Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Recalls, TSBs, SSMs and Investigations => Topic started by: SHOdded on February 13, 2017, 07:15:47 PM
Title: Lincoln Continental
Post by: SHOdded on February 13, 2017, 07:15:47 PM
2017 Escape/MKC/Continental – Battery Discharge – With Or Without Repetitive Cycling Compact Disc (CD) Ejecting Noise – Built On Or Before 23-Dec-2016
Some 2017 MKC and Continental with all audio systems and 2017 Escape with Sony audio systems built on or before 23-Dec-2016 may exhibit a discharged battery.
A repetitive cycling noise similar to a CD ejecting noise may also be present.
If excessive battery drain is present and eliminated with the radio battery power fuse removed, reprogram the audio control module (ACM) to the latest calibration using the Integrated Diagnostic System (IDS) release 103.05A or higher.
Make sure you are connected to the internet when entering module programming to obtain the latest updates.
Calibration files may also be obtained at www.motorcraftservice.com (http://www.motorcraftservice.com).
Module Reprogramming & Initialization
Software necessary to program electronic modules to the latest calibration level, perform module initialization (PATS), and set Programmable Parameters on Ford, Lincoln and Mercury vehicles.
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
    Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
    Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
Latest Calibration Information
Module Build Data (As-Built)
Use VIN to obtain As-Built data
Title: Re: Lincoln Continental
Post by: SHOdded on March 16, 2017, 03:59:41 AM
2017 Continental – Heated Seats Inoperative During A Remote Start – Built On Or Before 14-Feb-2017
Some 2017 Continental vehicles built on or before 14-Feb-2017 may exhibit heated seats that are inoperative during a remote start event.
Reprogram the drivers seat module (DSM) using IDS software 104.03 or higher.
Post by: SHOdded on March 16, 2017, 04:00:32 AM
2017 Continental – Seat Control Switches And/Or Memory Preset Buttons Inoperative – Built On Or Before 30-Aug-2016
Some 2017 Continental vehicles may exhibit a front right side and/or front left side power seat switches which are inoperative. The memory preset buttons may also be inoperative.
Post by: SHOdded on July 26, 2017, 10:48:44 AM
2017 Continental/MKZ – 3.0L – AWD – All-Wheel Drive Malfunction Warning Message/Wrench Light – DTC U2008 – Built On Or Before 12-May-2017
Some 2017 Continental/MKZ vehicles equipped with 3.0L engine and all-wheel drive (AWD), built on or before 12-May-2017 may exhibit an all-wheel drive malfunction warning message/wrench light along with DTC U2008 that occurs when using a conveyor type car wash.
Connect the Ford Integrated Diagnostic System (IDS) or equivalent and check the AWD module for DTCs.
If DTC U2008 is stored, then reprogram the AWD module to the latest level using IDS release 106.02 or higher.
Post by: SHOdded on July 26, 2017, 11:09:43 AM
2017 Continental – Easy Entry Exit Steering Wheel Feature Does Not Move Far Enough When Entering/Exiting Vehicle – Built On Or Before 31-May-2017
Some 2017 Continental vehicles built on or before 31-May-2017 may exhibit a steering wheel that does not move far enough when entering or exiting the vehicle.
Reprogram the column and pedal module (CAPM) to the latest calibration using the Integrated Diagnostic System (IDS) release 105.04 or higher.
Post by: SHOdded on February 14, 2018, 06:09:37 PM
https://www.ecoboostperformanceforum.com/index.php/topic,6726.msg133448.html#msg133448 (https://www.ecoboostperformanceforum.com/index.php/topic,6726.msg133448.html#msg133448)
TSB 17-2235 2.7L/3.0L – Oil Consumption With DTC P0524 And/Or P06DD, Rough Idle, Misfire And/Or White Or Blue Exhaust Smoke – Built On 1-Apr-2016 And Through 1-Jan-2017
Post by: SHOdded on March 14, 2018, 06:44:01 PM
April 12, 2017 MANUFACTURER COMMUNICATION NUMBER: SSM 46522
Summary
2013-2017 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police/Continental vehicles equipped with a 3.5L or 3.7L engine, all wheel drive (AWD) and a power transfer unit (PTU) that is being repaired or replaced for an internal failure must also have the vent hose replaced due to contamination in the hose.
Post by: SHOdded on August 01, 2018, 05:37:46 PM
SSM 47403 – 2017-2018 Continental, 2018 Navigator – Outside Front Seat Bolster Support Bracket Available For Service
Some 2017-2018 Continental and 2018 Navigator vehicles may exhibit an outside front seat bolster support bracket that is broken or cracked.
The outside front seat bolster support bracket is now available as a separate service part.
Base part number 9960328. When ordering, please refer to the parts catalog for the VIN specific application.
APPLICABLE VEHICLES
2017 – 2018 CAR: PL D544N CONTINENTAL
2018 TRUCK: B9 U554N NAVIGATOR
Post by: SHOdded on August 01, 2018, 06:10:00 PM
SSM 47378 – 2015-2018 Various Vehicles – 2.7L/3.0L EcoBoost – Crankshaft Pulley Bolt Torque Procedure
During service and repair of the 2.7L/3.0L EcoBoost achieving proper torque of the crankshaft pulley bolt is critical. Incorrect torque may allow the bolt to loosen resulting in the timing gear breaking and engine damage.
Replacement of the bolt is critical to the repair.
The bolt requires a 4 stage torque procedure.
Hold the pulley using a universal holding tool OTC 4754 or equivalent.
Stage 1: 225 Nm (166 lb.ft)
Stage 2: Loosen 360°
Stage 3: 35 Nm (26 lb.ft)
Stage 4: 270°.
