How to stop the black soot on my tail pipes
Started by TTSport15, January 10, 2015, 10:46:05 AM
Show off.
I do typically blend between E15 and E20, I've never noticed a difference.
Funny story...
I didn't realize the inner section of the outlets were polished literally for the first year of ownership. They were solid black the day I took delivery and I never knew otherwise. Lol
Base fuel is Shell 93.
I wonder if that makes a difference?
11BLKFX4EB
Glad I found this thread because the black tips are driving me nuts on both my wifes XSport and my SHO.
The next oil change will be with the Amsoil 0w and I'm also going to polishing the tips with Mothers and adding a good coat of wax. Its amazing how bad they can get in the winter and how hard it is to clean them.
2014 SHO w/ PP Platinum White
Unleashed tuned, H&R Springs, 35% tint, Corsa catback coming...
2015 Explorer Sport Magnetic Metallic-stock...for now.
The soot on my pipes has not been there since going with a small e/85 mix. Something I used to wipe clean daily, I haven't had to do once in 6 months now. Now it's only done to get dirt off.
Rich
MDesign CAI stopped mine... strange but true.
I cleaned the tips on my SHO for the first time in perhaps 10 months or so...since last spring. About 7K miles driven in that time. Many of those miles with a mild E blend (15 to 17ish). Have to admit, it was less severe than when I polished them up before, between purchase date and last spring, when I wasn't blending E.
Definitely reduced the soot. But didn't eliminate on my SHO.
Txstrmhntr
Strangely since ive installed the meth kit the only time i get black soot is after the wife has had her out for a couple days and i know she purposely keeps it out of meth range(and boost for that matter)
OLD
2013 Taurus SHO with PP, LET Tuned, ATP+2 Turbos ,PPE Hotpipes, PPE off road DP's,  Alky control methanol injection
NEW-- 2016 Kona Blue Fiesta ST, Stock(not for long)
TTSport15
ive tried everthing to no avail soot soot n more soot
I Bleed BLue
Quote from: TTSport15 on June 30, 2015, 08:01:38 AM
Added a little E85?  Meth kit?  MDesign intake?
With a tune these engine run a little rich by design. No way except meth to prevent it.
TSS
Just another note about MDesign. Makes no sense at all to me, but I clearly have had less soot since installing about 4 months ago. I Would not believe it if I did not experience it. I Don't understand at all.....but there is a clear correlation between the install and less soot.
Quote from: TSS on June 30, 2015, 11:08:59 AM
maybe more/less air to change the AFR? That's is pretty weird.
Quote from: glock-coma on June 30, 2015, 12:06:21 PM
Had the same experience. I did begin to see soot again as the less corn/nonoxygenated summer fuel became available again. It is still less, but fuel blend has an effect
buck91
Switched from store brand "synthetic" to penzoil platinum around the same time our winter blends of gas arrived.  Have noticed extreme decrease in tip carbon.  Not sure of it was the oil or ethanol but I want to test out ethanol.  14 x sport.  Any ideas how much e85 to blend in with the e10 from the pump?
