So driving a 55mph highway the other night, it was cold (single digits) and I went to WOT to pass someone. About 1/2 way through the pass the engine stuttered (felt like a missing cylinder) and the CEL came on flashing. It stayed like that for roughly 5 minutes (FELT like a lot longer) and then it went out, and back to normal. No codes popped up in the info screen and none registered in the system, still haven't scanned it with Forscan.
I will say my brother's truck had this issue last winter, at which time we changed the plugs. His truck (14 F150 3.5L ecoboost) hasn't worked yet so far since we started getting this cold winter weather, but he says it happens somewhat frequently to him when it's cold and he gets on it.
Is this common? Anyone else experienced this? Any known solutions? I have an unknown "cold weather" tune for the car that I may try and see if it replicates. NOT COOL. Limp mode when your passing someone is dangerous as ****.
What was engine and trans temperature at that point? Any idea? Do not recommend WOT until the trans is at least past 100F, preferably 140F.
I don't think it is a fluid not high enough type issue, but it could be.
When was fluid last completely exchagned out?
Still running 93 octane? What brand? Some brands are better behaved, even some stations within a brand, than others. Cannot take for granted.
Tranny/oil/coolant were all up to temp, probably had driven 20+ miles at that point. Oil pressure was good/normal.
I run strictly 93 from Citgo, since that's the only station around that carries 93. The car only JUST broke 60k miles, running Amsoil. Planning to do a drain/fill on the tranny in the spring. Boost Juice as well.
Have you found anything else wrong?.. my sho does the same with all tunes! And it sucks takes away the fun out of the sho
I would have the Ford dealer Reflash your PCM to the latest updates applicable to your vehicle. Z
TSB for the 13-SHO..
Repair
Number: 16S31S3
Date: 10/26/2016
Title: Recall - Fuel Pump Malfunction May Cause Engine Stall
Number: NHTSA16V621000
Date: 08/25/2016
Title: Cooling Sys. - Coolant Pump Warranty Information
Number: GSB-0000083
Date: 03/01/2016
Title: Computer and Controls - No Network Communication
Number: GSB-0000052
Date: 12/07/2015
Title: Recall - Fuel Delivery Module Replacement, Possible Fires
Number: 13S04S5
Date: 12/01/2015
Title: SRS System - Air Bag Squib Connector Information
Number: GSB-0000065
Date: 12/01/2015
Title: Powertrain Management - Historical DTC's
Number: GSB-0000067
Date: 12/01/2015
Title: CAN System - Testing Information
Number: GSB-0000043
Date: 11/01/2015
Title: Infotainment - Touch Screen Warranty Information
Number: GSB-0000049
Date: 11/01/2015
Title: Body - Paint Defects Warranty Information
Number: GSB2096
Date: 10/22/2015
Title: Body - Exterior Mirror Damage Warranty Information
Number: GSB2104
Date: 10/22/2015
Title: Recall - Steering Control Module, Steering Gear Replacement
Number: 15S18S1
Date: 10/01/2015
Title: Recall - Interior Door handle Inspection and Repair
Number: 15S02S2
Date: 07/30/2015
Title: Recall 15V340000: Loss of Power Steering Assist
Number: NHTSA15V340000
Date: 06/02/2015
Title: Engine - Excessive Oil Consumption, Smoke From The Exhaust
Number: 15-0086
Date: 05/27/2015
Title: A/T - 6F35 Fluid Leak From Left Halfshaft Seal
Number: 15-0079
Date: 05/18/2015
Title: Tire Monitor Sys - TPMS Identification
Number: GSB-0000053
Date: 05/01/2015
Title: Drivetrain - Fluid Leak From Power Transfer Unit (PTU)
Number: 15-0056
Date: 04/17/2015
Title: A/T - Shift to Park or Trans. Not In Park Message Displayed
Number: 15-0047
Date: 03/31/2015
Title: Recall 15V040000: Interior Door Handle Inspection
Number: NHTSA15V040000
Date: 01/28/2015
