I went on a trip to Tennessee for a week and while there i had two issues come up.
Neither seemed vital so i'm just now posting about them.
One is a DTC that popped up, c1b00 anyone know what that code is for on a 14 xsport?
I'm thinking it's to do with a speed sensor as my cruise would show a faster speed than my needle when set.
I tried searching but only found stuff for older models.
Second issue, we stayed on a mountain, when climbing the mountain i would put it in M mode and drop it to first or second depending on speed.
Higher gear would just bog the motor horribly and it would downshift and get fussy, at least the first time i went up it did so i did the shifting myself.
Normal climb speed between 10-18mph i would shift from 1st to 2nd at about 15mph.
I went back to a stock tune for the trip because i have no way of knowing the quality of gas at stations in states i don't normally travel.
Once we would reach the top and park on the passenger side you could smell a burning odor. It seemed to come from right around the passenger door/maybe near the front wheel well.
Anyone had an issue like that? I started to think maybe the lower speeds but in 1st-2nd gear might have had the turbos pushing boost for an extended period and they just got hot or maybe pushing some oil past seals.
It didn't have any smoke that i could see though when i looked under the car or popped the hood. No smoke from tailpipe either so i'm kinda not sure?
The only time it ever happened was climbing the mountain which we did roughly 10 times.
Any insight?
