SYNC, AV, Security, Electrical, and Lighting => Interior Modifications => Topic started by: Spyder3000gtvr4 on March 18, 2019, 11:08:38 AM
Title: Connect issue see dealer on the radio, which fuse?
Post by: Spyder3000gtvr4 on March 18, 2019, 11:08:38 AM
I searched the forum and can't find it. It's happened once before and couldn't verify which fuse it was so I disconnected the battery for the night. Since it happened again after a few hundred miles I figure this is a thing that's going to happen fairly often and would like to just pull the fuse for 5 minutes. Anybody know exactly what fuse this is? 2010 sho
Title: Re: Connect issue see dealer on the radio, which fuse?
Post by: SHOdded on March 18, 2019, 05:58:52 PM
try fuse 14 (10 amp) in the passenger compartment fuse panel.
Post by: Spyder3000gtvr4 on March 25, 2019, 05:39:37 PM
Thanks for the info, It turned out to be fuse 39 20amp. I've read that you only need to remove it for a few minutes (I did an hour) hopefully this helps somebody else.