Refer to the Workshop Manual (WSM) Section, 303-01.
The bolt torque procedure can be found in the crankshaft front seal removal and installation procedure or in the engine assembly procedure.
APPLICABLE VEHICLES
2015 – 2018 CAR: DQ CD539N EDGE
2015 – 2018 TRUCK: FC P552N F-150
2017 – 2018 CAR: C7 CD391N FUSION
2016 – 2018 CAR: D9 U540N MKX
2017 – 2018 CAR: C9 CD533N MKZ
Post by: SHOdded on September 01, 2018, 02:05:21 AM
Customer Satisfaction Program 18B19 – Exterior Door Handle Replacement – 2017 Lincoln Continental
August 21, 2018
TO: All U.S. Ford and Lincoln Dealers
SUBJECT: Customer Satisfaction Program 18B19
Certain 2017 Model Year Continental Livery Vehicles
PROGRAM TERMS
This program will be in effect through August 31, 2019.  There is no mileage limit for this program.
AFFECTED VEHICLES
Vehicle    Model Year    Assembly Plant    Build Dates
Continental Livery    2017    Flat Rock    August 1, 2016 through June 16, 2017
Affected vehicles are identified in OASIS and FSA VIN Lists.
REASON FOR THIS PROGRAM
In some of the affected vehicles, customers may not be able to open a door from the outside due to intermittent failure of the door handle.
SERVICE ACTION
Dealers are to replace all four exterior door handles.  This service must be performed on all affected vehicles at no charge to the vehicle owner.
LABOR ALLOWANCES
Description    Labor Operation    Labor Time
Replace All (4) Exterior Door Handles (Front and Rear)
    Includes time to retrieve and clear DTC's per WSM front interior door panel R&I procedure
    Includes time to perform power door window initialization per WSM front door window glass R&I procedure
   18B19B    2.6 Hours
Additional Time To Paint New Exterior Door Handles    18B19C    1.0 Hours
PARTS REQUIREMENTS / ORDERING INFORMATION
Description    Order Quantity    Claim Quantity    Part Number
Paint Material Allowance    As Needed    PAINT
Exterior Door Handle Assembly – Right Front    1    1    GD9Z-5422404-ADPTM
Exterior Door Handle Assembly – Left Front    1    1    GD9Z-5422405-ADPTM
Exterior Door Handle Assembly – Right Rear    1    1    GD9Z-5426604-ADPTM
Exterior Door Handle Assembly – Left Rear    1    1    GD9Z-5426605-ADPTM
Order your parts requirements through normal order processing channels.  To guarantee the shortest delivery time, an emergency order for parts must be placed.
NO RENTALS APPROVED!!!
Post by: SHOdded on September 01, 2018, 02:12:32 AM
Customer Satisfaction Program 18B20 – Seat Back Bolster Replacement – 2017-2018 Lincoln Continental
August 21, 2018
SUBJECT: Customer Satisfaction Program 18B20
Certain 2017-2018 Model Year Continental Livery Vehicles
PROGRAM TERMS
URGENCY / EXPIRATION DATE
This Customer Satisfaction Program has an expiration date of August 31, 2019 to encourage dealers and customers to have this service performed as soon as possible.
We recommend dealers utilize their FSA VIN Lists name and address available by September 19, 2018 to contact customers with affected vehicles.  This will help minimize the number of vehicles that may have cracked seat back bolsters, which may require a more extensive repair.
AFFECTED VEHICLES
Continental Livery    2017-2018    Flat Rock    August 1, 2016 through February 21, 2018
In some of the affected vehicles, the front driver or passenger seat back bolster may crack, resulting in a loose outboard bolster and/or a gap between the foam trim and surrounding plastic.
LABOR ALLOWANCES
Replace both front seat back bolsters    18B20B    1.0 Hours
Seat back bolster    2    2    GD9Z-9660081-BC
Post by: SHOdded on September 01, 2018, 02:16:03 AM
SSM 47487 – 2017-2018 Continental – Front Interior Courtesy Lamps Turn On Uncommanded – Built On Or Before 1-Dec-2017
Some 2017-2018 Continentals built on or before 1-Dec-2017 may exhibit an intermittent concern where the front interior courtesy lamps turn on uncommanded.
This may be due to a circuit board fault within the overhead console.
If this condition occurs, do not replace the body control module (BCM), suspect the overhead console to be the cause.
APPLICABLE VEHICLES
Post by: ZSHO on February 15, 2019, 11:43:52 AM
LINCOLN CONTINENTAL DOOR LATCH RECALL INCLUDES 28,200 CARS
Lincoln Continental recall ordered to fix door latches that may fail to engage. Z
FEBRUARY 13, 2019 — A Lincoln Continental door latch recall has been ordered for more than 28,000 cars in the U.S. and Canada.
The 2017-2019 Continentals may have door latch motors that suffer from contamination from silicon, resulting in latches that don't fully engage.
Ford says there haven't been any reports of crashes or injuries, but a door unintentionally opening while driving is a good possibility.
The recalled Lincoln Continental cars were built between November 30, 2015, and November 14, 2018, with the majority (27,000) located in the U.S. and the remaining 1,200 cars recalled in Canada.
Lincoln dealers will replace the door latch assemblies on all four doors of the Continentals, but the automaker didn't announce when recall notices will be mailed.
Drivers concerned about their doors flying open should call 800-521-4140 and ask about recall number 19S03
http://m.carcomplaints.com/news/2019/lincoln-continental-door-latch-recall.shtml (http://m.carcomplaints.com/news/2019/lincoln-continental-door-latch-recall.shtml)
