So I goggled and searched but I don't see factory specs for the HPFP.
Is there a list or something somewhere? I can't imagine my 2013 Ford Flex pump is the same as the Raptor pump.
Same for the factory injectors.
Someone in the EB world please point me in this direction
If it was that easy. People would be posting here with that info.
It could be something "We" all missed so who knows.
So it seems my 13 Flex EB has a Carter replacement that's 29gph
The 2013 f150 Carter replacement is 37gph or roughly 28% more.
Since it's top secret information here I'm ASSUMING the factory pumps are the same/similar.
This shouldn't be so hard to find
Yeah but then you should need a LPFP to feed it and will it run off the CAM correctly ?
Nothing secret. If the 11 second guys could have used it. They probably would have.