Title: Drivetrain - Pop/Click/Ting Noise on Turns or Acceleration
Number: 14-0186
Date: 10/10/2014
Title: Infotainment - Ambient Lighting Defaults to White, Ice-Blue
Number: 14-0175
Date: 09/24/2014
Title: Recall - Possible License Plate Lamp Overheating/Fires
Number: 14R01
Date: 09/16/2014
Title: Campaign - ECM Update Warranty Ext. for ABS Communication
Number: 14N02
Date: 08/26/2014
Title: Fuel System - Easy Fuel(R) Capless Difficult Nozzle Operation
Number: 14-0132
Date: 07/23/2014
Title: Recall - License Plate Lamp Assembly Replacement
Number: 14S08S1
Date: 07/23/2014
Title: Recall 14V393000: Halfshaft May Separate from Transaxle
Number: NHTSA14V393000
Date: 07/02/2014
Title: Audio System- HD Radio Inoperative, DTC U3000:96
Number: 14-0123
Date: 07/01/2014
Title: Recall - Right Front Halfshaft Retention Inspection
Number: 14S10
Date: 07/01/2014
Title: Recall 14V285000: License Plate Lamp Fires
Number: NHTSA14V285000
Date: 05/29/2014
Title: Engine Controls - Rough Idle, DTC P0087 Set
Number: 14-0105
Date: 05/21/2014
Title: Campaign - ECM Update for Various Issues
Number: 13B16
Date: 05/14/2014
Title: Drivetrain - Fluid Leak From Rear Differential Vent Cap
Number: 14-0057
Date: 03/19/2014
Title: Navigation System - Display Offset or Incorrect Position
Number: 14-0037
Date: 02/28/2014
Title: Interior - Headliner Loose/Dropping Down at Back Window
Number: 14-0023
Date: 02/06/2014
Title: Body - Dirt Accumulation on Rear Door Scuff Plates
Number: 13-12-2
Date: 11/20/2013
Title: Infotainment - MyFord/MyLincoln Touch(R) Various Issues
Number: 13-10-6
Date: 10/04/2013
Title: SYNC(R) - Various Functionality Concerns
Number: 13-9-22
Date: 09/27/2013
Title: Keyless Entry - Intermittently Inoperative IKT
Number: 13-8-7
Date: 08/22/2013
Title: Recall - Fuel Delivery Module Cracks, Fuel Leaks
Number: 13S04S4
Date: 08/19/2013
Title: Campaign - MyFord/MyLincoln Touch(R) Performance Upgrade
Number: 12A04S4
Date: 08/09/2013
Title: Recall - Rear Door Child Safety Lock Test/Replacement
Number: 13S07
Date: 07/22/2013
Title: Recall 13V270000: Child Safety Lock Unlocks Without Notice
Number: NHTSA13V270000
Date: 06/06/2013
Title: Recall 13V227000: Fuel Delivery Module Cracks
Number: NHTSA13V227000
Date: 05/31/2013
Title: ABS/TCS - Service Advancetrac(R) Warning ON
Number: 13-5-13
Date: 05/21/2013
Title: A/T Controls - Intermittent No Upshift, No DTC's Stored
Number: 13-4-16
Date: 04/25/2013
Title: Navigation/GPS - Unable To Locate Vehicle Or GPS Concerns
Number: 13-3-11
Date: 03/21/2013
Title: Electrical - Various Electrical Systems Malfunctions
Number: 13-3-1
Date: 03/07/2013
Title: Memory Sys - Incorrect Easy Entry/Exit Steering Column Position
Number: 13-1-1
Date: 01/10/2013
Title: Audio System - Display Stays On 20-30 Seconds After Key Off
Number: 12-11-8
Date: 11/15/2012
Title: My Ford/Lincoln Touch(R) - Various Issues
Number: 12-11-1
Date: 11/05/2012
Title: Campaign - BCM Update For Improved A/C Performance
Number: 12B43
Date: 09/27/2012
Title: Engine Controls - Missing PIDS For AWD/4WD Diagnostics
Number: 12-7-3
Date: 07/19/2012
Quote from: El_SHO on December 08, 2018, 12:00:43 PM
Hasn't done it again as of yet. I passed a semi today @120mph (50-120 WOT) and not a hiccup. It was in the single digits here this morning. 6*F
Quote from: ZSHO on December 08, 2018, 12:18:29 PM
I would try to update and Reflash your PCM @ your local Ford dealer. Z
I don't believe a reflash will do any good on a tuned vehicle, will it?
It might if there is an update to the Ford calibration. Then you would need to get an updated calibration from Unleashed and put that on, after updating the X4 of course.
Yeah, means I'd have to buy new tunes. Unleashed has no interest in working with me since I'm not the original owner.
