explorer sport bov
Started by hindi1973, September 26, 2013, 01:28:54 AM
hindi1973
Hi everyone i am a new member in the forum and aproud owner of an explorer sport 2013, I was woundering how many bov's does the explorer have ? And if i want to vent to atmosphere where can i find them , Are they similar to the f150 under the car only ? Finally when i take the hose of the hard part shall i cap the rubber hose or the hard part? and is adding a crankcase vent filter a must on the open side just incase no dust gets in ?
thanks
moe
hindi1973
the 2013 explorer is abit different regarding the location of the bov and that it might be transferred to a single bov .
hindi1973
this is an example of what the 2013 explorer sport engine bay looks like , i just dont see that its similar to other how to posts .
hindi1973
Take your engine cover off, you should see a rear e-bov connected to the air intake pipe.
QwikSHO
Take off your engine cover and you'll be able to see both BOV's if you use the "how to."
I was going to do this on my wife's Sport, but she shot it down.    So when I bought my SHO, this is one of the first things I did.  LOL
I researched and found the non-red caps on eBay.
hindi1973
everything is sorted out . thanks everyone for ur help , my brain wasnt working right
chuxsvt
Here's A Stupid Question.If I Cap Off Both Bov.. Where Does Relive Pressure From..I Can'tFindWhere The Pssssh Comes From..Or Am I Doing It Wrong..Just Cap Off The Two Hoses right.
you don't cap off the blow off valve. you cap off recirc tube, where you removed the hose from.
chuxsvt
Oooooooh..I Was About To Mess tHings Up.. I Thought I Saw A Cap On The Bov..That's Why I Was confused...Okok Got It.
JimiJak
Quote from: chuxsvt on April 28, 2014, 12:48:15 AM
That's ok...you just would have ended up with an excuse to buy new intake pipes after you cracked the stock plastic ones. LOL
2014 XSport Black Betty Build
Rican219
Theres a reason why they made the rear bov hose difficult to remove,so you dont touch it,just leave it alone it will save you from future headaches.  Z
TTSport15
I did mine this weekend just plugged the lines with some pvc plugs i rigged from the depot...sounds kool 4 now
I Bleed BLue
