Wanted to throw this out there. Installing larger filter = less restriction which in turn = less vacuum on the clean side of the pcv system. The clean side is what provides the crankcase a slight vacuum while in boost.
So whats better, getting oil sucked into your intake piping or not providing this slight vacuum? UPR tries to accommodate this with a 5 ft hose from the intake pipe to their catch can but the issue of a less restrictive filter still remains.
I think it's grasping at straws and you will be fine
Quote from: AJP turbo on January 23, 2018, 03:24:09 PM
I agree it's out there. Reason I made the correlation is because I started putting my aftermarket parts back on and haven't noticed any difference in exhaust smell until I put the Air Raid on (maybe). Just for giggles I'm going to put the catch can on the clean side and see if it catches significant amounts of oil.
Found this from UPR. Looks like it would fit the location of the stock clean side nipple.
F150 Clean Side Seperator (http://www.uprproducts.com/ford-f150-billet-oil-clean-side-separator-ecoboost-11.html)
Same thread/fitting as pcv (http://www.stage3motorsports.com/UPR-Instructions-Low-Profile-Clean-Side-Separator-Dual-Valve-Cans.html)
Quote from: polskifacet on January 24, 2018, 11:53:16 PM
Rather than pay $100 for that i would just get the quick connect fitting and run a hose from the CSS to the stock nipple that way. i pulled several from a junk yard at one point. that's what i opted to do when my RX CSS was leaking except i ran a hose to a nipple in my stock air box. worked like a charm.
(https://uploads.tapatalk-cdn.com/20180125/706e14dcf38863a2eb6b2fe4fc87489d.jpg)
(https://uploads.tapatalk-cdn.com/20180125/f816b75333f472f7bcec3ae639f01e67.jpg)
(https://uploads.tapatalk-cdn.com/20180125/b11df512bbbefce156ea921b1940f722.jpg)
even so, will moving the clean side air supply fix the lack of vacuum from the bigger filter?
I'm curious if the clean side needs the slight vacuum from the suction of the turbo or it simply needs fresh air. All info I could find says that the turbo actually sucks out the crank case gas while boosting.
https://www.ecoboostperformanceforum.com/index.php/topic,4419.0.html (https://www.ecoboostperformanceforum.com/index.php/topic,4419.0.html) .Z
Thanks Z. My original idea was to cut the clean side line and put in a check valve so it cant burp out oil, only fresh air in. I have a CFM breather which gives something like a 1.5" hole for any positive pressure to escape. Think I should just execute this original plan.
Quote from: polskifacet on January 25, 2018, 04:15:23 PM
NP buddy! keep us updated on any findings! Z :)
Quote from: Colorado-SHOBro on January 25, 2018, 04:15:21 AM
I'm liking the overall custom setup CSB! Z :thumb:
Thanks Z! I'm actually really happy with the little CSS setup too. I get to keep my oem oil cap on which is nice. I have a check valve and a small amount of filter media after the barb on the quick connect fitting and there's really never oil that gets passed through the lines.
If others are looking for a CSS solution i highly suggest getting the fittings and fabbing something like this up. Cheap/easy and effective.
Sorry for the derail . . . back to your regularly scheduled thread!
Thanks for all the input guys. To keep as much of the original design as possible I pulled the trigger on a second catch can off Ebay.
SHOBro what did that front hose look like before you modified it and why did you do that? Been a while but I thought that front valve cover hose went to the airbox anyway? NO?
Quote from: AJP turbo on January 25, 2018, 11:11:53 PM
It goes to the front turbo intake piping stock, he plumbed it to the filter box.
Quote from: polskifacet on January 25, 2018, 11:20:48 PM
Isn't that essentially the same thing?
I assume he was hoping that any oil would stay in the filter box instead of going into the turbo inlet/ic
Quote from: AJP turbo on January 25, 2018, 11:25:00 PM
I originally did it because my RX CSS had a leaky seal and was leaking bits of oil on the valve cover. I've really come to prefer it to an actual separator unit though.
(https://i.imgur.com/RYrYnh3.jpg)
it's pretty much the same thing but a slightly different way to route it. I'm letting fresh air into the oem location through the nipple on the valve cover rather than the aftermarket option of using the clean side separator. looks more stock without a huge separator unit sitting on your oil neck. I really prefer to have the stock oil cap so i don't have to remove the CSS w/air tube attached to add/change oil. Also i really feel the oil neck gets a lot of unnecessary oil exposure. Sure it looks like you're catching a lot but that's oil that could be in the engine doing its job.
(https://i.imgur.com/nSiNHMr.jpg)
whereas the nipple stays pretty clean so there's less to filter to begin with.
I never get any oil in those lines so filter stays dry as a bone.
When you install a catch can it uses the nipple on the front turbo pipe for vacuum for the dirty side catch can and that's why the inlet source for fresh air is routed to the air box.
Wow Dual catch can is a nightmare. There is NO place to mount it. I'm going to have to give in and buy the CSS, at least is only $100 and maybe someone will buy my oil cap breather.
Quote from: polskifacet on February 01, 2018, 11:32:15 AM
Front bumper location?
Feel free to post the oil cap breather in the dedicated for "Sale Section"! Z :)
https://www.ecoboostperformanceforum.com/index.php/board,30.0.html (https://www.ecoboostperformanceforum.com/index.php/board,30.0.html)
I'm sure you have your reasons but why not keep $100 in your pocket and do something like i've done with utilizing the stock nipple on the front valve cover? It's just as functional if not more-so than a CSS.
Through research and talking to some bros, utilizing the suction of the turbo, which gives you slight vaccum is more healthy than equal pressure to atmosphere. The oil returns on the turbos will flow ever so slightly better etc. This is why RX & URP utilize this suction in their catch can designs. Both companies use McNally CSS. Yours is probably fine but utilizing the suction is the best for the turbo seals and piston rings and possibly 1-3% better performance (1% or less on our power level 3% with 1500hp)
Quote from: polskifacet on February 01, 2018, 11:10:56 PM
Maybe there's some fundamentals i'm missing in the design so bear with me as i'm just trying to understand. . .
How does a CSS routed to the airbox take advantage of suction from the turbos? Or function any differently than the way i have it setup other than it draws air in from the nipple rather than the oil neck?
In both cases it's still getting air from the intake and routing it to the crankcase as far i see it.
Your setup may work perfectly fine.
The front pcv line acts 2 ways. Under idle/vacuum it intakes fresh filtered air, under WOT it allows the turbo to suck crank case air while the seperator on the rear cover sees boost thus it is closed.
Physics would say that your setup has less sucking power as its further away from source of suction (turbo).
I have an Airraid intake so your solution doesn't apply.
Quote from: polskifacet on February 02, 2018, 12:27:30 AM
How would a CSS also routed to the intake provide any more sucking power?
Unless you're planning on routing the CSS hose to the nipple on the front charge pipe to draw in air from the OEM location?
Why would you want to get the suction from the clean side? Doesn't that defeat the whole purpose of it being "clean?" Under boost you get that suction from the WOT line that goes from the front turbo intake to the catch can, right?
Quote from: Colorado-SHOBro on February 03, 2018, 10:03:24 AM
Yup that would be the plan but I never ended up getting the css. I currently have a clear pipe in the stock location and it doesn't show any sign of oil.