Quote from: ToMang07 on December 08, 2018, 12:22:47 PM
Was that on your stock tune?? So I'm guessing the cold doesnt have anything to do with it studdering
What fuel setup are you running on stock vs tuned?
I've been on stock tune going on 2 months... I was chasing a ghost also I've change all fluids replaced plugs with different gaps, cleaned map and maf and throttle body with no luck. I even got with torrie from unleashed and he didn't seem like he was to worried he just asked if I had recently done the fluids and to replace plugs with 542 gapped at .025
Quote from: SHOdded on December 08, 2018, 03:31:50 PM
No, I have a 3-bar so I can only run tuned.
I'm running stock fuel/turbos/injectors.
Quote from: ToMang07 on December 08, 2018, 02:26:36 PM
WTF? Is that usually policy? I would be emailing another tuner ASAP. Quite a few of us use AJPTurbo. Brad (the tuner) does a great job.
Quote from: sm105k on December 10, 2018, 09:41:05 AM
Apparently.
Some "warranties" travel, some don't. I guess Unleashed's does not, but I also assume it to be common practice unless you are on a first-name basis with the tuner.
Quote from: SHOdded on December 10, 2018, 10:36:52 AM
I get that, however if I am the new owner I don't expect changes or anything for free from the tuner. However, I would expect some type of support or direction, because everyone's "tastes" are different. Maybe I have read into this completely wrong?
Well, if you know what mods u got, and what you would like to change, yes, the tuner should be able to give you some support in that regard. What is safe, what not, in a manner that is not a significant time investment on the tuner's part. That said, yes, some tuners are more "forthcoming" in that regard. Whether because they have it in their business model, whether it is just who they are, etc. Different people are comfy with different levels of support.
Technically your a new customer as you have never paid for a tune I guess. Torrie is notoriously short winded and doesn't offer much help with issues other than "try this one" or "it's not the tune it's your car"
I would suggest pinging AJPTurbo or Gearhead since you already have an SCT device.
If the car was tuned during the summer then I would be willing to bet the issue is fuel pressure. Torrie tunes to the max at any given time. A lot of Unleashed customers have a summer and winter tune.
Quote from: StealBlueSho on December 12, 2018, 04:33:47 PM
This is very true my dad has tunes from unleashed on his ecoboost mustang. I believe he said not to run the tune under 50 degrees. I may be off on the exact temperature.
+100; I have had dangerous luck with a previous well known high volume tuner. Go with AJP or livernois. I go with AJP as he is more than happy to lend a few ideas for troubleshooting.
Quote from: TopherSho on December 14, 2018, 09:36:26 AM
One of the many reasons I am tuned my AJP. Oh...and my car flat out does work.
Well, I planned on buying newer tunes. However Torries lack of interest has ensured I'll look elsewhere.
My experience with Torrie's tunes was extreme lack luster. In fact I am lucky to still have my stuff in proper running order. Probably a good choice to go elsewhere.
I have both unleashed and Ajp tunes. Brads first revision that Im still currently running is as just as fast as my unleashed race tune. Don't quote exact boost numbers but I want to say unleashed is around 18 and Brad has me at 14.5. I could be off on that. I'll have to look at unleashed logs later. I can only imagine once I send brad logs and we switch to 100 fuel. I will also say brads tune feels much easier on the car around town. The car shifts and acts like it's stock unless you get in it. Torrie's tune always felt like it was hard on the transmission even driving around town. The real reason I switched to ajp was explanation and customer service. Torrie will answer you any time of day in 20 minutes absolutely. But it's one word answers, nothing technical and won't even say what was revised in the tune. It was always "looks good try this thanks torrie." I understand he may tune 50,000 cars and not have time to write out a 7 page response to me. But all you have to say is what you adjusted and maybe why. Now Brad might only answer you 1-2 times a day. But it's a long thought out email with what he's doing and why he's doing it. To me that adds an element of security. I always know what to expect when the tune is loaded.
Fair evaluation.
Quote from: shoNoff on December 15, 2018, 10:43:19 AM
If brad makes you a good 100 tune .. it will rip your face off and put you in the low-LOW 12's even with stock hardware.
One price of advice, let him soften the shifts.
Yea I seriously can't wait until I get datalogging with Brad. I ran into one issue after another last year towards the end of the season.
Quote from: shoNoff on December 15, 2018, 04:39:26 PM
You wont be disappointed!
