?! is there such a thing as a moonroof relearn ?
https://shoforum.com/index.php?threads/sunroof-reset.134864/You posted that link SHODDed lol
and
https://www.fordescape.org/threads/re-calibrate-sunroof-moonroof-on-2015-model.102577/Front Sliding Glass Panel
1. NOTE: The driver front door must be open during the entire procedure.
Open the driver front door.
2. Turn the ignition to the ON position.
3. NOTE: Complete the following within 5 seconds:
A. Cycle the ignition to the OFF position and then back to the ON position.
B. Press the sliding glass panel close switch for less than one second and release.
C. NOTE: When the sliding glass panel close switch is pressed and held, there should be an audible click from the switch within 3 seconds. The audible click indicates that the
motor has accepted the request to initialize. If there is no audible click, the procedure must be repeated from step 1.
Press and hold the sliding glass panel close switch until the glass moves to the fully open and the back to the fully closed position (this could take up to 20 seconds to start).
4. Release the switch and verify successful initialization by carrying out one-touch open, one-touch close and one-touch vent operations.
