MIR 11/8/2019 New PB 11’s
Started by StealBlueSho, November 08, 2019, 04:29:16 PM
StealBlueSho
Full weight, 1/4 tank of gas, mods in signature.
SM105K
802SHO
Yes!  Congratulations on breaking the barrier....and consistently at that!  I believe that's an 11.7 with a better 60ft!
StealBlueSho
Quote from: 802SHO on November 08, 2019, 04:42:15 PM
Yea, I'm not sure how much lower I can go on the 60ft with this wheel/tire combo...
I had to drop the psi to 20 in the front lol... there were several other passes when I was dialing it in where I blew the tires off the car..
Hearty Congrats, SBS, LONG time coming.  You have one heckuva ride there,  definitely able to knock another 1/2 second off easy if the Gods cooperate just a little bit.
Add yourself to the list here
https://www.ecoboostperformanceforum.com/index.php/topic,9516.0.html
shoNoff
Hell yea congrats. I bet that felt real nice picking up that first 11 second time slip.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Congrat's SBS on your entry to the 11's Second club and truly well deserved!
I think you will sleep better knowing you broke into the elusive 11's barrier!  Z    :thumb: :thumb: :thumb:
StealBlueSho
Quote from: ZSHO on November 08, 2019, 07:46:59 PM
I think you will sleep better from know on knowing you accomplished your goal! Z     :thumb: :thumb:  :thumb:
New goal is just .923 seconds faster ;-) But thank you!
Quote from: shoNoff on November 08, 2019, 06:51:07 PM
LOL..I will say it was was nice to see the first one, but it made me double down to make sure it wasn't a fluke lol..
Quote from: SHOdded on November 08, 2019, 06:45:46 PM
Thank you SHOdded!! Yes it was a long time in coming.. I am not sure the 2010 had it in it...but this one sure did! Yes, there is still more in it.. a 1.75 50ft would put it down in to the 11.7's which I have suspected it has in it for some time. However, I will need to move off the P-Zero's.. they just don't have the grip I need for that.
All in all I am happy. I have SHO that looks ALMOST completely stock except for the ride height and exhaust that runs 11's for sure now with only 25K on the clock.. so lots of life left in it!
A big help was working with Matt to work out some of the kinks. I am still running the stock style strategy with the throttle controlling the load and torque modulation at the shifts. Hoping that adds the longevity of the vehicle..
mybigsho
2016 SHO NON PP, HPFP, CATTED DP'S, GH INTERCOOLER,
CAI, 170 STAT, HR SRINGS, GH E30 TUNE 12.08@117.22 60' AJP E30 TUNE11.991@115.91 1.72 60'
