Ecoboost Performance => Troubleshooting, Maintenance, TSB Articles => Troubleshooting => Topic started by: StinkinLinkin13 on April 19, 2019, 11:05:13 AM
Title: RDU "Chatter" while turning?
Post by: StinkinLinkin13 on April 19, 2019, 11:05:13 AM
Kinda a longshot but seeing if anyone has experienced this symptom... I noticed yesterday when making a decent relatively slow speed turn I feel a vibration / chatter coming from the rear. I also feel it during moderate to hard acceleration... It kinda feels like the RDU clutches are engaging/disengaging really quickly.... Similar to torque converter shutter but its very obviously coming from the rear end.... I have a very generic U3000 code... Scanners giving no specifics...TIA
Title: Re: RDU "Chatter" while turning?
Post by: SHOdded on April 19, 2019, 12:11:27 PM
I know a FEW members have had issues with the RDU, the first I heard of was glock-coma.  Usually a whining or grinding sound is the giveaway.  The viscous coupling/ATC portion of the RDU is sealed (I think filled with Motorcraft Mercon LV) has only been pinpointed as a problem in an Edge living in Russia IME.  And no shuddering/chattering there either.
So I would check the wiring between the AWD/4x4 module and the ATC, and see if there are codes stored in the PCM first.  Might be a wheel speed sensor or two at fault also.  You can use AWD related PIDs to see what speed each wheel is turning at.
Post by: ZSHO on April 19, 2019, 04:29:56 PM
Have you Flashed the car recently! Sometimes similar codes would suggest you Flashed a Tune to ECU,but not quite certain its relevant in your case! Warranty still active! Z
Post by: glock-coma on April 20, 2019, 01:15:52 PM
As SHOdded mentioned I did have RDU issues. Ford misdiagnosed a pulsing vibration @50+ mph and replaced everting that turns in the rolling drivetrain minus the trans.
The RDU was replaced last and finally corrected the issue.
Post by: StinkinLinkin13 on April 20, 2019, 05:51:19 PM
I'm still under warranty which is good. I'm about 90% sure its the RDU clutches chattering when power is sent to the rear. I got video recorded from underneath I'll post later.
Post by: StinkinLinkin13 on May 26, 2019, 07:50:15 PM
***Update. So took the MKS to the dealership a few weeks ago.... They did end up replacing the RDU under warranty... Also got a new front turbo that was apparently bad (although I only mentioned feed line leak) 🤔. A new multi function switch. Plus they replaced my gutted cats... 😂😂😂.  All's well. Looks like new downpipes are in order.
Post by: SHOdded on May 26, 2019, 08:31:18 PM
Yay, Lincoln warranty!
