Need Some Part Numbers...Please
Started by r1crusher, August 06, 2018, 11:09:47 AM
r1crusher
Somehow I've managed to lose the retainer nut, 1/4 turn fastener and spacer for one of the rear corners of my under cover (engine splash cover on the bottom of the car).  The only thing I can locate part number wise is the retainer nut which I think is right, -W716006-S439.
If anyone has the part numbers for the fastener and spacer I would be forever grateful.
TIA!
Kevin
'13 SHO, AJP Tune w/ 3-Bar
'17 F-250 6.7 PowerStroke
'17 XSport
r1crusher
Bolts and washers would be fine if there were a way to fasten it to the subframe.  All that's there is a rectangular hole where the nut (retaining clip) would be.  Thanks for the list, pretty much all I was able to find also.
'17 XSport
Under Cover Screw - Ford (AG1Z-00817-A). I hope this helps any!  Z
https://www.tascaparts.com/oem-parts/ford-under-cover-screw-ag1z00817a
Quote from: r1crusher on August 06, 2018, 11:28:44 AM
The bracket, spacer, and retainer/screw are all in the thread I posted, should be exactly what's needed!
SHOdded is spot on! Everything you need is under one roof!  Z   :)
r1crusher
My bad SHOdded!  Sorry...I looked at the first link you posted and not the second one.
I did a search but apparently my key words didn't match up to find that post...go figure.  That's what I get for trying to search using Ford's name for parts instead of what most folks would call things.
As always one or both of you come through...THANK YOU!   :thumb:
'17 XSport
Partly my fault as I was adding links as I found them.  It's too cumbersome to search and find and copy into a temp doc and then paste all back into a single post from a mobile device, LOL.
Maybe should make that thread a sticky!
r1crusher
At least I know I'm not crazy but I originally thought there was only one link that you posted!  LOL!
I'm more pissed that when I had the car at the dealership the last time they'd of at least let me know it was missing or just replaced it and billed me.  Instead I got a $.05 zip tie installed by their tech.
'17 XSport
Saving you money LOL.  I guess they don't realize how particular  SHO owners can be.  LOL
