New-ish Member
Started by Ecoboost_xsport, July 11, 2020, 11:31:25 PM
Ecoboost_xsport
So I am a decently frequent poster on the SHO boards (even though I own an XSport).  The XSport board is really dead, so I don't post there much.  But I finally decided to give in and join here.  Figured I may be able to share some of my exploits and findings with the broader ecoboost family...I'm no newb to the ecoboost, but always looking to learn more...
So...hi everybody...Sacramento, CA
HOT HOT HOT!
Welcome aboard the EBPF!
802SHO
Welcome stranger lol!
SM105K
I wondered if that was you when i approved you. Welcome.
Macgyver
