WHITE SMOKE and po3016 code oil in hot pipes right before throttle body 35000 miles mods include direct inject wmi ... everything but hpfp an turbos
Not familiar with thay specific code, but sounds like fuel injector so far. Any associated smells?
The P0316 would suggest the powertrain control module (PCM) has detected a misfire shortly after startup, specifically within the first 1,000 revolutions which is an emissions Based code IIRC! Z
I would NOT Drive the vehicle if gas smell is present as kindly mentioned ^^^ by SHOdded!
I would have a Ford Mode 6 Data with Power Balance performed with IDS!
Post some PICS @ your earliest convenience! TIA.
Link and Video below!
https://www.obd-codes.com/p0316 (https://www.obd-codes.com/p0316)
https://youtu.be/L-hMn4hFcmc (https://youtu.be/L-hMn4hFcmc)
Crossing fingers. But that sounds like a cracked head or cylinder liner. Is the oil on the stick muddy or foamy? is there oil in the Radiator?
Quote from: TopherSho on October 23, 2018, 09:53:54 PM
Those type of milk shakes are bad....
Quote from: sm105k on October 24, 2018, 11:48:27 AM
*potentially* could he a stuck injector also. But it is just as bad. All three are new block time :(
/crossed fingers/
Injector is fixable. Rod or block or rings, not so much.
Yeah that usually comes with a bad injector just FYI
ford said it pcv valve what yall think
Yes! It was my initial thought! That would explain the oil inside the Hot pipes AFAIK! Z
what a relief that was to hear. thought I was in deep s*** lol why do they have to update / reprogram ?
There is an updated TSB for the oil Sep and PCV!
Here is an aewsome Link below. Z :)
https://www.ecoboostperformanceforum.com/index.php/topic,8777.0.html (https://www.ecoboostperformanceforum.com/index.php/topic,8777.0.html)
https://youtu.be/fvBvaNqKScw (https://youtu.be/fvBvaNqKScw)
? oil catch can if I do that do I need fords new stuff?
The OCC will not address your current issue until the Oil Sep is removed and evacuated AFAIK! To simplify things your Oil Sep is plugged causing oil to backup through the TB. Z
